Greenboard On Basement Walls - Drywall - Contractor Talk
Old 01-30-2012, 06:34 PM   #1
carpenter
james127's Avatar
Hi guys,
I'm new to this site. And looking for advise on drywall. I'm remodeling a basement and would like to use greenboard on exterior walls which are studed (2x4) and regular drywall on interior wall partitions. Any thoughts? thanks
james127 is offline
Old 01-30-2012, 06:36 PM   #2
Remodeling GC
kevjob's Avatar
Rewards Points: 2,088
Re: Greenboard On Basement Walls
Why do want to use green board?
kevjob is online now
Old 01-30-2012, 06:48 PM   #3
drywaller
Mudshark's Avatar
Trade: Drywall Finisher
Rewards Points: 75
Cool
Greenboard is often used in bathrooms to help prevent mold issues but there is debate about how good this board is and some suppliers are replacing it with other products. I would go regular 5/8 on the exterior walls and not bother with the extra expense of the green board.
Mudshark is offline
Old 01-30-2012, 07:11 PM   #4
carpenter
james127's Avatar
Thanks guys. My thought on greenboard for exterior walls was to eliminate the possibility of mold growth due to condensation. Eventhough it is a very dry basement. Might be over kill?
james127 is offline
Old 01-30-2012, 07:28 PM   #5
davitk's Avatar
Trade: Perfessional Contracter
Rewards Points: 502
Greenboard will mold just the same as regular sheetrock. Densarmor Plus http://www.gp.com/build/product.aspx?pid=4659 would work well in that situation.
davitk is offline
The Following 3 Users Say Thank You to davitk For This Useful Post:
angus242 (01-31-2012), james127 (01-30-2012), Metro M & L (01-30-2012)
Old 01-30-2012, 10:31 PM   #6
www.Atlantic-Drywall.com
JMC1981's Avatar
Trade: Drywall
Rewards Points: 77
I have noticed a lot of people recommending densarmor recently for mold related issues. Let me preface this by saying that I agree 100% that Densarmor is the best product if you're worried about mold. However, I do have two concerns having used the product:
1. It's much more expensive than any type of sheetrock; MR and Green Board included.
2. It has a unique texture to it. Meaning that if you plan on coating the screws, nails, and corners as you would a normal piece of drywall you're going to be left with a surface that is smooth where the joint compound is and textured where there is no joint compound. I have found you pretty much have to skim out the entire board which results in additional costs.
Just my .02
JMC1981 is offline
The Following 3 Users Say Thank You to JMC1981 For This Useful Post:
Big Shoe (01-31-2012), Metro M & L (01-30-2012), Mudshark (01-31-2012)
Old 01-31-2012, 05:47 AM   #7
Big Shoe's Avatar
Rewards Points: 1,910
It states in it's summary '' No product is considerd mold proof ''.
I don't live in climates like alot of you guys up North. And we don't have basements here either. I'm sure there are issues I'm not accustomed to.
But I always preach ''just use regular drywall'' on dry interior areas. If something goes wrong it's because something else failed. Does this make any sense????
I just tore out some greenboard last week. It got wet.
Big Shoe is offline
Old 01-31-2012, 06:52 AM   #8
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Just my .02
1. You get what you pay for.
2. Totally agree, learned that one the hard way...
ohiohomedoctor is offline
Old 01-31-2012, 09:27 PM   #9
drywaller
Mudshark's Avatar
Rewards Points: 75
Cool
Well stainless steel comes close.
The Densarmor has fiberglass strands so yes is a rough texture to mud over but is handy on outside applications.
Mudshark is offline
Old 01-31-2012, 09:40 PM   #10
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
I don't know why this continues to be a problem for so many. I have never had this issue. I've done multiple projects where DensArmor was used in conjunction with the existing standard drywall. I have been able to match finishes without issue....every time. No skim coating necessary.
Prime with an appropriate sealer, 1/2" nap roller and it's all good. I use SW PrepRite ProBlock.
http://www.sherwin-williams.com/pro/..._latex_primer/
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
SSC (02-01-2012)
Old 01-31-2012, 09:43 PM   #11
Elyrain's Avatar
Rewards Points: 442
Densglass gold 5/8".
