Crack At Peak In Vaulted Ceiling - Page 2 - Drywall - Contractor Talk
Old 10-30-2013, 06:26 PM   #21
Hamatin's Avatar
Trade: Blueboarder.Sheetrocker.metal framer all around beast
Re: Crack At Peak In Vaulted Ceiling
try putting a piece of metal corner bead in the angel or bend metal lathe in in the angle and screw it down before hanging your board. I had the same problem doing houses and then having the heat come on later. It worked for me.
Hamatin is offline
Old 11-04-2013, 09:44 AM   #22
icerock drywall's Avatar
Trade: drywaller
Rewards Points: 930
I did this the other day to a spot that had a crack and its very strong...trimtex glue with fibafuse ..it turns the fibers into like rubber ...the seam will stretch but not crack apart
dont work hard...work smart
icerock drywall is offline
The Following 2 Users Say Thank You to icerock drywall For This Useful Post:
Sir Mixalot (11-04-2013), ToolNut (11-04-2013)
installing a Hunter ceiling fan on a concrete ceiling dale rex Electrical 24 07-17-2012 06:12 PM
Why did this crack? KennMacMoragh Drywall 24 07-15-2012 01:20 AM
Hairline crack on ceiling jhammer7 Drywall 2 05-06-2012 08:10 AM
Dianosing Water Spots on Vaulted Ceiling OuchMyThumb General Discussion 2 07-15-2010 11:35 AM
Barrel vaulted ceiling summertime Framing 10 04-14-2007 04:47 PM
