Double Drywalling Between Studs And Rafters - Page 2 - Drywall - Contractor Talk
Old 01-06-2019, 12:56 PM   #21
90%-er
onmywayup's Avatar
Rewards Points: 2,236
Re: Double Drywalling Between Studs And Rafters
Originally Posted by woodspike View Post
true dat .
i didn`t do as he specified exactly. i am going back tomorrow and will replace those pieces for free .
but no it wont be quick .
fully adhered o the back , i will be pulling that chitt down in little pieces . my fault no matter how much i don`t agree .
Why not slap another layer over the ones that are too loosely cut? Save the labor of pulling the wrong ones, and he gets another layer of soundproofing there. Sell it, baby
"Internet Commando"
onmywayup is offline
The Following User Says Thank You to onmywayup For This Useful Post:
TheConstruct (01-06-2019)
Old 01-06-2019, 06:13 PM   #22
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,403
Sounds like (Pun intended...) you are working on stopping the drips on a submarine with several screen doors mounted through pressure Hull.....
When the crazy Doc turns up the sound levels, he going to be looking for a fall guy...to blame for his ignorance.
Record in writing all work orders, get paid early and often, save money for the lawyers, Run, don't walk away from this civil law suite.
Fouthgeneration is offline
Old 01-07-2019, 09:26 AM   #23
madmax718's Avatar
Trade: General
Rewards Points: 3,276
Air sealing is very important to sound proofing. Without air sealing the sound still travels. Roxul safe and sound, + poly, caulked and taped, rubber sound channel, 2 layer sound proof drywall, a floating floor, and surface mounted electrical gang boxes. Yes, those leak sound too. Its a 1960's apt, dont expect modern standards for floor and wall rigidity. In the city, all new construction is concrete + steel channels + roxul
madmax718 is offline
Old 01-27-2019, 02:19 PM   #24
PeteStreet's Avatar
Trade: Interior light rehab-kitchens, baths, tile etc
Rewards Points: 52
RE that 3/8th of an inch..inside corners? where walls meet ceiling etc?
At those points, for soundproofing treatment..most in the know will say you dont WANT your drywall tight where different planes meet
...you want a decent gap that is completely filled with a good acoustical sealant ..the idea is that the drywall is bearing the brunt of the initial contact with the noise..drywall is in many ways a resonator, it has a 'ring' to it..
You want discourage the sound from traveling through those sheets where you can...corners are deemed important for decoupling...you let the MASS
(most important for soundproofing) be the top plates of the structure behind these areas..and you decouple the drywall
If you're talking 3/8 at joints..butt and finish? jesus...fill them with Durbond before taping ...guy's nuts.
PeteStreet is offline
The Following User Says Thank You to PeteStreet For This Useful Post:
Fouthgeneration (01-28-2019)
