Drywall Repair Failure - Page 3 - Drywall - Contractor Talk
Old 03-28-2015, 12:49 PM   #41
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 340
Re: Drywall Repair Failure
Originally Posted by icerock drywall View Post
and what kind of mud did you use on your tape coat...Did u you light mud ?...and dont see to many screws ...did you add blocking ?
I add mudmax to my repair jobs...no need to paint first.
I have no idea what mud was used. It was 2 years ago.
It was screwed every 16" on joists.
Xtrememtnbiker is offline
Old 03-28-2015, 12:58 PM   #42
Rewards Points: 340
Originally Posted by Sir Mixalot View Post
Unless the tape kept the mud underneath it from drying longer than the area with no tape and that could be what made the primer and paint fail underneath the tape. It was just wet to long...
@Extrememtnbiker, How long did you wait before you second coated over the embeded tape and then before priming and painting?
Not sure. My Dad did the repair and it was two years ago. I think we used to wipe too much mud out on tape coat. That could be part of it.
The job was finishing off an attic as I mentioned. So I would assume there was no rush and we would have had a day between coats minimum.
When you explained how you do repairs, I have a couple questions.
So you spray Kilz as quick as you can I assume. This is not on the bare drywall for your patch, but on the surrounding surface that was existing. 12"-14" out?
Then after that dries, you tape with hot mud 20 or 45. Are you using the fibafuse tape or mesh?
How quickly can you put the next coat on? Guys on here have said things like, hot mud is dry but not cured.
With the fibafuse, my understanding is you could tape and then coat over the tape at the same time. Then I guess you would let that dry some, and do another coat.
Then come back and do a 3rd a different trip.
I'm just interested in a bit more info if you're willing to share.
Old 03-28-2015, 02:18 PM   #43
icerock drywall's Avatar
Trade: drywaller
Rewards Points: 930
if it was durabond the tape would not come off
same with ap if its mixed so It must be light crap...
2nd coat over ff with the 2'' roll is not good....might peek
I never prime before I do any repair...I might get a little bubble sometimes but no big deal.
with ff 36'' rolls you cant go wrong
dont work hard...work smart
icerock drywall is offline
Old 03-28-2015, 06:43 PM   #44
BUTCHERMAN's Avatar
Trade: DRYWALL PROFESSIONAL
Rewards Points: 2,392
Exactly, if it was primed, then I might think the primer was still wet when taped.
BUTCHERMAN is offline
Old 03-31-2015, 05:21 PM   #45
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 294
Paper tape will stick to paint just fine. even with high gloss ..It will stick.
The op's pic looks like the tape was wiped too tight . Like Rob said poor adhesion . And now it's been redone with FF? Good luck!
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
Old 03-31-2015, 05:36 PM   #46
Rewards Points: 340
So what's wrong with Fibafuse?
Old 03-31-2015, 05:44 PM   #47
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 696
Larn me, how do you do that? I thought the object was to squeeze just about everything out from under it.
As for sticking to the paint, it did in this instance.
Tinstaafl is online now
Old 03-31-2015, 06:07 PM   #48
Drywall Slave
blacktop's Avatar
Rewards Points: 294
It helps to leave mud under the tape.
Did you not see the bare rock? Kinda hard to see if it stuck to the painted surface ? Since It was a painted surface. But the bare board tells me there was no mud beneath the tape for adhesion . That's why it failed.
or not. I could be way off base! I''m just looking at a picture on the web!
blacktop is offline
Old 03-31-2015, 06:10 PM   #49
Drywall Slave
blacktop's Avatar
Rewards Points: 294
It ain't paper !
blacktop is offline
Old 03-31-2015, 06:11 PM   #50
Rewards Points: 340
But there was paint between the tape and the board. Bare board proves the paint failed. Right?
Old 03-31-2015, 06:12 PM   #51
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
It ain't paper !
And it makes my hands itchy...
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
Old 03-31-2015, 06:12 PM   #52
Rewards Points: 340
It ain't paper !
Well isn't that helpful. have you seen it fail?
Old 03-31-2015, 06:34 PM   #53
Drywall Slave
blacktop's Avatar
Rewards Points: 294
After enlarging the pic ..It's messed up that the tape stuck to the painted surface but failed to the bare board ..seems like the other way around would have made more sense ... I still say it was wiped too tight .
But lets take a step back here .. Why did you tear the tape off.. Did It crack or bubble up?? I think I missed that part . ADD!!
blacktop is offline
Old 03-31-2015, 07:01 PM   #54
Rewards Points: 340
The side it stuck to was the bare repair board. The side it failed was the already painted surface of the existing ceiling.
But what you are seeing and calling bare board is the existing ceiling that was painted before my repair. The tape was cracking and hanging down a slight bit. I just pulled the tape off with my hands.
The paint pulled off the existing board. And was stuck to the tape/mud.
Old 03-31-2015, 07:10 PM   #55
Drywall Slave
blacktop's Avatar
Rewards Points: 294
unless I was there to do the patch work In the first place !It's really hard to say over the interweb!
blacktop is offline
The Following User Says Thank You to blacktop For This Useful Post:
Xtrememtnbiker (03-31-2015)
Old 04-01-2015, 07:17 AM   #56
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
It ain't paper !
It's gods gift to rookie patching! I love it!
Inner10 is offline
Old 04-03-2015, 01:02 PM   #57
BUTCHERMAN's Avatar
If it was regular drywall, then you are good to go. Over paint you can do that. It's just not likely.
Old 04-03-2015, 01:06 PM   #58
BUTCHERMAN's Avatar
Not enough mud in setting the tape. Come on people this is taping 101. This is obvious.
Old 04-03-2015, 02:18 PM   #59
Drywall Slave
blacktop's Avatar
Rewards Points: 294
It did look like the new board was the high side..I agree . It was wiped too tight.
blacktop is offline
Old 04-03-2015, 04:32 PM   #60
BUTCHERMAN's Avatar
What does that even mean? This sounds like that scene in the movie Major League where they said "It's not a homerun, it's too high".
Drywall Subcontractor NJ LouCHI Help Wanted or Looking For Work 0 08-08-2012 06:40 AM
Drywall on studs won't line up with base awmyfreaknhead Drywall 19 07-20-2012 04:45 PM
paint flash after drywall repair bill02 Drywall 2 03-10-2009 12:51 AM
How much advantage is 5/8 drywall over 1/2"? Jim S. Drywall 2 08-26-2008 10:52 AM
Drywall Repair Rates Myson Painting Painting & Finish Work 6 04-01-2008 11:28 PM
