Fine Thread Vs Course Thread Screws - Drywall - Contractor Talk
Old 04-05-2013, 12:47 AM   #1
StrongBuilding's Avatar
Trade: Framing , Roofing, and general carpentry.
Rewards Points: 150
OK. This may be a dumb question but!
Is there any good reason to Not use fine / fast thread screws for screwing to wood studs and joists??
Also. Does anyone hang their sheets with drywall nails and then screw it off. ??
I'm working alone hanging 12' sheets and have been tacking the sheets in place then screwing them off.
StrongBuilding is offline
Old 04-05-2013, 01:59 AM   #2
Boondockian
Dustincoc's Avatar
Trade: Getting the job done
Rewards Points: 1,018
Re: Fine Thread Vs Course Thread Screws
Well, they take more spins to drive and therefore you can drive fewer screws per battery and they take longer to drive.
In the words of General James Mattis: "Be polite, be professional, but have a plan to kill everybody you meet."
Captain Howdy: We must all go through a rite of passage, and it must be physical, it must be painful, and it must leave a mark.
Dustincoc is offline
Old 04-05-2013, 02:50 AM   #3
Rewards Points: 150
I've been having a heck of a time with the 1 5/8 course thread screws with the new Ridgid drywall gun I got last week. But the fast / fine thread zing right in . Maybe the course threads that I have are just crappy screws. . But, I loaded a strip for my Pam gun with them and they worked great.. the Millwalki gun on the Pam is 2500 rpm Ridgid is 4,000 rpm. Maybe it just me.
Old 04-05-2013, 04:39 AM   #4
Big Shoe's Avatar
Rewards Points: 2,110
Fine for metal............Course for wood.
We had a few inspectors that would actually back out screws to make sure we were using the right type.
That's when we started using High-Low screws. Boy, have'nt seen them in a while.
Expect the Unexpected
Big Shoe is offline
The Following 4 Users Say Thank You to Big Shoe For This Useful Post:
2buckcanuck (06-09-2013), fjn (04-05-2013), greg24k (04-22-2013), moorewarner (04-05-2013)
Old 04-05-2013, 05:01 AM   #5
Fortune and glory, kid.
moorewarner's Avatar
Trade: Remodeler/Restorer
Rewards Points: 1,022
It's fairly common to tack and then screw the field I do believe, and what Big Shoe said.
"If you don't have time to do it right, when are you going to have time to do it over?" ~ Wise Old Timer
moorewarner is offline
The Following User Says Thank You to moorewarner For This Useful Post:
hdavis (04-05-2013)
Old 04-05-2013, 05:07 AM   #6
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,436
What thickness drywall? We use 1-1/4" for 1/2" drywall and 1-5/8" for 5/8" drywall. Always course for wood, sharp point or drill point fine thread for metal.
overanalyze is offline
Old 04-05-2013, 06:55 AM   #7
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
I find fine drives easier when remodeling with old growth (petrified) studs... coarse for new stuff
-Steve
TimelessQuality is offline
Old 04-05-2013, 07:12 AM   #8
hdavis's Avatar
Rewards Points: 1,034
Working alone, if it's an awkward hang, I'll put some nails in, place the sheet and drive them to hold it until I can get some screws in.
I have a few different kinds of drywall screw guns, including a Rigid. I don't have problems with them not driving screws, but I lock the trigger on, and don't unlock until I finish the sheet.
hdavis is online now
Old 04-05-2013, 07:40 AM   #9
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
I almost never see coarse thread on a jobsite, I remember not to long ago the sheetrocker's boss arrived with a box of coarse thread screws and the guy yelled at him.
Inner10 is offline
Old 04-05-2013, 12:25 PM   #10
Rewards Points: 150
OK. Thanks everyone. This building was framed a few years ago. , it's inside a heated and insulated steel building. . The original framing contractor got run off with good cause.
I've been fixing and completing the framing this winter. The lumber runs from piss fir ( white fir), 2 nd growth Doug fir and western hemlock. Quite a bit of the Doug fir is harder than the hubs of hell. And the hemlock is real tough. It really dry here so lumber gets hard. I've snapped the heads off quite a few screws.
Old 04-05-2013, 12:38 PM   #11
smeagol's Avatar
Trade: new construction and remodeling
Rewards Points: 638
If a taper sees fine thread screws laying around in a just rocked house they will not cover future nail pops.
smeagol is offline
The Following 2 Users Say Thank You to smeagol For This Useful Post:
Old 04-05-2013, 01:54 PM   #12
NothingButBath's Avatar
Rewards Points: 75
That's because the rigid drywall gun is crap !!! Lol. Milwaukee makes the best IMO. Then DeWalt !! But I picked up the rigid on sale once. Used for a few hours and tossed it in the van where it has never been used again
NothingButBath is offline
Old 04-05-2013, 06:43 PM   #13
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
Like anything... you can get by with fine thread in wood... but the grip of course thread is better. Better or easier.... your decision I guess.
You can frame with #10's too I guess, or plumb with type M.
Peter
PS... I have been known to use fine in some of that Cali super hard dry doug.... but in Colorado where we use that soft SPF, I always use coarse.
MTN REMODEL LLC is offline
Old 04-05-2013, 06:53 PM   #14
mbryan's Avatar
Trade: Ministry
Rewards Points: 568
Tried a hilti?
mbryan is offline
Old 04-05-2013, 06:56 PM   #15
Rewards Points: 75
Originally Posted by mbryan
Tried a hilti?
Not a big fan of them either !!
Old 04-06-2013, 12:19 AM   #16
Rewards Points: 150
Thanks for the replies all. I wanted to get a Milwaukee. But HD didn't have one . The Dewalts are a little to big for my hand. The Milwaukee, Ridgid and Makita fit my hand pretty well. . The Ridgid seem to be a good tool.
I'm gonna try a Senco drywall collated gun. Anyone use one. ???????
Another? Anyone ever had a problem with a collated gun crushing the sheetrock under the nosepiece?
Old 04-06-2013, 12:38 AM   #17
Rewards Points: 150
With the 1 5/8 course thread screws I'm using, I suspect the screws are the problem and or something I'm doing wrong. But if they get near a knot they break if the knot wasn't on the surface of the stud and if it is they bend.
When framing with a hammer all you need to make a guy look like a green horn nail driver is fill his pouch with GripRite nails.
Old 04-06-2013, 04:38 AM   #18
Big Shoe's Avatar
For the life of me. I still don't know why someone would use 1-5/8 screws for one layer of drywall.
Back in my Illinois days in the 70's we used 1'' and 1-1/4'' Same here in Florida now.
That is your problem. Try shorter screws.
Big Shoe is offline
Old 04-22-2013, 01:50 AM   #19
Rewards Points: 150
The shorter screws did the trick. Out of say 50 driven only 1 or 2 flop over sideways. Which I think is do to me not having the gun not square to the board when I start the screw.
Thanks!
Old 04-23-2013, 09:41 PM   #20
ubcguy89's Avatar
Trade: carpenter/ interior systems
Rewards Points: 742
I am a commercial guy mainly hanging on metal, I prefer Hi Lows, but I always get fine thread. When I have a side job and I hang on wood, I use course thread. If I have to hang on a heavy guage stud then I use S-12's
ubcguy89 is offline
Deck Screws vs Joist Nails subybohn Decks & Fencing 105 06-25-2018 06:54 AM
Vinyl Window Screws Wayfarer Doors Windows, Siding and Doors 12 11-23-2010 12:11 AM
Slotted screws and other peeves! WNYcarpenter General Discussion 31 10-10-2009 11:30 AM
