Fire Code? - Drywall - Contractor Talk
Fire Code?
Old 03-03-2009, 10:30 PM   #1
A+ Texture's Avatar
Trade: Drywall, Modulars, Remodeling
Rewards Points: 172
Fire Code?
Bidding drywall in garage (nightmare job) against a already built home. Garage was built right up against the eave of the home. With the ext. wall he wants to keep as siding, says its DOUBLE LAYERED. Do the same firecodes apply to this. So with 2 layers of siding (the particle board or osb type) can I get away with no rock their since its an exterior wall? If I state on my bill that I'm not liable, am a liable anyway? I would have walked right back out of this job only 3 months ago. Sheesh.
A+ Texture is offline
Old 03-04-2009, 12:29 AM   #2
Butt Expert
Brocktologist's Avatar
Trade: Drywall
Rewards Points: 250
Re: Fire Code?
You might want to call the local inspector just to make sure that will pass code.
Brocktologist is offline
Old 03-04-2009, 12:52 AM   #3
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
Re: Fire Code?
You the GC who pulled the permits or some drywall contractor bidding a job at a customers request?
Drywall Contract...
Install drywall in the follwing areas...as per Joe H.O. direction, customer responsible for Permits, Inspections.
Chris
Chris Johnson is offline
Old 03-04-2009, 09:27 AM   #4
A+ Texture's Avatar
Rewards Points: 172
Re: Fire Code?
I'm a drywall contractor. I'm thinking just stating in my bill that customer is responsible for adding fireproof door and firerock to that wall. Do you think I'd be covered? My wife tells me to just walk away from this one.
Old 03-04-2009, 09:46 AM   #5
Darren@Partners's Avatar
Trade: Drywall Contractor
Rewards Points: 150
Re: Fire Code?
A wife's intuition is pretty valuable. But if you really need the work, I'd consult the Inspector and rid yourself of the liability. And charge an hour for the call.
Darren@Partners is offline
Old 03-04-2009, 08:47 PM   #6
MUDBUCKET's Avatar
Trade: DRYWALL CONTRACTOR/TAPER
Rewards Points: 25
Re: Fire Code?
You really have to check with your local city inspector or call the state for the code ,they are different in every state.
MUDBUCKET is offline
Old 03-04-2009, 08:52 PM   #7
Pompass Ass
bwalley's Avatar
Rewards Points: 1,000
Re: Fire Code?
You as the Professional need to look up the code, or get clarification on the code and do what is necessary to comply to it.
If you are unable or unwilling to do the job properly, or deal with the HO, dont take the job.
bwalley is offline
Gas Flex running through the wall of fire place acrwc10 Plumbing 6 12-07-2008 11:14 PM
New Code Coming dayspring Business 33 10-04-2008 05:08 PM
09 fire sprinklers for single family. K2 General Discussion 16 09-28-2008 08:40 PM
