Drywall Screw Pops, ULW USG - Page 2 - Drywall - Contractor Talk
Old 04-23-2014, 09:40 PM   #21
VanGoghFinish's Avatar
Trade: Drywall
Rewards Points: 61
Re: Drywall Screw Pops, ULW USG
Originally Posted by Magic View Post
Ya ya. Its all our fault. It has nothing to do with your new rock... Thanks
That's what there trying to shove down our throats!!! Like we were born yesterday and don't no what we are doing? That's the best they could come up with is wet lumber? Then how in the hell do explain it happening in ever rehab, remodel, and patch job we do? The lumber has been dry for year guineas! Nice try....
VanGoghFinish is offline
The Following User Says Thank You to VanGoghFinish For This Useful Post:
Magic (04-30-2014)
Old 04-23-2014, 09:49 PM   #22
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
I cut into some usg ultra light weight a few weeks ago and found a silver dollar size hole in it. Just paper on both sides.
I got some gold 5/8th today. That felt a lot heavier than the certainteed we usually use. It snapped and rasped really nice. I might make a switch.
jlsconstruction is offline
Old 04-25-2014, 11:43 AM   #23
ToolNut's Avatar
Trade: Painting & repairs
Rewards Points: 508
Another problem that has been noted is with the painters. When finished painted looks good, go back a few months later looks like crap. Seems this junk aborbs lots more paint.
ToolNut is offline
The Following User Says Thank You to ToolNut For This Useful Post:
Magic (04-30-2014)
Old 04-25-2014, 04:33 PM   #24
Trade: Drywall
Rewards Points: 61
This stuff is junk in so many ways! Manufacturers dont want to fess up that there is a problem because the have spent to much money retooling there production plants for the lightweight drywall. It just as bad s the Chinese drywall if you ask me! Mark my word that there is something big that will come out of this. Lightweight is in thousands of jobs if not millions and it a ticking time bomb when it decides to show it ungly face with it problems. I think im going to start a blog on it and get everyone's stories and experiences with it.
blacktop (04-28-2014)
Old 04-27-2014, 09:27 AM   #25
3rdgen's Avatar
Trade: drywall
Rewards Points: 31
Agreed we have had horrible luck with this stuff too! High shoulders have costs me so many hours it's not funny. I don't know where you live but our main problem with these popped screws in the field is the bib system insulation. Or when they spray a few inches of foam and add batts over that. The walls are over filled and the light weight board is to soft. If you screw it off like normal all looks just fine until u push with ur hands on the wall and every screw pushes out. If I can't talk the builder/home owner into doing the entire job with 5/8" we have to double tap the walls (screw field off again. Even then I warm them before I start the project that this can and will be an issue.
3rdgen is offline
The Following User Says Thank You to 3rdgen For This Useful Post:
Old 04-27-2014, 01:47 PM   #26
Ancient Rocker
Ancient Rocker's Avatar
Trade: drywall hanger
Rewards Points: 97
The original problem in this situation is the insulation, not the drywall. If the cavity is overfilled, it makes no difference if you use 5/8 or not.
If you think hiring a professional is expensive, wait until you see what an amateur costs.
Ancient Rocker is offline
Old 04-27-2014, 08:42 PM   #27
Trade: Drywall
Rewards Points: 61
Correct! He is dealing with a different problem. I see this thread is getting a lot views since I started posting facts. Come on guys dont be shy I know there are plenty of seeing the same problems. So lets here them the more noise we make the faster things might get done.
Old 04-27-2014, 09:06 PM   #28
Burns-Built's Avatar
Trade: Residential Construction & Masonry
Rewards Points: 430
We have been having the same problems as well here in pa, the drywall finisher has had quite a few houses "pop" and had to repair. The screws arent' popping though, looks good until after painted and then the screws stand proud of the board, if you push on the board the screw isn't popped it doesn't move but the screws are proud of the board.
I don't think the problem is in the frame but the board is to wet. Does anyone know the perm rating of the new board compared to the old? The drywall soaks up moisture a lot more than the old stuff apparently. The way they are making the board makes it hold water because it is so porous.
There will always be a market for quality.
Burns-Built is offline
Old 04-28-2014, 10:21 AM   #29
ToolNut's Avatar
Rewards Points: 508
I would guess you are correct that's why the painters are starting to see big problems with it.
ToolNut is offline
Old 04-28-2014, 02:17 PM   #30
Trade: Drywall
Rewards Points: 61
Bingo! This is the problem I am talking about and im 100% sure lots of others are as well. But they havent caught on its a problem with the lightweight sheetrock and thy are blaming themselves and taking responsibility for the repairs. Just like I did for over a year and a half. I had a house/homeowner I did almost two years ago call me a few mouth back to come and take a look and my job. EVERY and I mean EVERY screw was sticking out of the walls and ceilings. Even shows thru the tape on flats and butt joints! And that when I realized there was a problem because I had already fixed and of them once the year before a few months after I rock it!
