Angle Box Advice - Drywall - Contractor Talk
Angle Box Advice
Old 12-14-2014, 08:45 AM   #1
BobbyCA's Avatar
Trade: general
Rewards Points: 60
Angle Box Advice
Hi All,
I'm hoping to get some assistance from the drywaller's... I'm by no stretch of the imagination a pro and will never pretend to be... However, I will do small drywall jobs (like a room or two) on remodel work... It takes me three times as long as a pro, but I've always been okay with that... But, I'm now starting to get the itch to move to actual tools and my first one would be an Angle Box... What I'm hoping for is to find out the learning curve on it... Is it something that takes a lot of time to master or is it a tool that can quickly cut my time finishing corners... Any help would be much appreciated... I'd hate to purchase the tool and all its requirements just to find out its actually taking me more time and frustration because it requires way too much practice.. Thanks in advance...
BobbyCA is offline
Old 12-14-2014, 10:40 AM   #2
mnld's Avatar
Trade: drywall junky
Rewards Points: 498
Re: Angle Box Advice
I would do some more research before buying an angle box. I started with an angle box, moved up to a mud runner, and now I use a compound tube and assorted heads. The compound tube is so simple and easy and didn't involve using a pump. Perfect for smaller jobs or whole houses. Check out some of the vids on drywall talk or you tube. Enjoy the journey, future drywall tool whore.
mnld is offline
Old 12-15-2014, 04:44 AM   #3
justanotherdrywaller
b,mitch's Avatar
Trade: drywall
Rewards Points: 26
As mnld has said,the tube and flusher is probably your best investment for doing the small jobs.low cost,easy to learn.you would need to be using a anglehead at the taping stage to achieve the best results with the angle box at the finish stage.expensive and a little tougher learning curve.if you're hand taping ,the tube and flusher is the best bet to finish.
b,mitch is offline
Old 12-15-2014, 06:36 PM   #4
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
I agree with all that has been said. You would need (IMO) a pump, angle roller, angle head, angle box, and the poles to use them. That right there is about $800 depending on the brand.
Get a banjo and a flusher. Your speed will be freakn amazing with the addition of just those tools.
CrpntrFrk is offline
The Following User Says Thank You to CrpntrFrk For This Useful Post:
Big Shoe (12-18-2014)
Old 12-16-2014, 09:06 PM   #5
Gary H's Avatar
Rewards Points: 2,342
X2 . I got all the tools to lay mud down. Boxes, many handles, pumps and bazooka . Never use them. Got a banjo and flusher and they are all I need. Easy clean up and cheap compared to the taping set.
Gary H is offline
Old 12-16-2014, 09:13 PM   #6
BobbyCA's Avatar
Trade: general
Rewards Points: 60
Thank you mnld.... Do you have a compound tube you would recommend?
BobbyCA is offline
Old 12-16-2014, 10:43 PM   #7
mnld's Avatar
Rewards Points: 498
Blue line tube, columbia corner applicator- with four wheels- columbia three inch flusher or If you're feeling spendy, a 3.5" north star angle head.
mnld is offline
The Following User Says Thank You to mnld For This Useful Post:
BobbyCA (12-17-2014)
Master Bath remodel advice NINZAN STUDIO Remodeling 25 08-15-2013 07:36 PM
Van to truck advice please! renov8r Vehicles 47 05-01-2013 06:28 PM
calculating crown spring angle Mrmac204 Finish Carpentry 12 12-26-2012 08:08 AM
Paslode Angle Trim Nailer Problem. MF Custom Tools & Equipment 3 07-16-2012 10:19 PM
right angle drill/driver Rich D. Tools & Equipment 16 06-29-2012 03:06 PM
