Attaching Drywall To This SH$#!!!! - Drywall - Contractor Talk
Old 03-18-2009, 03:03 PM   #1
bujaly's Avatar
Trade: Commercial interior super
Hey guys.. Doing some light framing and drywall to a basement.. The owner told me that some other guy framed this out about 4-5 years ago. Anyway, as you can see, the frame work is sitting flush against the foundation. Without just putting up a new 2x4 wall, (trying to keep cost low for HO), i'm going to modify this to attach the drywall too.
I know what I would like to do to attach the drywall correctly, but I'd like to see if anyone else has an better idea..
Thanks ya'll!!!
Attaching drywall to this SH$#!!!!-hpim1211.jpg   Attaching drywall to this SH$#!!!!-hpim1212.jpg
"Relentless in Reliability and Satisfaction!"
Oh yeah, 1 other thing...
Assuming doesn't make an a55 out of me and you, it makes an a55 out of YOU and YOU!!!
bujaly is offline
Old 03-18-2009, 03:09 PM   #2
Thom
thom's Avatar
Rewards Points: 4,748
Re: Attaching Drywall To This SH$#!!!!
Install the rock, tape the joint to the concrete with fiberglass tape, skim the concrete with durabond and call it good.
thom is offline
Old 03-18-2009, 03:14 PM   #3
mickeyco's Avatar
Trade: Squirrel Handler
Rewards Points: 2,000
Insulation?
mickeyco is offline
Old 03-18-2009, 03:15 PM   #4
SDC's Avatar
Rewards Points: 256
or, fur the whole wall with strapping...
David Cookman
Twitter
SDC is offline
Old 03-18-2009, 03:19 PM   #5
bujaly's Avatar
Originally Posted by mickeyco View Post
Insulation?
Hold your horses Mickey.. lol
Why do you all always go beyond the question..
I didn't say anything about insulation.. haha
bujaly is offline
Old 03-18-2009, 03:25 PM   #6
mickeyco's Avatar
If you're not insulating and the cement walls are fairly straight you can just use construction adhesive to attach the drywall on the lower portion, you can still insulate the top part.
mickeyco is offline
Old 03-18-2009, 03:27 PM   #7
AustinDB's Avatar
Rewards Points: 1,582
I would vote for furring it out too-1x3's would make quick work of it and you could insulate over the concrete w/ 1/2" foil board. For that matter, maybe cover from floor to ceiling w/ 1/2" foil board then install board directly over w/ 1 5/8 screws and glue the bottom :-(
AustinDB is offline
Old 03-18-2009, 05:26 PM   #8
roo's Avatar
Trade: Bricklayer
Rewards Points: 75
Is it water tight (damp proofed) if not it might have to be tyveked. Either way you could tyvek the existing wall first then add another piece of baton (over the tyvek) from the top of the existing frame and run it all the way to the floor and screw the baton to the concrete this would also allow breathing space for the tyvek (from the pics it looks like the frame work is flush with the concrete at the bottom). If insulation is a problem you could then use thermaboard instead of foil backed.
roo is offline
Old 03-18-2009, 05:35 PM   #9
catspaw's Avatar
Trade: building
Rewards Points: 150
glue it to the concrete definately as mickeyco stated. the sill will make excellent termite food if it's not treated wood.
catspaw is offline
Old 03-18-2009, 05:39 PM   #10
crazyboy's Avatar
Trade: Electrical
Rewards Points: 75
Did he do his own electrical?
crazyboy is offline
Old 03-18-2009, 05:39 PM   #11
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 186
Check your codes - most places require it due to change of use
SLSTech is offline
Old 03-18-2009, 11:01 PM   #12
bujaly's Avatar
That was my plan....
I know.. No staples..
??? What r u talking about? Not in a sarcastic way, but I have no idea what you r referring too my man..
bujaly is offline
Old 03-18-2009, 11:29 PM   #13
Sean
SLSTech's Avatar
Rewards Points: 186
In order...
Insulation?
Is this a little clearer - INSULATION may be required (especially when you change a rooms use from unfinished basement to finished), check with the BD or BI - you are pulling a permit right?
