Flat Box Advice - Drywall - Contractor Talk
Flat Box Advice
Old 04-19-2014, 10:51 AM   #1
NJ mudman's Avatar
Trade: Drywall finisher
Rewards Points: 4
Flat Box Advice
Should you sand between the second and finish coats?
NJ mudman is offline
Old 04-20-2014, 06:23 AM   #2
plasterboard/drywall stop
keke's Avatar
Trade: plasterboard/drywall stopper
Rewards Points: 20
Re: Flat Box Advice
to avoid future problems and have a perfect job must give a quick sand
keke is offline
Old 04-20-2014, 12:38 PM   #3
Anti-wingnut's Avatar
Rewards Points: 3,422
Re: Flat Box Advice
Is this a DIY question? Seems pretty rudimentary for a drywall finisher to be asking
Anti-wingnut is offline
The Following User Says Thank You to Anti-wingnut For This Useful Post:
gemerick (04-21-2014)
Old 04-20-2014, 09:30 PM   #4
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 276
Re: Flat Box Advice
Maybe he's new with the mud boxes ?
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
The Following User Says Thank You to blacktop For This Useful Post:
intjonmiller (04-27-2014)
Old 04-21-2014, 07:53 AM   #5
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,364
Re: Flat Box Advice
Maybe it's his first day, but yes you should sand between coats once they're dry. Google levels of gypsum board finish, it might help you.
KennMacMoragh is offline
Old 04-23-2014, 05:18 PM   #6
VanGoghFinish's Avatar
Trade: Drywall
Rewards Points: 61
Re: Flat Box Advice
But dont sand to much! Because the dust causes bubbles in the skim coat....
VanGoghFinish is offline
Old 04-23-2014, 09:37 PM   #7
icerock drywall's Avatar
Trade: drywaller
Rewards Points: 930
Re: Flat Box Advice
I do a quick vac sand the wall... that help with the dust bubbles
dont work hard...work smart
icerock drywall is offline
Old 04-27-2014, 04:32 PM   #8
That guy
intjonmiller's Avatar
Trade: Production process improvement
Rewards Points: 129
Re: Flat Box Advice
Complaining about people asking questions is so obnoxious. This isn't "what is corner bead?" or anything like that. If asking about proper technique with advanced tools like mud boxes is too basic then what the hell is this forum for?
intjonmiller is offline
Old 04-27-2014, 07:52 PM   #9
iDAHOchris's Avatar
Trade: dRYWALL SPECIALIST
Rewards Points: 256
Re: Flat Box Advice
If you are good with the boxes a scrape with a knife will do, but when you pick up a hitchhiker and have to re box a room you will wish you did a quick sand
iDAHOchris is offline
The Following User Says Thank You to iDAHOchris For This Useful Post:
icerock drywall (04-30-2014)
Old 04-30-2014, 02:34 PM   #10
Magic's Avatar
Trade: drywall
Rewards Points: 18
Re: Flat Box Advice
Well said!
Magic is offline
Old 05-02-2014, 09:37 PM   #11
BUTCHERMAN's Avatar
Trade: DRYWALL PROFESSIONAL
Rewards Points: 2,392
Re: Flat Box Advice
I recommend following with a next size up knife. One light flow through. Apply with 10", follow with 12" stainless steel knife. Let dry then scrape lap line. Forget sanding. Dust in skim coat makes you finish inferior.
BUTCHERMAN is offline
Old 05-04-2014, 10:47 PM   #12
Trade: drywaller
Rewards Points: 930
Re: Flat Box Advice
even a good box runner likes to do a quick sand...corners and nails get a quick sand as well even more then ever with high shoulders on the rock now
Old 05-05-2014, 02:02 PM   #13
GCTony's Avatar
Rewards Points: 482
Re: Flat Box Advice
No box experience so i'm feeling a bit stupid...I don't understand why you would need to sand between coats when using boxes. You don't sand when hand finishing do you? (I don't)
Correct me if I'm wrong but.... the mud goes on with say a 10" box, Taper edges and then pull with a 12" knife?
GCTony is offline
Old 05-05-2014, 05:24 PM   #14
Mountain Man's Avatar
Trade: Drywall
Rewards Points: 113
Re: Flat Box Advice
In theory you do not really sand, you just brush down any lap marks and edges. Often times the first coat, especially with smaller boxes, will leave heavy edges. This is amplified by bad board with high shoulders. Just a little love between coats will make everything a lot smoother when running auto tools.
Mountain Man is offline
The Following 2 Users Say Thank You to Mountain Man For This Useful Post:
icerock drywall (05-05-2014), intjonmiller (05-08-2014)
Residential Flat roof Nac Roofing 15 04-28-2018 08:46 AM
Paint or stain on hardi plank? Jer Painting & Finish Work 28 02-17-2017 08:29 PM
Flat roof - What roofing system should I use? acro Roofing 10 04-15-2013 04:47 PM
advice on flat work framergreg Masonry 9 10-27-2007 08:14 PM
I find some of these names,shocking sjm Painting & Finish Work 7 08-20-2007 05:51 AM
