Durabond Or Mud????? - Drywall - Contractor Talk
Old 02-28-2009, 10:19 AM   #1
ronm1974's Avatar
Rewards Points: 25
Ok so here is my question. usally when i have to do a patch job i will go blue mud because it shrinks and sucks the tape in. then durabond 90 so i can hopefully get two coats on in a day, then a top coat of blue.
My question is the stuff just doesnt dry fast enough which means i make multiple trips back to the job for 30 minutes of work. Does anyone have any advice????????
ronm1974 is offline
Old 02-28-2009, 10:25 AM   #2
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
Re: Durabond Or Mud?????
Insead of 90min switch to 20min durabond. Make your final skim coat tight.
Paulie is offline
Old 02-28-2009, 10:26 AM   #3
ronm1974's Avatar
Rewards Points: 25
What durabond all the way thru
ronm1974 is offline
Old 02-28-2009, 10:36 AM   #4
Paulie's Avatar
I do. Especially for a patch job. The tape coat has to be soupy though if your useing paper tape. I've had trouble when I'm not fast enough and the mud starts setting up, the tape will bubble.
Paulie is offline
Old 02-28-2009, 10:44 AM   #5
ronm1974's Avatar
Rewards Points: 25
ok you know thats kinda what i was thinking it helps to hear someone else say it. what about plastering it even if the walls are taped. just to make it go faster, but im no plaster so their for id have to learn.
ronm1974 is offline
Old 02-28-2009, 11:02 AM   #6
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
20min mud is for rookies...you need 5min mud. By the time your mixing up another pan of mud, the stuff on the wall is ready for another coat.
CrpntrFrk is offline
Old 02-28-2009, 11:04 AM   #7
Paulie's Avatar
If you haven't worked with plaster before I wouldn't mess with it. If you want to go faster they sell 5min. although be prepared to have it hardening up in the mix bucket. I just did a ceiling patch job about 32sqft used 20min for everything including lots of floating. Finished with green top thined out with water and dishsoap. Sanded next morning, had 10 man hours total including setup and cleanup. Some of these guys would say that's to long but I make a living.
Paulie is offline
Old 02-28-2009, 11:11 AM   #8
ronm1974's Avatar
Rewards Points: 25
Dishsoap ive never heard of that. Water ive heard of dishsoap, nope never....
ronm1974 is offline
Old 02-28-2009, 11:15 AM   #9
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
Rewards Points: 2,000
I do the dishsoap in the topping mix after 2 coats of 20. I carry a heat gun and I'm out in an hour if all goes well. Started doing drywall repairs many years ago and got good at it. It was impossible to get a repair guy to do the small stuff. Anything over a kitchen or bath I sub to a drywall guy. I carry 20-45-90 and a heat gun.
silvertree is offline
Old 02-28-2009, 11:19 AM   #10
I've been meaning to ask,
I was told long ago, to wet paper tape
with DuraBond, have been ever since.
Usually for a patch I use mesh tape,
but wonder, is wetting the the paper
just an old wives tale?
BTW, EasySand is good for your final coat.
neolitic is offline
Old 02-28-2009, 11:19 AM   #11
ronm1974's Avatar
Rewards Points: 25
Im wondering.........What does the dishsoapm do?
ronm1974 is offline
Old 02-28-2009, 11:23 AM   #12
Paulie's Avatar
Yeah a guy showed me that one time after I always ended up with air bubbles in my final coat. Plus it makes your mud smell good.
As far as 5min goes and being a rookie, I guess we all can't be drywall superstars. I've found I usually have to do a lot of floating which takes some time to get right. 20min works out right for this rookie.
Paulie is offline
Old 02-28-2009, 11:29 AM   #13
ronm1974's Avatar
Rewards Points: 25
So the dishsoap is for the air bubbles. I think you guys are f-in whith me. Here i go puting dishsoap in forget about it.
ronm1974 is offline
Old 02-28-2009, 11:31 AM   #14
Paulie's Avatar
my 10 man hours included lots of setup, it was a dining room with lots of antiques, tear out old plaster, cut and hang 3/8"s drywall, tape, mud and sand, clean and mop.
pictures of dustfree setup, takes time.
Durabond or mud?????-p2250033.jpg   Durabond or mud?????-p2260039.jpg   Durabond or mud?????-p2250036.jpg
Paulie is offline
Old 02-28-2009, 11:35 AM   #15
ronm1974's Avatar
Rewards Points: 25
What do you have a vacume in that box?
ronm1974 is offline
Old 02-28-2009, 11:38 AM   #16
Butt Expert
Brocktologist's Avatar
Trade: Drywall
Rewards Points: 250
If you use dishsoapm the mud will bubble up and fall off the wall. Don't fall for it!!!
Brocktologist is offline
Old 02-28-2009, 11:43 AM   #17
https://www.contractortalk.com/f49/pu...ight=dish+soap
https://www.contractortalk.com/f49/dr...ight=dish+soap
https://www.contractortalk.com/f49/so...ight=dish+soap
https://www.contractortalk.com/f49/bu...ompound-47822/
............and more if you care to look.
neolitic is offline
Old 02-28-2009, 11:47 AM   #18
Paulie's Avatar
bought a squrrel cage and motor on craigs list, mounted it in that box then pipe it out the window. It creats negitive air pressure and the dust does'nt migrate.
I've used soap for years, never had a call back.
Paulie is offline
Old 02-28-2009, 11:57 AM   #19
Darren@Partners's Avatar
Rewards Points: 150
If 5 minute goes off too fast for you, try using hot water in your 20. Not boiling, but about 90-100 F. Or even dirty water from your clean up bucket. Takes some experimentation. And the soap works, but it does burn your eyes when you sand. Mesh tape is quicker on one-trip repairs.
The only problem with using all hot mud is -- tends to swell instead of shrink over time and possibly shows up through the paint weeks later. JMO
Darren@Partners is offline
Old 02-28-2009, 12:07 PM   #20
Paulie's Avatar
I don't know what you're saying, the 20 will set faster with hot water/dirty?
Paulie is offline
Where to Purchase Durabond? turboimpala Drywall 23 11-20-2009 05:32 PM
Tips For Hand Mixing Durabond Kamala Drywall 19 08-01-2008 08:10 PM
Hot Mud LNG24 Drywall 31 10-26-2007 10:20 PM
durabond and bonding primer lornmastro Painting & Finish Work 2 04-10-2007 09:51 PM
Ez Sand 5 and bubbles Cousin Joe Drywall 11 03-24-2007 05:46 AM