SLSTech is offline
Old 03-18-2009, 11:52 PM   #14
bujaly's Avatar
In order...
I really don't understand some of you.. Really!! Why r u answering a question that was never asked.
Where did I mention... "Should I be insulating this sh#*?
The word insulation was never mentioned in my OP.
bujaly is offline
Old 03-19-2009, 05:15 AM   #15
Custom Stuff
Mike(VA)'s Avatar
Trade: General Contractor - Custom Renovations
Question certainly wasn't asked about insulation, but it is required. I guess that's why he's a handyman. Permits, well ......
bujaly, you are not the only one reading the responses. There are many HO's who look for answers here and that is why many of us respond the way we do. Educating HO's about the right way to do things is important.
__________________________________________________ ___________
I EXPECT THAT SOMEDAY I WILL SEE THE FRUITS OF MY LABOR. IS IT SOMEDAY YET?
Clifton, Great Falls, McLean, Fairfax Station, Manassas, Virginia Renovation Contractor
Mike(VA) is offline
Old 03-19-2009, 06:16 AM   #16
boman47k's Avatar
Rewards Points: 2,006
I can see the 1X3's.
My guestion is about the wiring. What is holding the wire up in that loopy fashion? There seems to be a gap between the studs and the block wall, and it looks like excess wire being used.
boman47k is offline
Old 03-19-2009, 08:24 AM   #17
SelfContract's Avatar
A cheap problem requires a cheap solution.
SelfContract is offline
Old 03-19-2009, 09:19 AM   #18
mgard64's Avatar
Trade: Genaral Contractor
Before you drywall tape some plastic to the block walls. To check for mosture it should sit for a week.Do this in
a couple places. Then insulate with rigid insullation and rock with dens armour drywall.
mgard64 is offline
Old 03-19-2009, 02:41 PM   #19
bujaly's Avatar
Damn, always gotta be one guy on this site to just go WAY off the charts with their ignorant replies..
BUT, I'm home early because of the rain, so I will enjoy this..
Okay, for 1, I posted in the DRYWALL forum, not the "How do I finish a basement" forum.
2. I also can see why someone would come into a drywall forum, looking to get insulation advice and/or questions answered. I mean, I go to the HVAC forum to get questions answered and advice about roofing all the time.
3. This is a site for CONTRACTORS, not HO's. Hence the name, CONTRACTORTALK.COM. Remember that you typed it into the address bar before hitting enter buddy.
4. Yes yes, I'm a handyman. Obviously from my title as a handyman and me asking one question about attaching drywall, I MUST not pull permits. What else can you say about me. OH, I do pick up illegals at HD. As all handymen do, so no worries there. lol..
5. Your right Mike, I'm not the only one reading responses on here.. True. But I am the one who started this topic, ON DRYWALL. Why do I need answers to questions that weren't even brought up by me?
6. Just for you, I'm going to post a new topic on.. "How do I insulate this Sh#@??"
I told her, whoever did this wiring, get them back in here to correct it. That certainly isn't going to pass any inspection. I'm no electrician, but..
I have already done that, with foil though.. I'm just going with 6 mil poly for a VB.. I do not have any experience with dens-armour. Not using it really, but applying a finish to it is where I am clueless. I will look into it though, as I only have 2 foundation walls to cover. Thanks for the tip.
bujaly is offline
Old 03-19-2009, 02:57 PM   #20
mickeyco's Avatar
Thanks fellahs
No sweat.
The reason i first asked about insulation was because I'm aware of the code, I didn't know if that was an exterior or interior wall, I have a similar interior wall in an apartment building and duplex that are interior firewalls.
mickeyco is offline
Insurance company estimate for drywall Shoreguy Drywall 24 10-10-2011 05:26 AM
Drywall Scratches - Level 5 Smoothwall HUNG BY FOOT Drywall 15 03-10-2009 05:19 AM
Drywall Doesn't Line Up???? rugby_3 Drywall 4 03-05-2009 08:04 PM
Any Of You Guys Use This Drywall? Ed the Roofer Drywall 12 03-02-2009 11:16 AM
How much advantage is 5/8 drywall over 1/2"? Jim S. Drywall 2 08-26-2008 10:52 AM
