Drywall Repair Failure - Page 4 - Drywall - Contractor Talk
Old 04-03-2015, 05:45 PM   #61
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 294
Re: Drywall Repair Failure
Originally Posted by BUTCHERMAN View Post
What does that even mean? This sounds like that scene in the movie Major League where they said "It's not a homerun, it's too high".
That tells me a lot about you.
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
Old 04-03-2015, 06:05 PM   #62
hdavis's Avatar
Rewards Points: 2,000
I still don't see much other possibility than the mud under the tape staying wet, weakening the adhesion of the paint layer. To me, that's the only thing that fits.
hdavis is online now
Sir Mixalot (04-04-2015), Xtrememtnbiker (04-03-2015)
Old 04-03-2015, 06:44 PM   #63
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 340
I don't know for sure what fits, but I see bare drywall where there used to be paint. Means the paint failed somehow right?
Not saying it's not our fault though.
Xtrememtnbiker is offline
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
hdavis (04-03-2015)
Old 04-03-2015, 08:13 PM   #64
hdavis's Avatar
I can't come up with a way it would be your fault, other than you agreed to patch it.
Old 04-03-2015, 08:37 PM   #65
avenge's Avatar
Rewards Points: 250
This argument could go on forever, simple fact is the paint/primer failed for whatever reason. That shouldn't happen I don't care if you used contact cement. Not your fault but you should still fix it at no charge.
avenge is online now
The Following User Says Thank You to avenge For This Useful Post:
hdavis (04-03-2015)
Old 04-03-2015, 09:06 PM   #66
Rewards Points: 340
Which we did.
overanalyze (04-04-2015)
Old 04-04-2015, 09:06 AM   #67
BUTCHERMAN's Avatar
Trade: DRYWALL PROFESSIONAL
Rewards Points: 2,392
It tells me about you. You like to dismiss the obvious here because you don't want to offend. You can't correct a problem if you can't recognize it. Result: problem continues. The problem wasn't the wipe or mesh. It was lack of setting mud. See those dry spots? There are areas where the tape is shredded and still adhering. This dismisses your theory completely. Where you see the drywall paper are areas that have no setting compound. It could have peeled, but I doubt it. The areas that did adhere shredded the paper. The set mud wasn't thick enough. Taping 101. You can't over wipe drywall tape to where the underneath is completely dry. Sorry, you are wrong. If you want to solve the problem you have to recognize it. You clearly don't. Sorry if it offends you. You are totally wrong and making professionals here look stupid. That don't jive with me. I know better.
BUTCHERMAN is offline
The Following User Says Thank You to BUTCHERMAN For This Useful Post:
blacktop (04-04-2015)
Old 04-04-2015, 09:10 AM   #68
BUTCHERMAN's Avatar
Is it possible that the patch piece was 5/8 and the existing was 1/2 inch? It looks like a heavy fill that was weak.
Old 04-04-2015, 09:42 AM   #69
hdavis's Avatar
According to the OP, that was existing, which was painted, and the paint is now gone in those areas - it peeled off taking the mud with it. Also according to the OP, the paper tape you see is on the patch they put in, so it's stuck to bare drywall.
Old 04-04-2015, 09:52 AM   #70
Rewards Points: 340
You sir, are correct.
In the past, we had some issues with wiping too tight. The whole deal of trying to not build up too much. We have learned from that but not sure what stage of learning we were in two years ago when this happened.
hdavis (04-04-2015)
Old 04-04-2015, 10:11 AM   #71
SamM's Avatar
Trade: Carpenter/Handyman
Rewards Points: 1,484
I don't think it's wiped too tight. The tape stuck fine to the patch.
I'd say it's the mud under the tape keeping things moist long enough to break the bond. Makes the most sense to me.
Did the mud pull out if the screw holes when you pulled the tape?
Your Dreams won't work unless you do.
SamM is offline
Old 04-04-2015, 10:21 AM   #72
Rewards Points: 340
I think it was screwed farther back than the tape. I don't recall seeing screws.
Old 04-04-2015, 10:23 AM   #73
thezoo's Avatar
Rewards Points: 238
Sorry guys, but i am confused by what you mean with "wiped too tight".
I put 1/8-3/16 of mud, embed tape, wipe with 4" pulling majority of mud off. Tape has maybe 1/16 of mud left under it. Can you pull more mud off with excess force? Yes. But am i pulling too tight by leaving about the thickness of tape under? I have had instances before where next day some spots were not adhered along length, i figured it was not enough put on bedding or too much pressure but nothing recent.
My last job i used fibafuse and enjoyed it, seemed much easier to bed than paper.
As for moisture levels, i installed some large windows that i did drywall returns with no casings. While priming, i kept pulling the feathered mud off the pre-existing flat painted drywall. There i assumed either dirty/dusty or taking too much time to layoff the primer (i finish by pulling roller ceiling to floor for consistent stipple). This was in an addition built '89 or about. Mud was either easysand or greentop ap. now i try to apply and layoff as quick as possible, lol.
This is strange, i have seen lots of tape pull away but never pull paint from bare drywall. Seems like the tape gets wet, loosens mud but paint keeps top dry and tape separates from surface leaving a layer of mud with mud and paint still on top.
thezoo is offline
Old 04-04-2015, 10:34 AM   #74
Drywall Slave
blacktop's Avatar
Rewards Points: 294
Once again I stand corrected....and it won't be the last time!
blacktop is offline
Old 04-04-2015, 11:33 AM   #75
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
Pushing too much mud out from under the tape, "wiping to tight".
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following User Says Thank You to TNTRenovate For This Useful Post:
Old 04-04-2015, 02:08 PM   #76
SamM's Avatar
Look at the picture. Three black spots on the original drywall under where the tape would have been. I assumed that was the screws.
SamM is offline
Old 04-04-2015, 10:46 PM   #77
Rewards Points: 340
Yes, that was screws on that particular end. Compound is gone.
Old 04-05-2015, 07:04 AM   #78
icerock drywall's Avatar
Trade: drywaller
Rewards Points: 930
I have pulled tape off and it looks just like the photo...I happen because he did not mix the mud with a whip. working out of the bucket with out mixing it up is what I am going with
dont work hard...work smart
icerock drywall is offline
Drywall Subcontractor NJ LouCHI Help Wanted or Looking For Work 0 08-08-2012 06:40 AM
Drywall on studs won't line up with base awmyfreaknhead Drywall 19 07-20-2012 04:45 PM
paint flash after drywall repair bill02 Drywall 2 03-10-2009 12:51 AM
How much advantage is 5/8 drywall over 1/2"? Jim S. Drywall 2 08-26-2008 10:52 AM
Drywall Repair Rates Myson Painting Painting & Finish Work 6 04-01-2008 11:28 PM
