Curved Drywall - Drywall - Contractor Talk
Curved Drywall
Old 01-28-2008, 02:01 PM   #1
oesd's Avatar
Curved Drywall
Am trying to design/build a curved drywall in a bathroom. Is a 32 inch radius too small to use on the inside curve? Any help would be greatly appreciated!
Mike
oesd is offline
Old 01-28-2008, 02:04 PM   #2
Fentoozler
Celtic's Avatar
Rewards Points: 2,000
Re: Curved Drywall
You may find using 1/4" board(double, triple, quad ~ whatever you need to buildup the wall to spec), lightly misted with water, and left to dry over a similar shaped 32" radius object will help.
Celtic is offline
Old 01-28-2008, 02:05 PM   #3
SelfContract's Avatar
Re: Curved Drywall
In the books, I can see they can bend 1/4 inch drywalll sheet easy for small curves, but I dunno where do they sell it anymore? For Vertical curves I use studs to form shape, and Horizontal/small curves, I need to buy that 1/4 inch.
SelfContract is offline
Old 01-28-2008, 02:44 PM   #4
Remodeling GC
kevjob's Avatar
Rewards Points: 392
Re: Curved Drywall
we use 1/4 inch in two layers for walls and arches etc.. usually we build it out of 2x4 and 1/2 inch osb for lots of backing.
only place that sells 1/4 is drywall supply companys most will have access to it.
kevjob is offline
Old 01-28-2008, 03:41 PM   #5
Al Smith
A W Smith's Avatar
Rewards Points: 1,000
Re: Curved Drywall
Jafco right there in South Plainfield has 1/4 inch drywall
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 01-28-2008, 03:52 PM   #6
Thumbs up
Re: Curved Drywall
Thank you for the good link, appeciate much! I live in VA-MD area.
Old 01-28-2008, 08:02 PM   #7
charlesmd's Avatar
Trade: Baths, basements, carpentry, int.remodeling
Rewards Points: 150
Re: Curved Drywall
Is this what your looking for??????
charlesmd is offline
Old 01-28-2008, 08:14 PM   #8
Professional Instigator
rbsremodeling's Avatar
Re: Curved Drywall
I might be misreading the post but we score the back of the drywall and use a sponge and wet the back leave it over night till it curves
rbsremodeling is offline
Old 01-28-2008, 08:19 PM   #9
Fentoozler
Celtic's Avatar
Re: Curved Drywall
Does slicing it on the back degrade it's fire rating?
Celtic is offline
Old 01-28-2008, 08:20 PM   #10
Re: Curved Drywall
Honestly I don't know. I never thought of that.
Old 01-28-2008, 08:24 PM   #11
Fentoozler
Celtic's Avatar
Re: Curved Drywall
W/O even looking for UL standards and getting "all technical" ~ I'm going to say YES.
On the bright side...a board half the size needed might cost a nickel more, but you make it up on labor from not having to go all Samurai on the full size board
Celtic is offline
Old 01-28-2008, 08:29 PM   #12
Re: Curved Drywall
slice it on the front and sponge it down??
Old 01-28-2008, 08:31 PM   #13
Fentoozler
Celtic's Avatar
Re: Curved Drywall
NO slicing....let the water work it's magic.
Celtic is offline
The Following 2 Users Say Thank You to Celtic For This Useful Post:
Ancient Rocker (09-26-2013), tenon0774 (09-28-2013)
Old 01-28-2008, 08:31 PM   #14
FramingFanatic's Avatar
Trade: Framing
Rewards Points: 77
Re: Curved Drywall
Build the wall straight next time? Thats why they have straight lines.
FramingFanatic is offline
The Following User Says Thank You to FramingFanatic For This Useful Post:
Old 01-28-2008, 08:33 PM   #15
Re: Curved Drywall
look I own a 75 dollar sheet rock knife I am slicing something
The Following User Says Thank You to rbsremodeling For This Useful Post:
Willie T (09-12-2010)
Old 01-28-2008, 08:34 PM   #16
Fentoozler
Celtic's Avatar
Re: Curved Drywall
LMAO
Celtic is offline
Old 01-28-2008, 08:38 PM   #17
Fentoozler
Celtic's Avatar
Re: Curved Drywall
Think outside the "box"...
Here's a visual aid:
This ceiling only has a mild barrel to it...might not even need water.
This one is a bit more intense:
How about some rock on this?
Celtic is offline
Old 01-28-2008, 08:40 PM   #18
Re: Curved Drywall
Seriously I never thought about the fire rating. Its funny how we use all these tricks and never think about the consequences. I will honestly think through some of the stuff I do now
Old 01-28-2008, 08:43 PM   #19
Fentoozler
Celtic's Avatar
Re: Curved Drywall
Just don't think too hard....we don't want you to break in that $75 knife on your own wrists
Celtic is offline
Old 01-28-2008, 08:45 PM   #20
Re: Curved Drywall
brb gonna drink another vodka cranberry and come back with a witty response to that
Lots of questions about drywall and bathrooms nobody Drywall 30 11-27-2008 01:33 PM
electrician seeks drywall help (pictures inclided) filburn Drywall 2 01-21-2008 06:58 PM
Breaking into the commercial drywall work dryrocker27 Commercial Construction 8 12-11-2007 06:48 PM
Framing for drywall under a curved staircase PABLOPICASSO46 Framing 1 09-15-2007 04:00 PM
Cutting in curved drywall edges aoc Painting & Finish Work 4 02-20-2006 07:55 AM
