-   Drywall (https://www.contractortalk.com/f49/)
-   -   glue and screw drywall (https://www.contractortalk.com/f49/glue-screw-drywall-109854/)
country_huck 12-24-2011 10:08 AM
57 Attachment(s)
I was taught when hanging ceilings to glue and screw the drywall, to me it made since. Is that standard practice or did i just learn from a guy that liked to take a few exstra steps.
TNTRenovate 12-24-2011 10:26 AM
If it is a sheet good I pretty much glue and screw it all.
dibs16 12-24-2011 10:31 AM
I've never glued a drywall ceiling other than a layover, or for soundproofing. But we strap every ceiling we drywall with 1x4 furring strips. If I were to ever screw directly to joists I would definitely glue it.
BrandConst 12-24-2011 10:44 AM
Never seen it glued unless overlaying. Must be something done more often up north. I use to be in the drywall business.
skillman 12-24-2011 10:56 AM
Glue and screw no one likes nail pops.
country_huck 12-24-2011 11:01 AM
57 Attachment(s)
that was the number one reason why I thought it was a good idea! but since i moved down south i havnt seen anyone do it so i was curious.
skillman 12-24-2011 11:07 AM
My drywall sub glues his 5/8 drywall on his ceiling . Doesnt use 1/2 anymore. Uses 5/8 on walls too.
woodworkbykirk 12-24-2011 11:23 AM
for new installs i was taught to just screw it. if we have old walls with wallpaper we would just go over it with a layer of 1/4" glued and screwed
skillman 12-24-2011 11:29 AM
They tack it with drywall nails then on to next board. Another guy comes back and just screws all day long. They bang out houses like no one i ever seen. Last job 3,000 sq ft home done in one day with good crews.
country_huck 12-24-2011 11:35 AM
57 Attachment(s)
When i first started we did 5/8 glued and screwd on ceiling and 1/2 on walls, I now use 1/2 that stuff meant for ceiling (the name escapes me now) and i still glue.
Mike- 12-24-2011 11:36 AM
Does this not create an issue when it comes to finishing and door jamb width?
Mike- 12-24-2011 11:37 AM
4.563 is our door jamb width standard here in bc.
skillman 12-24-2011 11:46 AM
The 5/8 drywall goes little better over uneven studs with less bows and sags. Doors are orderd to the width of the correct door jamb as well as window jamb extension.
Mike- 12-24-2011 12:01 PM
Most of the time, it would be a custom order. Thanks for the clarification.
griz 12-24-2011 12:24 PM
Only times I have seen drywall glued & screwed is on 5/8" board over 5/8" plywood, which was also glued & screwed & edge blocked.
Common installation method in high end residential when they want that dam no texture smooth finish...
TNTRenovate 12-24-2011 06:57 PM
Lazy! :whistling
Tech Dawg 12-24-2011 07:50 PM
My drywall finisher moved up from Virginia... He was amazed to see me glue studs and use 5 screws per stud (in 4 ft). He mentioned that other contractors around here are pretty much the same and make the joints nice and tight.
From what he tells me, the Virginia boys are sloppy hangers...
BrandConst 12-24-2011 08:14 PM
Originally Posted by TNTSERVICES (Post 1367644)
Lazy! :whistling
Lazy? Your clueless to say the least! :laughing: Bring yourself down here for a bit and see if you can make a living gluing and screwing. I worked in the drywall business for 7 years and I'm purty darn sure I've seen alot more drywall stuck to the wall than you and it hasnt been glued.
country_huck 12-24-2011 08:45 PM
57 Attachment(s)
your probably right but, however over 80% of home construction is track housing by huge businesses that dont care anything about quality, all they care about is that the huricane clips are installed so they can pass code and the rest is :censored: Finishes are not inspected so who cares.
BrandConst 12-24-2011 08:53 PM
I've done it domed ceilings, cathedrals, coffered..etc, etc,... in new 12k sf homes and new 2k sf homes. No glue unless your doing drywall reveals.
To add, when I was in the drywall business, we didn't work for track builders, only custom.
