Best Method For Small Patch - Drywall - Contractor Talk
Old 02-07-2013, 08:03 PM   #1
Git R Done
DemRem's Avatar
Rewards Points: 202
I typically only do patch work. Recently I had a few small jobs and it got me thinking what is the best method for a small patch.
I think the main factor I have problems with is drying time.
I've been using 20 for patches but find I'm still standing around waiting for it to dry. The problem seems worse when I have a large gap to fill or using paper tape (meaning that I think it's a good idea to let paper completely completely dry before re-coating which takes more time). But I don't really like fiberglass tape because of frays and the fact that it takes a thicker top coat and shows so easily if you sand too far.
DemRem is offline
Old 02-07-2013, 08:06 PM   #2
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,040
Re: Best Method For Small Patch
Ever used the 5-minute hot mud.
I never have, it scares me.
Old 02-07-2013, 08:07 PM   #3
Git R Done
DemRem's Avatar
Rewards Points: 202
I think pre-mixed usually leaves a much better finish coat but again it has to dry overnight. I'd like to be able to do a patch without making two trips but maybe I should just count on two trips.
What about using 5 instead of 20? Also, keep in mind that a patch is fresh drywall to painted surface and I've heard paint causes pin-holes for whatever reason? I personally haven't noticed it too much but obviously a painted surface is a much different surface than a drywall sheet.
DemRem is offline
Old 02-07-2013, 08:09 PM   #4
Git R Done
DemRem's Avatar
Rewards Points: 202
Never so I don't even know what it's like, but I can imagine it would really mess up your adhesion if it skins over too quick
DemRem is offline
Old 02-07-2013, 09:14 PM   #5
Commercial Contractor
Mud Master's Avatar
Trade: Commercial General Contractor
Rewards Points: 1,000
Install a blow out patch
Mix your 20 with warm water and use a heat gun to accelerate drying time.
Scrap excess mud, 2nd coat of 20. Same steps as before
Sand, 3rd coat
Sand, clean, paint, leave.
Should be 3-4 hours at MOST. If you only have one patch mix your mud a little tighter.
As for painted surfaces causing air holes. Sand the surrounding surface first. For a semi or high gloss you may have to skim the area first.
Originally Posted by katoman View Post
And when the day is done, I can look myself in the mirror, with pride, and say " you're a craftsman, well done. "
Mud Master is offline
The Following 4 Users Say Thank You to Mud Master For This Useful Post:
CarpenterSFO (02-14-2013), thom (02-08-2013), Wile E Coyote (02-26-2013)
Old 02-07-2013, 10:14 PM   #6
Git R Done
DemRem's Avatar
Rewards Points: 202
Sand, 3rd coat
I should have said by small that I meant like 2-4' square so blowout patch wouldn't work and also kind of tedious to use a heat gun on a 3' seam but still doable I suppose. I do think your heat gun and blowout patch method would be perfect for a door knob hole and things like that.
DemRem is offline
Old 02-07-2013, 10:30 PM   #7
Santa's Helpers's Avatar
Trade: Repair and remodeling
Rewards Points: 97
we do these patches all the time. If it is a large area, use 20 for the first coat. Dry with a heat gun and repeat with 5. Our HD carries 5 min mud. As said before. We can do a 3' x 3' repair in 3-5 hours including texture and paint. We use the oil based rattle can for orange peel or knockdown.
Popcorn we spray with a hopper and may have to make a second trip to paint the following day.
Comcast is a repeat customer. Lots of ceilings that get stepped on or holes that miss the top plate and come through the wall
Santa's Helpers is offline
Old 02-07-2013, 10:59 PM   #8
kambrooks's Avatar
Rewards Points: 572
I run a $30 space heater
Kameron Brooks
www.iFixHomeImprovement.com
kambrooks is offline
The Following User Says Thank You to kambrooks For This Useful Post:
Henn Drywall (02-16-2013)
Old 02-07-2013, 11:08 PM   #9
Git R Done
DemRem's Avatar
Rewards Points: 202
Just curious do you use the 20 first because you figure the 1st coat takes the longest and the 5 can be used on the 2nd coat
I think I'm closer to the 5hr mark and maybe another 45 to paint
It seems like quite a few drywallers on here aren't too fond of the 5 min mud but Im not sure why...maybe someone can elaborate. The only thing I can think of is the high risk of it skinning over too quickly
DemRem is offline
Old 02-07-2013, 11:10 PM   #10
Git R Done
DemRem's Avatar
Rewards Points: 202
I did that on a job this week but sometimes it's hard to position them right...I figured a heat gun would be too tedious for a larger patch but it sounds like a lot of people are using them so I'll give mine a try
DemRem is offline
Old 02-07-2013, 11:21 PM   #11
Red Adobe's Avatar
Trade: Metal Roofs, Sparky , Remodels and beer specialist
Rewards Points: 92
if you mix 5 min and 20 do you get 12 n1/2?
