Dangerous Wall Texture - Drywall - Contractor Talk
Old 12-26-2018, 02:22 PM   #1
Jmotre's Avatar
So, I have been tasked with removing the thickest crows foot texture on a wall I have ever seen. It’s ugly and obtrusive. Some of the higher peaks are probably 3/4 an inch. It’s borderline dangerous. Any tips would help. With how heavy it is and the fact it’s painted will definitely make sanding a joy.
Is the best I can do sand and skim until I have a smooth surface?
Part of me would like to rip off the drywall and start anew but that’s not really feasible. It is a pretty large living room.
Jmotre is offline
Old 12-26-2018, 02:53 PM   #2
hdavis's Avatar
Rewards Points: 4,028
Re: Dangerous Wall Texture
Put drywall over it, or tear it off and put up new.
hdavis is offline
Old 12-26-2018, 04:14 PM   #3
avenge's Avatar
Rewards Points: 660
How is new drywall not feasible compared to sanding, skimming, sanding, skimming, etc.? You wouldn't catch me doing anything but tearing it out.
avenge is online now
The Following 2 Users Say Thank You to avenge For This Useful Post:
hdavis (12-26-2018), onmywayup (12-28-2018)
Old 12-26-2018, 05:23 PM   #4
Designer/Contractor
Rio's Avatar
Rewards Points: 2,146
How hard is it? If it's not too hard maybe scrape it and go with a lighter texture?
Rio is online now
Old 12-26-2018, 05:27 PM   #5
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,333
Sometimes there is no choice--R & R
rescraft is offline
Old 12-26-2018, 06:53 PM   #6
Jmotre's Avatar
I guess it’s completely reasonable, but it’s for family and I don’t know if they would go for me demoing the living room. Since my time will be donated they’ll probably prefer the labor intensive choice...
Jmotre is offline
Old 12-26-2018, 06:55 PM   #7
Jmotre's Avatar
It’s incredible thick and solid, I doubt scraping will put a dent in it
It’s also so obtrusive I doubt going overtop with new will work well.
Jmotre is offline
Old 12-26-2018, 07:05 PM   #8
hdavis's Avatar
Buy yourself a couple of new shoulders to swap out, you'll need them.
hdavis is offline
Old 12-26-2018, 07:09 PM   #9
hdavis's Avatar
Originally Posted by Jmotre View Post
Itís incredible thick and solid, I doubt scraping will put a dent in it
Itís also so obtrusive I doubt going overtop with new will work well.
You only have to mostly clear some tracks for furring to sit in. Lay out your grid, and knock the peaks off where the furring strips will go. If you want, you can bed them in hot mud.
Then hang the ceiling.
hdavis is offline
Old 12-26-2018, 07:14 PM   #10
hdavis's Avatar
Do yourself a favor, donate your time and the materials, then do it the fast and easy way. It's a lot better deal for you.
No way would I skim that, and I skim darn near anything.
hdavis is offline
Old 12-26-2018, 07:28 PM   #11
Jmotre's Avatar
Aaaaaahhhh brilliant. I never thought about furring strips.... appreciate it!
Jmotre is offline
The Following User Says Thank You to Jmotre For This Useful Post:
hdavis (12-26-2018)
Old 12-26-2018, 07:40 PM   #12
hdavis's Avatar
Trust me, I didn't invent this approach.
hdavis is offline
Old 12-26-2018, 07:46 PM   #13
avenge's Avatar
Rewards Points: 660
I usually refrain from covering with or without furring because there's windows and jambs that need to be built out.
The Following User Says Thank You to avenge For This Useful Post:
Rio (12-26-2018)
Old 12-26-2018, 09:17 PM   #14
Designer/Contractor
Rio's Avatar
And outlets
Rio is online now
Old 12-26-2018, 09:43 PM   #15
hdavis's Avatar
Originally Posted by Rio View Post
And outlets
Moving boxes can be a pain. I don't think twice sbout building out.
hdavis is offline
Old 12-26-2018, 09:50 PM   #16
Jmotre's Avatar
Yea I was thinking about that.
One window, few outlets. I was figuring out my plan of attack... still probably less labor than full strip
Jmotre is offline
hdavis (12-26-2018)
Old 12-26-2018, 09:52 PM   #17
Jmotre's Avatar
Couple doorways and a big archway tho... could be problematic
But It think can be done
Jmotre is offline
Old 12-26-2018, 09:54 PM   #18
tjbnwi's Avatar
Rewards Points: 3,892
Planex connected to a CT36AC.
tjbnwi is online now
Old 12-26-2018, 10:28 PM   #19
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 6,330
You can sand a lot with 36 grit and a rotax type sander (that spins, no just random orbit)
How big is the wall? Lucky it's not a ceiling.
I've sanded down some pretty heavy textures. Then 45 or 90 minute hot mud power mixed in a bucket, a bag at a time for at least the first skim coat.
Golden view is offline
The Following 2 Users Say Thank You to Golden view For This Useful Post:
Rio (12-27-2018), ScipioAfricanus (12-27-2018)
Old 12-26-2018, 10:42 PM   #20
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,520
And outlets
Thatís the easy part.
https://www.menards.com/main/electri...4444952247.htm
Big Johnson is online now
The Following 3 Users Say Thank You to Big Johnson For This Useful Post:
artinall (12-27-2018), Rio (12-27-2018), Seven-Delta-FortyOne (12-26-2018)
Wobbly shower wing wall Layinpipe Framing 0 02-25-2015 11:26 PM
Gable end wall pappagor Framing 33 04-20-2013 08:16 PM
Floor framing. Why put a joist under a non-loadbearing wall? Willin Architecture & Design 54 10-28-2012 08:21 PM
Restaurant Wall build?? lsgstexas Commercial Construction 1 10-17-2012 09:09 PM
Wet basement, just making sure my thoughts are correct HandicappedHome Excavation & Site Work 7 10-12-2012 06:17 AM
