Any Opinions On This Tool? - Drywall - Contractor Talk
Old 03-08-2009, 02:03 PM   #1
willworkforbeer's Avatar
Trade: home remodeling
I'm finishing the drywall (not my normal trade) on a 1200 sq ft unit, around 150 sheets of 4x8, might do a smaller job later. I really dont want to invest in a Porter Cable as I sincerely hope in the future to leave the drywall to the professional drywallers. I found this this "RotoBlast 880" for $209,you can google it, (sorry cant post URL's yet) Cheap but I'm a little wary
willworkforbeer is offline
Old 03-08-2009, 09:37 PM   #2
Tim0282's Avatar
Trade: drywall contractor
Re: Any Opinions On This Tool?
I have looked at this sander for quite some time. My PC sanders are getting close to worn out. Considered buying one to try. About half the price of PC. Worth a shot.
Tim0282 is offline
Old 03-09-2009, 06:35 PM   #3
plazaman's Avatar
Rewards Points: 1,216
looks like a PC knockoff. if it only 1 job, then maybe... i have a PC setup, but bastically it sits in my garage. we find that hand sanding is better.
plazaman is offline
Old 03-14-2009, 05:46 PM   #4
Well I ordered it, I'll find out in a few days if I'm just another sucker. I really really dont want to hand sand the ceiling, had major shoulder surgery 8? monthes ago and the only guy I have working for me is a framer, good dude but no experience at mudding, I see a lot of sanding in the immediate future
Old 03-14-2009, 08:07 PM   #5
Tim0282's Avatar
I bet you'll be fine with your purchase. I could be mistaken but, I think they have been around longer than Porter Cable has had theirs. The ad dollars are behind PC and not behind these guys. I'm going to jump out and double check on the length and get back to you...
Tim0282 is offline
Old 03-21-2009, 05:43 AM   #6
The sander came and I tested it, seems to work, but haha get this, its label is drywall sander, no brand name. I'm deep in unhappyland, finishing a 1200 sq ft unit by myself now, what was I thinkin?
Old 03-22-2009, 01:56 PM   #7
drywaller
Mudshark's Avatar
Trade: Drywall Finisher
Rewards Points: 75
If drywall is not your normal trade why even own this expensive sander even if you did find a "deal" ?
These sanders can be great on big jobs when handled by experienced drywallers but carefull you don't oversand and leave gouges. Kind of reminds me of the people that try to sand wood with an angle grinder.
The tried and true pole sander sells for a lot less and stores well when not being used
Mudshark is offline
Old 03-22-2009, 10:11 PM   #8
Butt Expert
Brocktologist's Avatar
Trade: Drywall
Rewards Points: 250
After renting a PC sander a few times I went ahead and bought one but it seems the "head" is too tight on this one and it leaves that circular gouge line so all I ended up doing is using it for grinding down other peoples textures with it.
If that cable line was more flexible like the one I rented, I'd prolly use it alot more.
Brocktologist is offline
Old 03-27-2009, 09:16 PM   #9
Yeah pole sanding uh huh, two guys, me and a framer, right. We got it done, nothing that texture and 40 watt lightbulbs cant hide. Seriously though I'll never finish the drywall on a whole unit again. I'll stick to objects made out of wood. That sucked really bad. The sander worked out great though. Best $239 (with S & H) I ever spent to get my a$$ out of a hole. You finishers earn your money.
Old 03-28-2009, 06:33 AM   #10
BUTCHERMAN's Avatar
Trade: DRYWALL PROFESSIONAL
Rewards Points: 2,392
The brushes on your sander are too new. They need to wear down. You can do to things here. 1) Finish with mid-weight. This stuff was made for the Porter Cable Sander. 2) Cut a round piece of cardboard and put it under the sanding pad. This will push the pad out past the brushes enough that the vacuum won't suck tight to the wall and be hard to swing. Make sure you take the cardboard out after the brushes have worn a little or over time you will wear out the bearing. Also if you are not doing so use a 220 pad.
BUTCHERMAN is offline
Old 03-31-2009, 10:11 PM   #11
MeatBallDryWall's Avatar
Trade: Residential & Commercial Hanger/Finisher
Rewards Points: 75
I bought one with the same problem. It would leave ungodly swirls in the joints. I sold it & bought a Radius 360 & WoW can you fly with it(if ur finishing is slick)
MeatBallDryWall is offline
tool definitions go do it General Discussion 10 05-15-2017 01:44 AM
tool storage SES Constructio General Discussion 55 08-18-2010 08:53 PM
Working from a Tool Cart basswood Finish Carpentry 41 03-24-2010 03:38 AM
Some tool reviews d's Drywall 11 02-22-2009 12:02 PM
Another Cordless Tool Thread... orson Tools & Equipment 7 11-09-2008 11:39 PM