Ca A&B
Elyrain is offline
Old 01-31-2012, 09:47 PM   #12
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 948
Mold needs moisture and organic material to grow. Greenboard is the same gypsum product. The difference between it and regular drywall is the paper is thicker and coated with wax. It will not mold exactly the same as regular drywall, but it will mold non the less.
Mold resistant drywall would be a better choice. Basements are high moisture environment and you should protect against mold as much as possible. It's silly to say, treat a high moisture zone just like any other and when something goes wrong you need to fix that something instead of trying to prevent mold. Mold can and will grow in large quantities effecting the health of those inhabiting the dwelling long before any issue is detected.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 01-31-2012, 10:43 PM   #13
JMC1981's Avatar
Trade: Drywall
Rewards Points: 77
I prime with Tuff Hide which is the heaviest primer on the market which is marketed as a level-5 finish. If that doesn't cover the difference between the smooth joint compound and the grainy densarmor nothing will. Now, I haven't gotten complaints when this has happened. Regardless, when I notice it doesn't look right I am never happy with the finish,.
JMC1981 is offline
Old 01-31-2012, 10:44 PM   #14
davitk's Avatar
Rewards Points: 502
We used it on a basement this fall - regular sheetrock on the upper half of the walls, DensArmor on the lower half. Taped, sanded and sprayed (no primer). I'm as anal as anybody and I can't seen any texture difference.
davitk is offline
Old 01-31-2012, 10:50 PM   #15
Sounds like a lighting issue....
Old 01-31-2012, 11:02 PM   #16
JMC1981's Avatar
Trade: Drywall
Rewards Points: 77
Can you admit the board is slightly textured? That's where we need to start. If you can't then I would recommend eye glasses or maybe a large form or artificial light.
Lets cut to the next step and suppose you admit that densarmor is textured. Well, joint compound isn't, especially when it's sanded. Logic says there's going to be a noticeable different.
/end discussion.
JMC1981 is offline
Old 02-01-2012, 05:47 AM   #17
Big Shoe's Avatar
Hung it once a few yrs ago. First time the finisher and I had ever seen it. We both agreed that it should be skimmed. Have not seen or hung it since. So I can't call myself an expert on this.
We hung greenboard on bottom sheets for several builders.
All bathrooms and kitchens for example.
Can't hurt none.
Big Shoe is offline
Old 02-01-2012, 07:27 PM   #18
YUUUUP!
JWilliams's Avatar
Trade: Metal Roofing Mogul
Rewards Points: 916
ive been seeing purple board now.. what's its so called purpose?
JWilliams is offline
Old 02-01-2012, 07:44 PM   #19
SSC's Avatar
Trade: Interior Remodeling Specialists
not all green board is bad. Lafarge makes a mold and moisture board that is green in color, the same as national gypsum's purple mold and moisture and certainteed's blue mold and moisture.
Colors are company specific now and why Lafarge would choose green is IMO just bad marketing.
If you cant afford Dens armor Plus then get a mold and moisture board. and do all the walls in the basement not just the exterior ones.
I have used densarmor plus alot and have NO finishing problems at all. I only wish they made it lightweight
The Finest in Interior Renovations
SSC is offline
Old 02-02-2012, 02:03 AM   #20
drywaller
Mudshark's Avatar
Rewards Points: 75
Cool
The purple board is meant to replace the green board and is labelled as mold resistant. I have been told they don't make the green board anymore but the dealers still deliver it around here anyway.
Mudshark is offline
Finishing Basement Walls Old North Framing 6 06-26-2011 10:27 PM
Basement concrete walls - insulation options stanfordconst Remodeling 14 03-02-2011 03:09 PM
Covering block walls? barefootbuilder Remodeling 6 03-15-2010 01:28 AM
cladding exposed basement walls on exterior dakzaag Masonry 20 02-22-2009 10:23 PM
Basement Walls and Insulation highpeaks Construction 6 07-21-2008 05:36 PM