An old guy taught me to cut out a square say 6" x6' put a couple 1/4s in the wall then score the back of the new rock 6x6 and the paper side 10x10 and break from the back and peel leaving the white paper.
Apply a thin layer around patch screw in the new and then float. (this is easier then taping a patch and only a thin coat is needed to blend in, stick a fan on it for 20 mins then texture, another 20 and paint.
6" hole saws work real nice as well, cut the bad out and back of rock then paper side to a square
Red Adobe is offline
Old 02-07-2013, 11:28 PM   #12
kambrooks's Avatar
Rewards Points: 572
A gun and an oscillating tower... Works great. I don't do many patches anymore but it was great when I did
Kameron Brooks
Old 02-07-2013, 11:30 PM   #13
kambrooks's Avatar
Rewards Points: 572
Ferguson recommends that in his books. I liked the idea, never tried it
Kameron Brooks
Greg from K/W (03-06-2013)
Old 02-08-2013, 12:12 AM   #14
B.D.R.'s Avatar
Trade: renovation carpenter
Rewards Points: 1,990
I'll second or third or whatever the heat gun. It works great.
I've done the scored drywall patch as well but find that the paper is too thick for my liking.
Lined notebook paper is nice and thin, you just have to be careful not too over work it.
H*ll news paper in a pinch.
B.D.R. is offline
Old 02-08-2013, 12:14 AM   #15
skillman's Avatar
Rewards Points: 1,968
I cut blow out patch's for small holes . Then use fast setting compounds . My two cents .
skillman is offline
Old 02-08-2013, 11:30 AM   #16
FineLineBill's Avatar
Trade: General Contactor
mix your 20 with a paddle or your wifes egg beater in your cordless, the heat created by using a power tool will help the mud set fast, but not too fast, two coats of that followed by a top coat of premixed and a heat gun will get it. An old timer showed me a trick for eliminating air bubbles...add a little liquid dish soap and mix well, makes a nice creamy skimming mud that doesnt leave any air bubbles.
FineLineBill is offline
Old 02-09-2013, 11:11 AM   #17
profinish's Avatar
Trade: painting and drywall
Rewards Points: 75
Wow 5 at HD?
Not around here and the paint stores will rape you!! LOL
Was looking over reciepts awhile back SW Dinged me $22 For a bag of 5
Brought it up they made it right but im just sayin..
I had bought like 40 gals of paint at same time so I didnt catch it till later. Ive never found 5 at HD or Lowes
Anyway a patch is a patch, takes time somtimes, mix a little tighter use your heat gun..
profinish is offline
Old 02-10-2013, 06:27 AM   #18
Big Shoe's Avatar
Rewards Points: 2,070
Sorry, but....................20 and paper..............mesh and frays..............sanding??????
Eliminate those three problems and you will be a happy camper
Also, High velocity fans will make your twenty dry in twenty.
Expect the Unexpected
Big Shoe is offline
The Following User Says Thank You to Big Shoe For This Useful Post:
icerock drywall (02-14-2013)
Old 02-14-2013, 09:14 PM   #19
icerock drywall's Avatar
Trade: drywaller
Rewards Points: 930
Originally Posted by mud master View Post
install a blow out patch
mix your 20 with warm water and use a heat gun to accelerate drying time.
sand, 3rd coat
sand, clean, paint, leave.
Should be 3-4 hours at most. If you only have one patch mix your mud a little tighter.
same for me but i dond sand it and i like to fuse it not tape it
dont work hard...work smart
icerock drywall is offline
Old 02-16-2013, 09:32 AM   #20
Henn Drywall's Avatar
Trade: Drywall
Rewards Points: 25
It's called a Cali patch.......it works good for patchwork. Did about 500 of them on the job im at now.
Henn Drywall is offline
"Quick" drywall patch robert c1 Drywall 23 01-23-2013 06:10 PM
DIY knockdown patch Cole82 General Discussion 9 05-27-2012 11:44 PM
wallboard patch on plaster artinall Drywall 0 05-21-2012 04:20 PM
Knockdown Texture Patch - Flashing? mseneker Drywall 7 05-18-2009 11:47 AM
