Glue And Screw Drywall - Page 6 - Drywall - Contractor Talk
Old 05-16-2012, 12:13 PM   #101
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 998
Re: Glue And Screw Drywall
Originally Posted by Inner10 View Post
I like how at 3:00 the video explains to insulate around a pipe...here we always insulate behind the pipe if it has to run on an ext wall and put the vapor barrier behind the pipe.
Still doesn't nailing on the inside compress the edges and leave an unwanted air space all around the edge?
If you insulate only behind the pipe, you will have a considerably lower R factor in that stud cavity. Interesting that you would put the VB behind--that leaves potential for condensation on a cold-water line with no way to dry to the outside.
As for the unwanted air space, technically you're correct. But I think you'd have a hard time measuring the difference in performance, or demonstrating a meaningful increase in the likelihood of mold or rot.
Tinstaafl is offline
Old 05-16-2012, 12:19 PM   #102
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
I don't insulate anything...I just know what I see, and in the rare occasion I see pipes in an outside wall they VB behind them.
Inner10 is offline
Old 05-20-2012, 07:38 PM   #103
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
You can still buy paper back insulation? Wow haven't seen that stuff in eons.
We aren't allowed to use any faced batt insulation in basements anymore up here.
Always taught to staple to the sides of the studs.
Glue and screw rock.
Paulie is offline
