Backerboard To Drywall Seam - Drywall - Contractor Talk
Old 11-14-2018, 10:52 AM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 4,496
Have a case of installed backerboard around a tub surround that was already tiled. But they left the unfinished backer extend about two inches on the sides into the drywall area.
So to tape and skim the two surfaces - 20 min mix with mesh? Is okay over backer material?
Also, where the side backer walls meet the ceiling, how to treat the gap? Mesh'd be hard to use on the inner corner, and I hate to caulk !
BTW: searched this forum, thinking there was something about this...
artinall is offline
Old 11-14-2018, 11:11 AM   #2
AustinDB's Avatar
Rewards Points: 1,098
Re: Backerboard To Drywall Seam
I've treated it like sheetrock and used mesh tape and 45 (I'm not fast enough to spread 20 and clean it up)
AustinDB is offline
The Following User Says Thank You to AustinDB For This Useful Post:
sparehair (11-14-2018)
Old 11-14-2018, 11:25 AM   #3
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,525
Use paper tape or fibafuse. Mesh does nothing when it's all dry. (And the debate continues...) I would use 5 or 20 and get it all done.
MarkJames is offline
Old 11-14-2018, 11:43 AM   #4
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 2,180
Agree with other replies, tape and mud no problems .
Idothat is online now
Old 11-14-2018, 11:51 AM   #5
artinall's Avatar
Didn't know if paper tape was alright over the backer... You are quicker than me, with that 5.
Whenever I apply backer/cement board, I end up just shy of the border so it's clean, no seams to deal with. So long as it's sealed.
- Does the backer need primed with the mud or 20 min?
artinall is offline
Old 11-14-2018, 11:56 AM   #6
MarkJames's Avatar
Originally Posted by artinall View Post
Didn't know if paper tape was alright over the backer... You are faster than me, with that 5.
Primer not necessary, but you might want to damp wipe any cement dust off. It doesn't have to be bone dry, either.
You can mix your setting compounds, so 5 and 20 will give you something in between.
artinall (11-14-2018)
Old 11-14-2018, 01:13 PM   #7
artinall's Avatar
Believe it to be Hardiebacker but will have to confirm...
artinall is offline
Old 11-14-2018, 07:43 PM   #8
90%-er
onmywayup's Avatar
Rewards Points: 2,098
Could also run another row of tile or bull nose to cover the seam? Or some complimentary mosaic tile?
Obviously the mud would be faster though
onmywayup is online now
Old 11-14-2018, 08:22 PM   #9
tjbnwi's Avatar
Rewards Points: 3,450
Use Kerdi band, bedded with mortar, covered with hot mud for finish.
tjbnwi is offline
Old 11-14-2018, 08:43 PM   #10
artinall's Avatar
I like the looks of that, and lightweight. Next time I do!
Nice thought but that would extend beyond the wall of the tub, at the base...and a window interferes.
artinall is offline
Old 11-17-2018, 09:05 AM   #11
Tom M's Avatar
Rewards Points: 3,412
Do you plan your seam behind the bullnose tile then hot mud to the tile after its installed
Tom M is online now
Old 11-17-2018, 09:47 AM   #12
tjbnwi's Avatar
Normally end up doing 1 coat of hot mud about 1/4" into the tile area, prior to setting the tile.
tjbnwi is offline
Tom M (11-17-2018)
Old 11-17-2018, 09:57 AM   #13
tjbnwi's Avatar
Two different situations. The blueish is Noble brand.
On the straight wall just the liner was used, no need for a band. It covers the seam by 4-5". The pencil line is where the tile trim goes. No bullnose on this one.
Backerboard to Drywall Seam-img_0227.jpg   Backerboard to Drywall Seam-img_1653.jpg
tjbnwi is offline
Old 11-17-2018, 09:59 AM   #14
Tom M's Avatar
I thinset the cracks and mesh and at times thinset seams for fill but use Aqua Defense to embed fleece in transitions. I dont know whats better or correct.
Just like the tub flange on acrylic tubs......the tile setter I use says he just packs it with thinset and mesh while setting but that seem like a crack waiting to happen to me. I may be wasting my time but I will silicone the gap the use Aqua defense in those transitions onto the tub for some flexibility.
Tom M is online now
Old 11-17-2018, 10:09 AM   #15
tjbnwi's Avatar
I use Kerdi Fix to fill the gap, normally leave 1/4" gap, place a piece of band over it. Make sure you mask the tub deck if using Kerdi-Fix....
I also relieve the back so the board sits flat on the flange. No screws within 6" of the deck.
tjbnwi is offline
Old 11-17-2018, 12:37 PM   #16
Tom M's Avatar
Never used kerdi fix. I guess it's flexible/elastic.
Tom M is online now
Old 11-17-2018, 04:52 PM   #17
tjbnwi's Avatar
Yes, and sticky as——well.....
Good luck getting it off something you don’t want it on.
That’s why you tape off the deck completely. Leave yourself courtesy tabs to pull the tape off. Don’t run a piece of tape more than a couple of feet. Shorter pieces give you better control when removing the tape.
tjbnwi is offline
Tom M (11-17-2018)
Old 11-17-2018, 07:32 PM   #18
avenge's Avatar
Rewards Points: 610
He didn't do the tile or backer he's left having to tape a seam 2" from the tile which is messed up. I almost always bring the tile past the seam, which ends up outside of any possible water if not I'll fibafuse, mud if needed then Redgard just short of where my tile ends.
And who the hell uses mesh tape anymore?
avenge is offline
Old 11-17-2018, 08:16 PM   #19
Tom M's Avatar
Is it preservable? As in using today and cutting out a niche tomorrow and the tube still useable?
Tom M is online now
Old 11-17-2018, 10:23 PM   #20
tjbnwi's Avatar
Yes, I tape the nozzle or put a new one on the tube that has not been cut cut open. I've used tubes that have been open for 6 months or or more.
tjbnwi is offline
Tom M (11-18-2018)
Veneer plaster vs drywall nesc39 Drywall 15 03-29-2016 09:27 AM
drywall over drywall nwksremodeler Drywall 11 01-14-2014 09:57 PM
Priming & Painting drywall Repairs, not new drywall mcgyver79 Painting & Finish Work 21 04-23-2013 03:47 PM
Backerboard a Whole Bathroom Jaws Remodeling 52 02-22-2012 02:23 PM
Drywall GettingBy General Discussion 3 06-16-2011 12:58 PM
