Dangerous Wall Texture - Page 2 - Drywall - Contractor Talk
Old 12-26-2018, 10:57 PM   #21
hdavis's Avatar
Rewards Points: 2,318
Re: Dangerous Wall Texture
Personally, I'd demo it out.
hdavis is online now
Seven-Delta-FortyOne (12-26-2018)
Old 12-26-2018, 11:22 PM   #22
tjbnwi's Avatar
Rewards Points: 1,826
Originally Posted by Big Johnson View Post
I prefer Arlingtonís.
https://www.cableorganizer.com/arlin...-extender.html
tjbnwi is online now
The Following 3 Users Say Thank You to tjbnwi For This Useful Post:
rescraft (12-27-2018), Rio (12-27-2018), Seven-Delta-FortyOne (12-26-2018)
Old 12-26-2018, 11:32 PM   #23
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,028
Can't see how any of this is easier than pulling the wall board and hanging new.
The Following 3 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
avenge (12-27-2018), Fixed (12-28-2018), hdavis (12-26-2018)
Old 12-26-2018, 11:49 PM   #24
Jay hole's Avatar
Trade: General contractor
Rewards Points: 1,717
Iíve seen guys cut a new box on the miter saw to the size they need.....might be cheaper.....
Jay hole is offline
Old 12-26-2018, 11:58 PM   #25
hdavis's Avatar
No doubt, but I don't think that's a listed box extension.
jproffer (12-31-2018), Seven-Delta-FortyOne (12-27-2018)
Old 12-27-2018, 06:57 AM   #26
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 892
$1.48 instead of $0.50? My time is worth more than that not to mention my fingers.
Big Johnson is online now
hdavis (12-27-2018)
Old 12-27-2018, 11:07 AM   #27
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 8,469
Originally Posted by Jmotre View Post
So, I have been tasked with removing the thickest crows foot texture on a wall I have ever seen. Itís ugly and obtrusive. Some of the higher peaks are probably 3/4 an inch. Itís borderline dangerous. Any tips would help. With how heavy it is and the fact itís painted will definitely make sanding a joy.
Is the best I can do sand and skim until I have a smooth surface?
Part of me would like to rip off the drywall and start anew but thatís not really feasible. It is a pretty large living room.
What year was the home built?
-Paul
TextureMaster.com
Checkout my YouTube Channel with 70,000 Subscribers and over 11,000,000
My Latest Video: https://youtu.be/E23Y-fw4KCM
YouTube Channel: https://www.youtube.com/paulpeck
Twitter Facebook Instagram YouTube
Sir Mixalot is offline
Old 12-27-2018, 05:52 PM   #28
Gumshoe's Avatar
Trade: Painter
Rewards Points: 128
I'm doing a WHOLE house just like that right now. I have resorted to scraping with a carbide-bladed scraper to get the high points down to a manageable level. Then, I either use my orbital with 80 grit or my orbital vac attachment to sand it smooth. It has worked well, although I hate the scraping part. In retrospect, the family is re-doing much of the house so I should have talked them into replacing the ceilings with new sheetrock.
Gumshoe is offline
The Following User Says Thank You to Gumshoe For This Useful Post:
hdavis (12-27-2018)
Old 12-27-2018, 06:19 PM   #29
avenge's Avatar
Rewards Points: 130
Asbestos?
avenge is online now
Old 12-27-2018, 10:56 PM   #30
GC/carpenter
Calidecks's Avatar
Rewards Points: 4,104
Call a plasterer and have him darby it. Might need to set screed rails made of ply every so often.
Mike.
_______________
Calidecks is online now
Sir Mixalot (12-28-2018)
Old 12-27-2018, 11:00 PM   #31
GC/carpenter
Calidecks's Avatar
Mike.
_______________
Old 12-28-2018, 10:14 PM   #32
hdavis's Avatar
Mike.
_______________
He'll still need to cut extensions, etc., unless he gets it sanded down fairly low over most if it, and close to smooth around trim.
3/4 inch is a pretty thick plaster layer to be spreading, bucket mud is a nonstarter.
Sounds like the HO is paying for materials only, no labor.
Sometimes the best thing to do is just demo it out. It all depends on how long it would take to get everything sanded for a relatively thin skim coat, how good he is at skimming vs hanging and finishing, etc.
Old 12-28-2018, 10:19 PM   #33
GC/carpenter
Calidecks's Avatar
True but if the texture is already 3/4" what's there to lose? Coat as much as the high points?
Mike.
_______________
Old 12-28-2018, 10:35 PM   #34
hdavis's Avatar
Mike.
_______________
It's all picky details no matter how you go. I think if he knew how to use a darby, he would have already figured out his options instead of asking here. Most people don't seem to know plaster technique, but a lot of people can get through a drywall job.
In any event, this whole situation is why I say pay for all the materials and do the whole job for free, otherwise you're liable to be pushed in a stupid direction because it costs less in materials, even if it does nothing but burn time to get an inferior result.
Calidecks (12-28-2018)
Old 12-29-2018, 04:07 PM   #35
Take an oscillating tool to all the highest peaks and skim coat it!
-Paul
TextureMaster.com
The Following 2 Users Say Thank You to Sir Mixalot For This Useful Post:
Calidecks (12-29-2018), Rio (12-29-2018)
Old 02-12-2019, 08:33 PM   #36
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
So got here a little late, had a home the customer had textured his own walls and the texture was sharp and sticking out from the wall if you hit the wall with your fore arm you would bleed.
So I figure I got to sand it or skim it, I go to the local tool store and buy a Porter Cable pole sander and the discs also the vac that went with it, get back to the job have my guy go try out sanding the walls while I carry on installing siding, he comes out in after 15 minutes or so I say what's the story he say's its done !.
I go in the walls look great just like we gave them a orange peel texture, the home owner comes by later could not believe what a good job we had done, 15 minutes paid for that tool and vac
Still "Shakin" the tree boss
sunkist is offline
The Following User Says Thank You to sunkist For This Useful Post:
Idothat (02-12-2019)
Old 02-12-2019, 10:25 PM   #37
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 882
Iíve had my porter cable for years , I absolutely love it . Beats the heck out of hand sanding .
Idothat is online now
Wobbly shower wing wall Layinpipe Framing 0 02-25-2015 11:26 PM
Gable end wall pappagor Framing 33 04-20-2013 08:16 PM
Floor framing. Why put a joist under a non-loadbearing wall? Willin Architecture & Design 54 10-28-2012 08:21 PM
Restaurant Wall build?? lsgstexas Commercial Construction 1 10-17-2012 09:09 PM
Wet basement, just making sure my thoughts are correct HandicappedHome Excavation & Site Work 7 10-12-2012 06:17 AM