Old 04-28-2014, 02:21 PM   #31
Trade: Drywall
Rewards Points: 61
Bingo! This is the problem I am talking about and im 100% sure lots of others are as well. But they havent caught on its a problem with the lightweight sheetrock and thy are blaming themselves and taking responsibility for the repairs. Just like I did for over a year and a half. I had a house/homeowner I did almost two years ago call me a few mouth back to come and take a look and my job. EVERY and I mean EVERY screw was sticking out of the walls and ceilings. Even showed thru the tape on flats and butt joints! And thats when I realized there was a problem because I had already fixed all of them once the year before a few months after I rock it!
Old 04-29-2014, 12:56 AM   #32
lawnco's Avatar
Trade: Full service remodeling contractors since 1945
Rewards Points: 4
A local rocker thinks the problem is with this Eco friendly "Green"glue. It seems this stuff has a longer cure rate ,expanding initially and then shrinking pulling the rock tight and causing the screws to appear to be popping.
When pressed at the screw there is no movement but the screw appears to be proud of the surface, we are eliminating glue to see if the results change.
Code calls for more field screws with no glue every 12" without glue 16" with glue, our local municipalities require a screw inspection prior to coating, they require 5 screws per stud in the field, so why glue?
Glue is used so fasteners can be fewer, with local codes we are eliminating glue.
lawnco is offline
Old 04-29-2014, 01:25 AM   #33
lawnco's Avatar
Rewards Points: 4
I just looked over USG how to install Sheetrock guide. REALLY 48 pages of what we are not doing correctly.
Funny how problems are always us installers. The manufacturers change products overnight and never test or inform us of any changes, it is business as usual with us being the fall guys.
They take zero responsibility for their lack of educating us as to their money saving changes and we are to blame.
I have been hanging and finishing rock for 30 years with zero problems, now all of a sudden I don't know what I am doing.
Lightweight Sheetrock ???
Green glue???
All of a sudden framing lumber that has always been to wet is too wet?
NOW US INSTALLERS ARE AT FAULT???
Oh "did you happen to read our installation manifesto".
It is Sheetrock, not a science project.
But it appears to be an "EXPERIMENT" WITH US CONTRACTORS AS THE PATSY'S.
lawnco is offline
The Following 3 Users Say Thank You to lawnco For This Useful Post:
blacktop (04-29-2014), mnld (04-29-2014), ToolNut (04-29-2014)
Old 04-29-2014, 03:56 PM   #34
ToolNut's Avatar
Rewards Points: 508
It's not the glue I don't use glue.
ToolNut is offline
Old 04-29-2014, 04:06 PM   #35
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 214
Glue could be a factor . But not the only reason why.
I've seen pops on board that was glued and not glued.
The unglued board had tons of pops due to the amount of fasteners used.
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
Old 04-29-2014, 09:04 PM   #36
3rdgen's Avatar
Trade: drywall
Rewards Points: 31
I'm gunna argue this 5/8. Makes a huge difference. The new 1/2" is very soft and the screw sets long before it right to the wall. 5/8" is still solid and will suck down. I also believe that the screws showing after is a moisture issue it doesn't matter how many time you spot them they keep showing.
3rdgen is offline
Old 04-30-2014, 04:04 AM   #37
Big Shoe's Avatar
Rewards Points: 1,910
Wow
Did not realize how much trouble this allegedly appears to be causing. Curious if any of my full time drywall buddies are dealing with this too.
I'll try to find out.
Expect the Unexpected
Big Shoe is offline
Old 04-30-2014, 06:31 AM   #38
smeagol's Avatar
Trade: new construction and remodeling
Rewards Points: 638
We use gold bold no sag ceiling board for walls too. A few pounds heavier than standard board but man it can hold a fastener. You can tack up lids with 4 screws
smeagol is offline
Old 04-30-2014, 06:42 AM   #39
Magic's Avatar
Trade: drywall
Rewards Points: 18
Originally Posted by Big Shoe View Post
Wow
Every finisher I know is going through this. We do a beautiful job finishing but once painted the trouble starts.
Magic is offline
Old 04-30-2014, 06:55 AM   #40
Magic's Avatar
Trade: drywall
Rewards Points: 18
And how do we explain to our clients that the rock we get is plagued with problems?
Wish the manufacturers cared...
Magic is offline
Screw Pops! I'm Screwed!! Haydin Drywall 57 04-07-2013 04:19 PM
consequences of improper steel stud drop ceiling installation mohdmaruf Drywall 29 04-02-2013 11:43 PM
Screw gun keeps tearing paper on tapered side??? Spencer Drywall 13 02-20-2013 10:11 AM
Drywall sagging on 24" o.c. ECinc Drywall 20 10-30-2010 08:31 PM
Lead testing on drywall and plaster hammerz_nailz General Discussion 10 06-15-2010 11:48 PM
