Glue And Screw Drywall - Drywall - Contractor Talk
Old 12-24-2011, 10:08 AM   #1
pro
country_huck's Avatar
Trade: Capenter/ Remodeler
Rewards Points: 768
I was taught when hanging ceilings to glue and screw the drywall, to me it made since. Is that standard practice or did i just learn from a guy that liked to take a few exstra steps.
country_huck is offline
Old 12-24-2011, 10:26 AM   #2
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,244
Re: Glue And Screw Drywall
If it is a sheet good I pretty much glue and screw it all.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 12-24-2011, 10:31 AM   #3
dibs16's Avatar
Rewards Points: 490
I've never glued a drywall ceiling other than a layover, or for soundproofing. But we strap every ceiling we drywall with 1x4 furring strips. If I were to ever screw directly to joists I would definitely glue it.
Anthony
dibs16 is offline
Old 12-24-2011, 10:44 AM   #4
PRO
BrandConst's Avatar
Rewards Points: 1,004
Never seen it glued unless overlaying. Must be something done more often up north. I use to be in the drywall business.
BrandConst is offline
Old 12-24-2011, 10:56 AM   #5
skillman's Avatar
Rewards Points: 1,968
Glue and screw no one likes nail pops.
skillman is offline
The Following User Says Thank You to skillman For This Useful Post:
TNTRenovate (12-24-2011)
Old 12-24-2011, 11:01 AM   #6
pro
Rewards Points: 768
that was the number one reason why I thought it was a good idea! but since i moved down south i havnt seen anyone do it so i was curious.
Old 12-24-2011, 11:07 AM   #7
skillman's Avatar
My drywall sub glues his 5/8 drywall on his ceiling . Doesnt use 1/2 anymore. Uses 5/8 on walls too.
skillman is offline
Old 12-24-2011, 11:23 AM   #8
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
for new installs i was taught to just screw it. if we have old walls with wallpaper we would just go over it with a layer of 1/4" glued and screwed
woodworkbykirk is offline
Old 12-24-2011, 11:29 AM   #9
skillman's Avatar
They tack it with drywall nails then on to next board. Another guy comes back and just screws all day long. They bang out houses like no one i ever seen. Last job 3,000 sq ft home done in one day with good crews.
skillman is offline
glkirk (12-25-2011)
Old 12-24-2011, 11:35 AM   #10
pro
Rewards Points: 768
When i first started we did 5/8 glued and screwd on ceiling and 1/2 on walls, I now use 1/2 that stuff meant for ceiling (the name escapes me now) and i still glue.
Old 12-24-2011, 11:36 AM   #11
Mike-'s Avatar
Trade: Renovation Specialist.
Does this not create an issue when it comes to finishing and door jamb width?
Mike- is offline
The Following User Says Thank You to Mike- For This Useful Post:
glkirk (12-25-2011)
Old 12-24-2011, 11:37 AM   #12
Mike-'s Avatar
4.563 is our door jamb width standard here in bc.
Mike- is offline
Old 12-24-2011, 11:46 AM   #13
skillman's Avatar
The 5/8 drywall goes little better over uneven studs with less bows and sags. Doors are orderd to the width of the correct door jamb as well as window jamb extension.
skillman is offline
Old 12-24-2011, 12:01 PM   #14
Mike-'s Avatar
Most of the time, it would be a custom order. Thanks for the clarification.
Mike- is offline
Old 12-24-2011, 12:24 PM   #15
Fire up the BBQ
griz's Avatar
Rewards Points: 368
Only times I have seen drywall glued & screwed is on 5/8" board over 5/8" plywood, which was also glued & screwed & edge blocked.
Common installation method in high end residential when they want that dam no texture smooth finish...
griz is online now
Old 12-24-2011, 06:57 PM   #16
Hair Splitter
Trade: General
Lazy!
Old 12-24-2011, 07:50 PM   #17
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,282
My drywall finisher moved up from Virginia... He was amazed to see me glue studs and use 5 screws per stud (in 4 ft). He mentioned that other contractors around here are pretty much the same and make the joints nice and tight.
From what he tells me, the Virginia boys are sloppy hangers...
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
The Following User Says Thank You to Tech Dawg For This Useful Post:
nature boy (12-26-2011)
Old 12-24-2011, 08:14 PM   #18
PRO
BrandConst's Avatar
Originally Posted by TNTSERVICES View Post
Lazy!
Lazy? Your clueless to say the least! Bring yourself down here for a bit and see if you can make a living gluing and screwing. I worked in the drywall business for 7 years and I'm purty darn sure I've seen alot more drywall stuck to the wall than you and it hasnt been glued.
Old 12-24-2011, 08:45 PM   #19
pro
Rewards Points: 768
your probably right but, however over 80% of home construction is track housing by huge businesses that dont care anything about quality, all they care about is that the huricane clips are installed so they can pass code and the rest is Finishes are not inspected so who cares.
Old 12-24-2011, 08:53 PM   #20
PRO
BrandConst's Avatar
I've done it domed ceilings, cathedrals, coffered..etc, etc,... in new 12k sf homes and new 2k sf homes. No glue unless your doing drywall reveals.
To add, when I was in the drywall business, we didn't work for track builders, only custom.
