Fire Taping In Cold Weather - Drywall - Contractor Talk
Old 01-08-2019, 03:36 PM   #1
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 404
So I have about 48' of drywall seams that need to be fire taped Thursday before we can frame a garage.
Temps Thursday morning are starting out in the low 20's (Fahrenheit for you Canucks ) and falling into the teens by night.
Can I put the drywall up, put some plastic up, and run a heater under there for a hour and a half or so and use 20 min mud, then start framing in the afternoon? How long does the hot mud need to be kept above freezing?
I was going to use this stuff, https://www.amazon.com/EZ-Taping-Sys...ire+tape&psc=1 but then saw on the label it needs to be a minimum of 50 degrees to be installed...
mrcat is offline
Old 01-08-2019, 06:42 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 934
Re: Fire Taping In Cold Weather
One thing to keep in mind is that while hot mud hardens quickly, the full curing process takes much longer. Just how long, I dunno--but I bet it's more than a couple of hours.
Tinstaafl is online now
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
Fixed (01-08-2019), mrcat (01-08-2019)
Old 01-08-2019, 07:23 PM   #3
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,004
In cold weather during gypsum panel joint finishing, a minimum surface, water, mix and air temperature of 45 °F must be maintained until joints are completely dry. Adequate ventilation shall be provided to carry off excess moisture.
https://www.usg.com/content/dam/USG_...ittal-J17A.pdf
In my experience even 5 minute can take overnight to fully dry, depending on thickness. A thin coat under tape is probably at least 8 hours at 50°
Big Johnson is offline
mrcat (01-08-2019)
Old 01-08-2019, 07:27 PM   #4
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
yup. Water isn't gonna evaporate any faster just because the mud has set.
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
mrcat (01-08-2019)
Old 01-08-2019, 08:43 PM   #5
hdavis's Avatar
Rewards Points: 1,024
If the tape just needs to be stuck onto a 50F surface, I'd probably try a seaming iron or a heat gun.
hdavis is online now
mrcat (01-08-2019), SmallTownGuy (01-09-2019)
Old 01-08-2019, 10:34 PM   #6
mrcat's Avatar
Rewards Points: 404
Thanks guys.
I'm thinking I'll go with the ez tape stuff, tarp the wall, and run the space heater under there for a couple hours while we are framing the garage walls, then stick the tape on, and start setting trusses.
mrcat is offline
The Following User Says Thank You to mrcat For This Useful Post:
hdavis (01-14-2019)
Old 01-08-2019, 10:39 PM   #7
MarkJames's Avatar
Rewards Points: 18,805
I'm guessing it wouldn't hurt to store the tape on a warm dashboard, etc.
MarkJames is offline
Old 01-08-2019, 11:29 PM   #8
mrcat's Avatar
Rewards Points: 404
Yup, I've got a couple warm boxes in the trailer for the battery chargers, it'll be in one of those.
mrcat is offline
Old 01-14-2019, 03:01 PM   #9
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,030
Originally Posted by Big Johnson View Post
...In my experience even 5 minute can take overnight to fully dry, depending on thickness. A thin coat under tape is probably at least 8 hours at 50°
Whoever came up with those minute ratings must have been a politician-in-training.
They often take multiples of stated time periods. Even in low humidity, proper mix, mid-to-high ambient temps
artinall is offline
Old 01-14-2019, 06:26 PM   #10
It’s the amount of time before they can be top coated. I still wouldn’t top coat anything after only 5 minutes.
The Following 4 Users Say Thank You to Big Johnson For This Useful Post:
avenge (01-14-2019), Fixed (01-14-2019), hdavis (01-14-2019), mrcat (01-14-2019)
Old 01-17-2019, 10:59 AM   #11
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 322
Ive seen heavily coated beads with 20 min take days to cure . With proper heat.
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
The Following 3 Users Say Thank You to blacktop For This Useful Post:
Fixed (01-18-2019), mrcat (01-17-2019), Tinstaafl (01-17-2019)
Old 01-17-2019, 06:21 PM   #12
mrcat's Avatar
Rewards Points: 404
Just to follow up on this, I ended up setting the last truss 1 1/2" away from the house, and once the garage was closed in, tarped off the first 8' and ran the space heater in there for a couple hours, and stuck the ez tape on.
Worked pretty good.
mrcat is offline
hdavis (01-18-2019)
Cold weather health tip... Robie Health & Safety 6 11-20-2014 07:55 AM
Cold weather concreting perimeterbrew Concrete & Paving 4 02-09-2013 10:37 AM
Cold weather blasting.. killzoneq2 Sandblasting 10 01-25-2011 10:14 AM
Under Armor Cold Weather Gear CENTERLINE MV General Discussion 17 01-17-2011 07:32 AM
Flatwork and Block in Cold Weather CookeCarpentry Masonry 5 09-12-2010 08:14 AM
