Best Mud Drywall To Plaster - Drywall - Contractor Talk
Old 01-27-2016, 08:16 PM   #1
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Decks, Additions
Rewards Points: 15,178
So I am going to frame a ceiling in a room with plaster walls. What kind of mud works the best where the ceiling meets the walls or does it matter?
I will be framing at the same height where the acoustic drop ceiling was at
A&E Exteriors is online now
Old 01-27-2016, 08:23 PM   #2
House surgeon
illbuildit.dd's Avatar
Trade: building/remodeling
Rewards Points: 2,078
Re: Best Mud Drywall To Plaster
Hot mud. its strong and hard like an oak tree
illbuildit.dd is offline
The Following User Says Thank You to illbuildit.dd For This Useful Post:
A&E Exteriors (01-27-2016)
Old 01-28-2016, 01:09 AM   #3
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Yup, 20 minute USG hot mud.
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
The Following User Says Thank You to m1911 For This Useful Post:
A&E Exteriors (01-28-2016)
Old 01-28-2016, 07:20 PM   #4
Windwash
Windwash's Avatar
Rewards Points: 148
Durabond hot mud, not easy sand for tape coat.
What is the reason for framing it down? In the pics it looks like a good candidate for an overlay of 1/2" or 5/8" with 2" screws. By the time the wall /ceiling intersection is taped/finish coated you will be down to the ceiling grid line.
Windwash is offline
The Following 2 Users Say Thank You to Windwash For This Useful Post:
A&E Exteriors (01-28-2016), asgoodasdead (02-08-2016)
Old 01-28-2016, 07:29 PM   #5
The existing ceiling is no where near flat. I was going to drop the plaster (that wasn't already falling) but it will be a much nicer finished product if I just frame a 2x6 ceiling
Old 01-28-2016, 07:34 PM   #6
Finished Celing will be flirting with 8'
Old 01-28-2016, 08:18 PM   #7
gbruzze1's Avatar
Rewards Points: 2,608
Why 2x6? In the past I've done this by running a 2x4 metal track across the perimeter and then using 2x4 metal stud for the joists. If span is too long you could hang a 2x4 from the original ceiling joists to the new metal studs at the middle to take out any sag.
Metal stud makes for an easy job to do with 1 person and a magnetic level
Gary
gbruzze1 is offline
The Following 4 Users Say Thank You to gbruzze1 For This Useful Post:
aptpupil (01-30-2016), asevereid (01-28-2016), asgoodasdead (02-08-2016), OVContractor (02-17-2016)
Old 01-28-2016, 08:33 PM   #8
That would definatley work. Longest span is 11'. I'm just used to using wood so it is my first thought. Did 2 rooms in my basement like this. (Double wide on a basement, so we couldn't put a lid on the bottom of the floor joists )
Old 01-29-2016, 05:33 AM   #9
Big Shoe's Avatar
Rewards Points: 2,122
First, metal studs are 3-5/8'' and second you could frame that with 1-5/8''studs too, if max height is needed.
And, A&E. I don't exactly understand your question.
Expect the Unexpected
Big Shoe is offline
Old 01-29-2016, 09:00 AM   #10
thezoo's Avatar
Rewards Points: 238
Just doing a bath, it had been redone in the 80s, I am sure they used greentop, couldn't tell. Current owners been there almost 40yrs. My replairs were done with durabond for taping, easysand to feather, greentop or easy to finish. We built a wall and fixed the poor patches from previous (water damage from vent pipe over many years and recessed medicine cab).
The smaller the room, the worse the plaster waves, lol.
thezoo is offline
The Following User Says Thank You to thezoo For This Useful Post:
A&E Exteriors (01-29-2016)
Old 01-29-2016, 09:04 AM   #11
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 350
Chalk line the joist and 5/8 over It. That's the cheapest way out.
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
The Following 2 Users Say Thank You to blacktop For This Useful Post:
A&E Exteriors (01-29-2016), hdavis (01-29-2016)
Old 01-29-2016, 05:30 PM   #12
Ceiling has way to big of a sway in it for my liking, pic really doesn't do it justice. It would probably take longer to locate all the joists than it will to frame a new ceiling.
The Following User Says Thank You to A&E Exteriors For This Useful Post:
blacktop (01-29-2016)
Old 01-29-2016, 05:30 PM   #13
I did think about that already though!
Old 01-29-2016, 05:33 PM   #14
I was just curious as to the preferred product for this situation for the best results.
Old 01-29-2016, 06:39 PM   #15
hdavis's Avatar
Rewards Points: 1,316
I use AP over plaster, or an admix if I'm using hot mud. You have to make sure it's going to stick to the plaster.
hdavis is online now
Old 01-29-2016, 06:40 PM   #16
Should I ask paper or mesh? Lol
Old 01-29-2016, 06:53 PM   #17
hdavis's Avatar
FibaFuse
Old 01-29-2016, 07:13 PM   #18
Lmao!!
hdavis (01-29-2016)
Old 01-29-2016, 07:37 PM   #19
Drywall Slave
blacktop's Avatar
Rewards Points: 350
Lmao!!
Yeah me too!
blacktop is offline
The Following User Says Thank You to blacktop For This Useful Post:
Old 01-29-2016, 09:51 PM   #20
Randy Lahey
NYC_Line7's Avatar
Trade: Construction Management/Latherer/Civil Engineer
Rewards Points: 146
Gary
With that same logic, you can use 2x2's, I've done it before, you just have to install a couple more hangers.
NYC_Line7 is offline
The Following User Says Thank You to NYC_Line7 For This Useful Post:
gbruzze1 (01-29-2016)
Drywall over plaster DavHomeServ Drywall 9 04-02-2015 09:35 PM
Drywall Subcontractor NJ LouCHI Help Wanted or Looking For Work 0 08-08-2012 06:40 AM
Laminating drywall over plaster Frankawitz Drywall 13 10-13-2009 06:09 AM
Hanging Drywall on Cement or Plaster jlscas Drywall 2 02-20-2006 02:06 PM
drywall over interior plaster/ brick walls n8sr Drywall 10 11-10-2005 10:18 PM
