Ceiling Texture Mix Recipe's - Drywall - Contractor Talk
Old 12-08-2010, 10:46 AM   #1
Construction Connoissuer
CCCo.'s Avatar
Trade: Construction Remodeling - Renovations Repairs
Location: Kirklin, IN "Proudly Serving Central Indiana Area"
Rewards Points: 1,320
Alright, I'll share.
So you want to do some ceiling texture, and you don't know where to start.
You may or may not have tried it before, but if you have, you know the results can be a little intimidating.
Sorry bad pics, poor lighting,........I might put up new ones, but for now.
My samples, I spent an afternoon mixing different recipes of compound.
I quickly found, it took a lot of thining to get where I wanted.
Here is the four boards I ran out.
Test board #1..Pretty thick, unpredicatable, and hard to maintain pattern.
Test board #2..A little better, but not what I wanted yet.
Test board #3..Just about right.
Mix: 5 gal. of compound, 1 Qt. of water, and 2 Qt. of paint.
Test board #4...a little thinner than I wanted, but still excellent results.
Mix: 5 gal. of compound, 2 Qt. of water, and 2 Qt. of paint.
James Crow - Crow Contracting Company, LLC - Central Indiana Remodeling Contractor
Facebook l Youtube l Merchant Circle
Home, Kitchen & Bath Remodeling - ~ - Facility Maintenance & Repair Solutions
Want to contact us? - Call ~ 765.279.8271
CCCo. is offline
Old 12-08-2010, 10:47 AM   #2
CCCo.'s Avatar
Re: Ceiling Texture Mix Recipe's
The customer and I agree'd that 3 was the magic number.
I placed these samples at there house overnight, and let them choose.
CCCo. is offline
Old 12-08-2010, 11:03 AM   #3
tcleve4911's Avatar
Trade: Remodeling contractor
Rewards Points: 1,008
Thanks for taking the time Mr Crow
This helps a lot
Your texturing is the Brush/Dab system, no?
Can you do a 12" swirl?..............
[IMG][/IMG]
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 12-08-2010, 11:06 AM   #4
CCCo.'s Avatar
Mines the stomp, I haven't done a swirl, but I would try it.
I think the mixes should be about the same, just applied with different methods.
If you get the mix right, I think it will come out ok, especially in a corner.
CCCo. is offline
Old 12-08-2010, 11:07 AM   #5
CCCo.'s Avatar
I roll mine on, then stomp.
I think you could roll, then swoop.
Me, I'd start at 3, and see if you think it needs to be thinner.
CCCo. is offline
Old 12-08-2010, 11:13 AM   #6
tcleve4911's Avatar
Somewhere I missed the 3..4...part.
What is that referring to?
EDIT....Is that the sample board numbers?
Back in Maine
Dubbin' Around
Old 12-08-2010, 11:26 AM   #7
CCCo.'s Avatar
Sorry, Yes sample board numbers.
CCCo. is offline
Old 12-08-2010, 11:40 AM   #8
tcleve4911's Avatar
Nice work...........and thanks again.
I'm headed over to play with this stuff now.
Things I've learned...
Thin the mud with water - paint after
Roll on with 1" nap- swirl away
Test samples
Wallpaper brush
Low room temp - dries slower - longer working time
I'll post some pics.....IF it comes out good......
Back in Maine
Dubbin' Around
The Following User Says Thank You to tcleve4911 For This Useful Post:
CCCo. (12-08-2010)
Old 12-08-2010, 11:42 AM   #9
CCCo.'s Avatar
One more for your list, go a little heavier than what you think you need,
Cause it will likely shrink up to what you want, even if you think its a little too heavy.
I just was trying to give you some starting points, obviously different muds may have different moisture content,
soo its play time.
CCCo. is offline
Old 12-08-2010, 02:37 PM   #10
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 4,232
Looks good Crow nice pattern, Light touch, not too hevy, I know when I started doing ceilings with my friends OMG my sholder was shot at the end of Lunch. So i ended up doing clean up - after doing this for the summer I looked like Popeye
The Following User Says Thank You to Snobnd For This Useful Post: Leo
Snobnd is online now
CCCo. (12-09-2010)
Old 12-09-2010, 12:18 PM   #11
CCCo.'s Avatar
I hope no news, is good news......
CCCo. is offline
Old 12-09-2010, 04:51 PM   #12
tcleve4911's Avatar
I know, I know........
I had to make a repair and tape some bad corners before I can start the Creative Crowing Art Work.......
Back in Maine
Dubbin' Around
CCCo. (12-09-2010)
Tags
ceiling texture mixtures , ceiling texture repairs , crow contracting company , drywall repairs ceiling , indianapolis contractor
Popcorn Texture over Concrete AM1965 Drywall 14 04-15-2010 10:51 AM
Knockdown Texture Patch - Flashing? mseneker Drywall 7 05-18-2009 11:47 AM
Ceiling texture fun!! EricTheHandyman Drywall 2 04-01-2009 09:14 PM
Prime and Texture over painted splatter ceiling texture AARC Drywall Drywall 2 03-13-2009 07:53 PM
ceiling texture - small question andrewjoseph Drywall 6 02-13-2009 08:04 PM
