Cracks In Plaster And Drywall - Drywall - Contractor Talk
Old 07-22-2012, 05:36 PM   #1
6stringmason's Avatar
Trade: masonry
Rewards Points: 1,136
Im wondering if anyone could give me some insight into why these cracks appeared in the plaster, and a couple appear to be through the drywall, I assume these are all on a joint.
This house is mid 80's, all 2x8 outer wall construction, and seems to be in pretty good shape.
All the windows near where the cracks are open and close fine with no sticking so I ruled out settling?
This one is between an upper and lower window.
This is a clear story wall.
Kamps Masonry 920-680-3195
https://www.facebook.com/pages/Kamps...31566206923069
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline
Old 07-22-2012, 05:42 PM   #2
mbryan's Avatar
Trade: Ministry
Rewards Points: 568
Re: Cracks In Plaster And Drywall
Water?
mbryan is offline
Old 07-22-2012, 05:49 PM   #3
Trade: masonry
WOuldnt there be other signs of water damage? Like the ceiling above the bump out wall, and stains in the other areas?
Visit our website @
Old 07-22-2012, 06:16 PM   #4
mbryan's Avatar
Trade: Ministry
Rewards Points: 568
Plants on shelf?
Slow leak in window?
mbryan is offline
Old 07-23-2012, 04:40 AM   #5
Big Shoe's Avatar
Rewards Points: 2,122
Little shelf wall looks like too much mud and shrinking, sorta?
Clear wall crack, unavoidable.
Between windows, Looks like movement of some sort but would not rule out water,open it up and see.
Good luck
Expect the Unexpected
Big Shoe is offline
Old 07-23-2012, 07:38 AM   #6
hdavis's Avatar
Rewards Points: 1,952
Looks like movement to me. Mesh is really weak in shear, and it looks like the little shelf and below the window are having shear problems. The clear story is expected and looks normal.
hdavis is online now
Old 07-28-2012, 11:42 PM   #7
Tim@nuroom's Avatar
Trade: Kitchen,Bath & Basement
I've seen similar damage to drywall attached to double studs and double top plates. In my experience too many screws and or liquid nails on adjoining double studs or double plates won't allow the lumber to move when it soaks up moisture in the summer months. Since two pieces of wood will move at different rates, if the drywall is attached to both adjoining pieces the result is cracked drywall. Your pics look like recent foundation movement.
Tim@nuroom is offline
Old 07-29-2012, 07:12 PM   #8
dryrocker27's Avatar
Trade: Drywall Contractor
Rewards Points: 75
We work on custom homes with similar features that are pictured. Builders and designers do not calculate how load is transferred down to the foundation in these big open contemporary designs. What you are dealing with is stress load and compression. When we encounter this, we remove busted drywall, replace with new material leaving a 1/8" gap all around. Make needed repairs and tell owner that this may return. Call me if you need to. Structure will eventually adjust to load. May take up to 5 years to settle on some of the homes.
Robert
dryrocker27 is offline
Old 08-05-2012, 06:11 PM   #9
Spike7's Avatar
Trade: interior/exterior
Rewards Points: 402
yeah , sounds like settling
check the headers on some of the doorways and see if they are out of square , or if there are signs the floor as settled .
Spike7 is offline
Old 08-11-2012, 08:25 PM   #10
bluntman001's Avatar
Trade: Taper
Looks like seetling to me also, could be the mix that was used when they did the home, could of been a bad batch ...
Drywall In Camrose
bluntman001 is offline
Drywall Over Plaster Lath oldhouses Drywall 37 04-04-2012 10:17 AM
Veneer plaster and drywall comparo UpNorth Drywall 7 12-14-2011 11:29 AM
Drywall over plaster ceiling? RandyB1986 Drywall 34 11-29-2011 05:09 PM
Lead testing on drywall and plaster hammerz_nailz General Discussion 10 06-15-2010 11:48 PM
Drywall vs Plaster 8Frank8 Drywall 12 11-17-2009 06:03 AM
