Asbestos In Older Drywall. Do You Test For It? - Drywall - Contractor Talk
Old 04-16-2015, 12:26 AM   #1
needs glasses's Avatar
Trade: Renovator
Rewards Points: 300
I've had old plaster and insulation tested before for asbestos, but not drywall.
I'm doing a job and the plumber said to the HO that he wanted the drywall tested for asbestos before he cut the ceiling open.
The place was built in 1978, so asbestos was still around in construction then.
Got me thinking, maybe I too should be insisting on testing. Just wonder how far to go with it. Cutting a 2'x2' hole? A couple sheets ? etc...
needs glasses is offline
Old 04-16-2015, 08:17 AM   #2
Manager/Diplomat/Builder
darthdude's Avatar
Trade: Lead Carpenter
Rewards Points: 392
Re: Asbestos In Older Drywall. Do You Test For It?
Always test popcorn ceilings! Flat work can probably be skipped, unless you can tell popcorn has been scraped off, or overlaid. I've never heard of asbestos being in plaster though, was that a thing?
Oh, the lab here can do with a pretty small piece as long as all the layers are there. 1"x1"
darthdude is offline
The Following User Says Thank You to darthdude For This Useful Post:
needs glasses (04-16-2015)
Old 04-16-2015, 09:05 AM   #3
rustyjames's Avatar
Rewards Points: 1,816
From what I've read, the asbestos was used in the joint compound, not the board itself. I doubt there would be a problem with anything drywall from 78.
rustyjames is online now
The Following 3 Users Say Thank You to rustyjames For This Useful Post:
Big Shoe (05-24-2015), blacktop (04-16-2015), needs glasses (04-16-2015)
Old 04-16-2015, 07:37 PM   #4
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Get your plumber to tell the home owner to c/k for lead paint too, Then he can say something about radon gas, And dust mites in the a/c vents.
sunkist is offline
The Following User Says Thank You to sunkist For This Useful Post:
rustyjames (04-17-2015)
Old 04-16-2015, 08:08 PM   #5
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 322
Anything before 1980 could have it. There were a few buckets still floating around even after is was banned.
I just wish more H/Os And G/Cs would take note That Asbestos actually existed !! Whenever I bring the matter up of testing ..They all of a sudden become experts !! Telling me how wrong I am.
I tell em to have it tested then get back with me.
My Dad ate that stuff for many years . He said That joint compound was the best ever ! Today's Compound Is a joke in comparison .
He's 68 now . It ain't got him yet ! But It could tomorrow!!
I think Needs glasses ..All you need is a dime size piece . They don't need much .
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
The Following User Says Thank You to blacktop For This Useful Post:
Old 04-16-2015, 10:50 PM   #6
Trade: Renovator
Rewards Points: 300
I had it tested. I took two samples, one was wall board, other was tape and joint compound.
She told me not to bother with the board as it doesn't have it in. BUT the compound and tape tested as having 1 to 3% asbestos content.
Anyway too late now as I'd pulled a couple walls down last week, wore a good dust mask most the time. Realistically I'm sure I've pulled walls down with it in the past.
So now the job has come to a stop. HO had a fit, then calmed down, now he's considering getting someone in to take a look.
Old 04-16-2015, 11:01 PM   #7
Drywall Slave
blacktop's Avatar
Rewards Points: 322
That's gonna cost. As it should! I'm rolling a bet on 10k at the least.
blacktop is offline
The Following 2 Users Say Thank You to blacktop For This Useful Post:
needs glasses (04-16-2015), Rio (05-17-2015)
Old 04-16-2015, 11:09 PM   #8
Fire up the BBQ
griz's Avatar
Rewards Points: 1,758
Job at that age drywall mud is generally presumed to be hot.
Mud has been tested as hot, only thing left to do at this point is air sample, then abate remaining compound.
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
blacktop (04-17-2015), needs glasses (04-16-2015)
Old 04-16-2015, 11:50 PM   #9
Trade: Renovator
Rewards Points: 300
I agree with Griz's tagline.
The Following User Says Thank You to needs glasses For This Useful Post:
rjconstructs (05-17-2015)
Old 04-17-2015, 05:40 AM   #10
builditguy's Avatar
Rewards Points: 2,072
"Popcorn" ceilings can also have asbestos. Asbestos fibers can form part of the texture binding. Not the actual nodules.
builditguy is offline
Old 04-17-2015, 09:28 AM   #11
rustyjames's Avatar
Don't forget the mold and the off gassing of the carpets and furniture
Old 05-17-2015, 06:41 PM   #12
fast fred's Avatar
Trade: carpentry
Rewards Points: 836
thanks for the laugh, just recently had a old guy swear that mud was better and easier to put on back in the day, cause of asbestos
I've delt with asbestos a bunch, good racket to get into as far as I'm concerned, and racket it is
Here is what I know about it, but don't quote me, I just pretend to be a contractor and I'm mostly wrong, all of what I do know pertains to colorado asbestos and law
1) You can remove 32 sq ft of asbestos containing material before having to do any mitigation
2) material containing 1% or less of asbestos does not have to be mitigated
3) A tiny little bit of drywall is needed for a sample, samples are usually taken from random spots, I average 5 spots per 1000 sq ft of living space
4) Asbestos may be present in any home built up to 1990
5) Friable asbestos which was used as insulation (and lots of other stuff) will screw you up, I don't think asbestos in drywall will do that much damage to you (opinion)
6) Asbestos is in many things besides drywall, floor and tile adhesives, glues, siding, roofing
7) Most of my hot jobs come back at 2% - 4% asbestos containing, I pay anywhere between 8-12k to have a 1000 sq ft condo demo'd by a certified crew who hauls to a special landfill
fast fred is offline
Test - How many terrible practices can you find ??? theflynner Roofing 28 08-08-2019 11:01 AM
Zinsser 123 for new drywall? renov8r Painting & Finish Work 11 09-10-2013 07:35 AM
Kerdi Board to Drywall Stunt Carpenter Kitchens & Baths 5 06-18-2013 12:11 AM
drywall subs needed ASAP estimating2013 Help Wanted or Looking For Work 4 04-27-2013 06:46 PM
Radiant Ceiling Heat - Drywall Falling Again CliffHollen Drywall 7 04-05-2010 04:18 AM
