Drywall Pin Holes (Air Bubbles) - Page 2 - Drywall - Contractor Talk
Old 01-30-2008, 07:57 PM   #21
Tim0282's Avatar
Trade: drywall contractor
Re: Drywall Pin Holes (Air Bubbles)
Originally Posted by player2watch View Post
in smoth wall finishing, after sanding the 3rd coat, take a damed sponge and wipe down all joints and nails or screws, then using a light to veiw the walls use mud with a small amount of blue chaulk mixed up in it. then touch up all pin holes and other inperfections. then you go back to the blue spots and sand off the edges.
Great idea with the chalk! I like that!!
It is so easy to miss sanding where you just touched up. I've just tried to go on memory, but I am getting older and getting that part timers disease.
Tim
Tim0282 is offline
Old 02-24-2008, 06:39 PM   #22
Drywall Swine's Avatar
Trade: I own a drywall company
Rewards Points: 25
I recently finished a home for a friends friend. The job was 2.5 hours away and he called my partner and I back because of air pockets he was unhappy about. We were also unhappy, we have never had any call backs before and it was far from home. We went back touched up the bubbles and sucked it up. Never really saw pockets that bad before on our own work we were a bit confused. After reading these posts I remembered that the HO said he would take care of the dust on the walls and that instead of wiping down the walls and ceilings he just took an air compressor and blew off all the dust I laughed at the time, but now Im thinking he waisted alot of our money on gas and a days work. Do you think this is why all the mud holes showed through?
Drywall Swine is offline
Old 02-24-2008, 08:20 PM   #23
Brocktologist llc.
Brockster's Avatar
Trade: drywall
Rewards Points: 250
Tim
No kidding Tim, it's s darn easy to miss a touch up spots to sand. This blue chalk idea is great!
Brockster is offline
Old 02-24-2008, 09:03 PM   #24
taper71's Avatar
Trade: Drywall Taper
Rewards Points: 250
I use red food coloring.
taper71 is offline
Old 02-24-2008, 09:29 PM   #25
CrazyTaper's Avatar
Trade: Drywall Finisher
Rewards Points: 250
Suprisingly, I use urine.
CrazyTaper is offline
Old 02-24-2008, 09:55 PM   #26
Tim0282's Avatar
I'm thinking my guys would not like this idea very good...
Tim0282 is offline
Old 02-24-2008, 09:57 PM   #27
Tim0282's Avatar
Taper71 do you use the red in the mud that you use to touch up??
Tim0282 is offline
Old 02-24-2008, 09:57 PM   #28
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 3,429
You are supposed to do that in the empty buckets.
Sir Mixalot is offline
Old 02-24-2008, 10:02 PM   #29
I don't use the red chalk because it can bleed through when it's painted. But I never tried the red food coloring. Have you ever had it bleed through?
Old 02-24-2008, 10:08 PM   #30
Tim0282's Avatar
Booo!!! Wake up Taper71. Where'd ya go? Yer hidn from us arnt ya?
Tim0282 is offline
Old 02-24-2008, 11:04 PM   #31
taper71's Avatar
Rewards Points: 250
I've never had it bleed through. It actually only tints it a little . Just enough to see where your touch ups are.
And Tim if you dont mind some of us actually have a life- my wife makes me do things against my will.
taper71 is offline
Old 02-25-2008, 07:55 PM   #32
Tim0282's Avatar
I was just kidding you, Taper71.
I think the red in the mud is a great idea!
Tim0282 is offline
Old 02-25-2008, 08:51 PM   #33
taper71's Avatar
Rewards Points: 250
The red dye actually turns the mud a light pink- much to the happiness of my wife who is the one usually doing the touch ups. lol Sorry Tim I meant to put a smilie face after my previous wife statement.
taper71 is offline
Old 02-25-2008, 10:57 PM   #34
Tim0282's Avatar
I'd say you have good wife. One that will take care of the touch up is pretty amazing! I'd make the mud pink or any color she wanted. Just to have some else do it.
Tim0282 is offline
Old 03-11-2008, 11:41 PM   #35
Worm Drive's Avatar
Trade: carpenter
Rewards Points: 93
Brilliant! Thanks
Worm Drive is offline
Lots of questions about drywall and bathrooms nobody Drywall 30 11-27-2008 01:33 PM
electrician seeks drywall help (pictures inclided) filburn Drywall 2 01-21-2008 06:58 PM
Bubbles when taping over paint raven2006 Drywall 30 12-23-2007 04:39 PM
Breaking into the commercial drywall work dryrocker27 Commercial Construction 8 12-11-2007 06:48 PM
What the heck? Holes in basement floor Terrence Remodeling 4 06-13-2007 01:06 AM
