Best Method - Cutting Holes In Plaster Ceiling For Can Lights... - Drywall - Contractor Talk
Old 04-09-2014, 07:24 PM   #1
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
What tool works best for cutting out circle holes in plaster ceiling for can lights?
Spencer is offline
Old 04-09-2014, 07:39 PM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,298
Re: Best Method - Cutting Holes In Plaster Ceiling For Can Lights...
Carbide grit holesaw, it will last you a lifetime. If I have a lot to cut I will burn through the plaster with the carbide grit, then cut through the wood lath with a regular hole saw.
Or buy a case of regular hole saws because lime plaster will murder them.
Inner10 is online now
Old 04-09-2014, 07:41 PM   #3
PoleBarnsNY's Avatar
Trade: Pole Barn Builder
Rewards Points: 1,419
Abrasive grit hole saw
PoleBarnsNY is offline
Old 04-09-2014, 07:41 PM   #4
Dan_Watson's Avatar
Rewards Points: 2,710
What they said.
Dan_Watson is online now
Old 04-09-2014, 07:44 PM   #5
Home Repairs
D.E.P.S.'s Avatar
Trade: Home Improvement
Rewards Points: 424
Plaster drywall or plaster over old lathe? The old lathe system hates vibrations, so you might want to use a spiral cutter after making a pilot hole. You can pretty much write off the bit afterwards. If it is on a newer drywall type substrate, you can use whatever you like if you do it neatly.
A hole saw would be fine for a newer system, but could possibly create a problem on old plaster lathe ceilings because you never really know how loose the plaster is to the lathe.
D.E.P.S. is offline
Old 04-09-2014, 07:45 PM   #6
Inner10's Avatar
I should also add that the cheap one don't appear to be much different than the expensive ones. Mine's a Greenlee but I picked up a MasterCraft set for 20 bucks and it works fine.
Old 04-09-2014, 07:50 PM   #7
rrk's Avatar
Rewards Points: 2,120
Drill a small hole in the center of where you think you want the light and use a wire thru the hole to check for pipes/joists. Easier to patch small hole than 6" hole.
rrk is online now
Old 04-09-2014, 07:52 PM   #8
Never tried a roto zip or multi master but they might be distant runners up with an abrasive grit bit.
The reason the hole saw works the best is these other tools get hung up on the lathe and crack the plaster and then your are going to be late for dinner patching that mess.
Jig saw with abrasive blade would be fun to watch. It sounds like a total nightmare. LOL.
If you go with the hole saw with abrasive grit It might be worth switching from an abrasive grit saw to a wood hole saw that is the same size once you are thru the plaster down to the lathe.
Agree with RRK above that you want to be sure there are no obstructions where you want to insert the recessed fixture canister. Often there is framing, wiring or pipes in the way where you want to install it.
Old 04-09-2014, 08:01 PM   #9
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 3,431
Morse Recessed Lighting Hole Saw (Tungsten carbide grit)
http://www.mkmorse.com/products/index.aspx?product=21
-Paul
TextureMaster.com
Checkout my YouTube Channel with 53,000 Subscribers and over 9,500,000 Views
https://www.youtube.com/paulpeck
Twitter Facebook Google+ Instagram
Sir Mixalot is offline
Old 04-10-2014, 06:00 AM   #10
Livin the dream...
Spencer's Avatar
Thanks for all the advice. Got the answers I was looking for. Sounds like I need to invest in a carbide grit hole saw for cans...
Spencer is offline
Old 04-10-2014, 06:20 AM   #11
Inner10's Avatar
I have an acquaintance who owns an electrical company and buys Dewalt hole saws by the case and throws them out as they get dull.
Old 04-10-2014, 08:31 AM   #12
Stoneyard's Avatar
Trade: Journeyman Carpenter
Rewards Points: 249
http://www.tlc-direct.co.uk/Products/FXDADE.html
http://www.holepro.com/electrical.html
Seen an electrician use these, pretty slick set up.
Stoneyard is offline
Old 04-10-2014, 11:14 AM   #13
Inner10's Avatar
Originally Posted by Stoneyard View Post
The adjustable hole cutter is as useful as tits on a bull for plaster.
The Following 3 Users Say Thank You to Inner10 For This Useful Post:
Ancient Rocker (04-10-2014), Dan_Watson (04-10-2014), m1911 (04-10-2014)
Old 04-10-2014, 12:48 PM   #14
Stoneyard's Avatar
Rewards Points: 249
Try a different bit, its not brain surgery...
Old 04-10-2014, 12:50 PM   #15
Inner10's Avatar
The adjustable hole cutters.
Old 04-10-2014, 12:57 PM   #16
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,244
Just picked up one and it works awesome!
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following User Says Thank You to TNTRenovate For This Useful Post:
Sir Mixalot (04-14-2014)
Old 04-10-2014, 12:57 PM   #17
Stoneyard's Avatar
Rewards Points: 249
Gotcha...
Old 04-13-2014, 05:29 PM   #18
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
Assuming it's a existing plaster cieling, what about the rest of the housing?
Paulie is offline
Old 04-13-2014, 05:34 PM   #19
rrk's Avatar
You do know about remodeling cans right?
rrk is online now
66 Shelby (04-13-2014)
Old 04-13-2014, 05:37 PM   #20
Paulie's Avatar
Never had a job to retro fit them.
Come to think of it never seen one.... never really looked for 'em either tho.
Paulie is offline
Paint chipping Dpear Painting & Finish Work 8 05-28-2013 11:23 AM
Room Too Small for Coffered Ceiling?? vettefan77 Remodeling 11 12-18-2012 08:32 PM
Plaster over Particle Board damanriq Construction 9 12-13-2010 03:51 PM
Plaster Ceiling Demo Question nmcomeau Demolition 28 03-27-2009 10:00 AM
