Fixing Mesh-taped Corners - Drywall - Contractor Talk
Old 06-04-2014, 08:33 AM   #1
That guy
intjonmiller's Avatar
Trade: Production process improvement
Rewards Points: 129
I'm doing a small job for a neighbor. Previous homeowner "finished" the small basement. Did a full, pretty good job on a bedroom, and did a rough tape on the hall/stairs leading to the room and the bathroom. This owner is now trying to refinance so he got an appraisal and the appraiser said he can't count the basement bedroom until the hall is complete. I'd never heard that before. So he needs me to finish it up so he can count the additional square footage.
It's a small job in terms of square feet, with only one small board to hang over concrete. But the idiot used mesh tape for the corners. And all of his joints have way too much mud. The numerous butt joints and few tapers are easy enough to knock down with a power sander, but what about the mesh corners?? They aren't sharp. Do I need to cut it out (maybe with my oscillating tool?) and re-tape the corners? (My 5" R.O. sander doesn't get into corners all that well, especially interior 3-ways, and it would just chew up the tape and leave a ragged mess anyway.) Before I left I tried smoothing it with more mud, but the exposed mesh in the corner where it wasn't tight enough makes the knife bounce and gives me lines across the length of the knife. Not cool.
So, what do you think? The homeowner isn't expecting perfection, but it can't look like absolute crap either. Maybe just smooth it with the knife just shy of the corner and then caulk it? It won't be a crisp corner but at least it will be smooth?
Any ideas are appreciated. Sorry I forgot to take a picture of it for reference but you can probably imagine. Thanks!
intjonmiller is offline
Old 06-04-2014, 11:19 AM   #2
avenge's Avatar
Rewards Points: 298
Re: Fixing Mesh-taped Corners
Can you go over it with Strait Flex?
avenge is online now
Old 06-04-2014, 02:15 PM   #3
That guy
Rewards Points: 129
I thought about that but it's already built up so much I'm not sure how it would look. I may try an area like that to see how it goes. I just don't want to spend hours experimenting. I have a tendency to do that because I lose track of time.
Old 06-04-2014, 02:58 PM   #4
Big Shoe's Avatar
Rewards Points: 2,110
Get a stiff knife and knock as much chunks and high spots off as possible.
If not painted, sand with pole sander.
If go the straight flex route. 6" first coat and follow with 10 if it is as bad as you say.
Good luck.
Expect the Unexpected
Big Shoe is offline
The Following User Says Thank You to Big Shoe For This Useful Post:
intjonmiller (06-04-2014)
Old 06-04-2014, 09:07 PM   #5
BUTCHERMAN's Avatar
Trade: DRYWALL PROFESSIONAL
Rewards Points: 2,392
Forget the straight flex. In a stairway with over built mesh angle you risk popping. Straight flex is very stiff. It doesn't crack but it does pop. I suggest opening the point with a razor knife, side scraping as much of it down as you can and consider level line which is more forgiving. Just fill in the rail and don't take it to the corner. If it's real bad you may want to run an adjustable double sided knife skim as a prefill before the level line.
BUTCHERMAN is offline
The Following User Says Thank You to BUTCHERMAN For This Useful Post:
Old 06-05-2014, 04:16 AM   #6
Big Shoe's Avatar
Just re-read original post. Be sure to check back in and let us know how it all worked out. And It's really hard to recommend how to fix something like that without physically seeing it.
Big Shoe is offline
Old 06-05-2014, 06:45 AM   #7
Quad Racer's Avatar
Rewards Points: 594
Remove the mesh and as much mud as possible down to the paper of the DW. Maybe even water would help with removal? Then tape with paper and use as big a blade as needed to blend the previous guys mess. Definitely use Durabond but I use it for everything anyway. My $.02
Quad Racer is offline
The Following User Says Thank You to Quad Racer For This Useful Post:
iDAHOchris (06-08-2014)
Old 06-07-2014, 02:03 PM   #8
ToolNut's Avatar
Trade: Painting & repairs
Rewards Points: 508
Have to agree on removing the mesh. I think you are also going to find on the high joints that when you start sanding them you find those lovely little squares peeking out at you.
ToolNut is offline
Old 06-07-2014, 05:44 PM   #9
PoleBarnsNY's Avatar
Trade: Pole Barn Builder
Rewards Points: 1,419
Three options
1. Cut the mesh in the corner with a razor knife paper tape it and do the best you can
2. Use a square power sander in the corners with a very aggressive grit to get all you can then cut the tiny remainder out in the tightest part of the corner with a razor knife then paper tape it as normal
3. If it is indeed small amount of square footage, cut out the section of boards in the corners and back to the last stud and replace the board then finish as normal
My choice would be number 2
PoleBarnsNY is offline
Old 06-07-2014, 11:02 PM   #10
Walraven's Avatar
Trade: carpenter/joiner
Rewards Points: 372
What about scraping it back with a tungsten scrapper?
Walraven is offline
Old 06-08-2014, 06:56 AM   #11
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Mesh paper sands away pretty easy. I would just get yourself a 1/4 sheet sander and some 100 or 80 grit. Shouldn't take long at all.
PLC Custom Interiors and Woodworking
Lebanon, NJ (908)246-3797
https://www.facebook.com/PunchlistCarpentry?ref=hl
TBFGhost is offline
Old 06-08-2014, 12:51 PM   #12
scottktmrider's Avatar
Trade: carpenter/drywall
Rewards Points: 295
I think the best idea is to sand down so u can get enough
I read somebody said to cut it back to the next stud, I wouldn't do that.you will have a but joint with a hump and trying to float that out to the corner you will have a bigger problem than u started with
scottktmrider is offline
The Following 2 Users Say Thank You to scottktmrider For This Useful Post:
intjonmiller (06-08-2014), ToolNut (06-09-2014)
Old 06-08-2014, 04:46 PM   #13
rrk's Avatar
Rewards Points: 4,846
Just sand it down and retape
Opening the wall to the next stud just increases your problems. Having butt joints close to corners is worse than just tapering out corner.
rrk is online now
Old 06-08-2014, 06:49 PM   #14
iDAHOchris's Avatar
Trade: dRYWALL SPECIALIST
Rewards Points: 256
get it wet and wait ten minutes. It will all scrape out like butter,,, maybe cheese. The water will help
iDAHOchris is offline
The Following User Says Thank You to iDAHOchris For This Useful Post:
Old 06-08-2014, 08:08 PM   #15
Quad Racer's Avatar
Rewards Points: 594
I can agree with that. A good approach because it all has to come off the board.
Inside corners on baseboard and crown otislilly Finish Carpentry 147 05-19-2014 07:07 AM
Fixing this rock shed topps Masonry 43 02-23-2013 10:56 PM
Exterior Corners - flush or a little reveal? txgencon Windows, Siding and Doors 29 01-28-2013 09:25 AM
Using mesh tape for inside corners Kastcon Drywall 234 02-07-2012 10:27 AM
Mesh Tape Plaster Guy Drywall 19 11-01-2009 06:54 PM
