Anchoring For Large Pictures/mirrors In Plaster - Drywall - Contractor Talk
Old 07-21-2015, 04:57 PM   #1
Creter's Avatar
Rewards Points: 1,966
Do you guys recommend anything specific to anchor large pictures and mirrors into plaster?
Creter is offline
Old 07-21-2015, 06:40 PM   #2
Snow580's Avatar
Trade: Drywall
Rewards Points: 22
Re: Anchoring For Large Pictures/mirrors In Plaster
Ideally I like to drive a screw into a wall stud but depending on the location that the picture needs to be hung that's not always possible. If that happens as long as it's not a super heavy piece I've had good luck pre drilling a small hole through the plaster and anchoring the screw into the lath.
Snow580 is offline
Old 07-21-2015, 07:00 PM   #3
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,258
If you can't hit a stud use a toggler:
Inner10 is online now
The Following 5 Users Say Thank You to Inner10 For This Useful Post:
GettingBy (07-24-2015), overanalyze (07-24-2015), platinumLLC (07-23-2015), RiverBG (07-21-2015), rrk (07-25-2015)
Old 07-21-2015, 07:23 PM   #4
rondon's Avatar
Trade: carpenter
Rewards Points: 96
INNER10
I just started using them and really like them
rondon is offline
Old 07-21-2015, 08:59 PM   #5
Fire up the BBQ
griz's Avatar
Rewards Points: 2,980
Originally Posted by rondon View Post
INNER10
Way cool until they fail.....
Don't know what you are calling large....
Huge weight difference between pictures and mirrors....
What mounting method(s) are you dealing with?_
griz is online now
Old 07-22-2015, 05:23 AM   #6
Inner10's Avatar
Get it behind the lath, it will take the wall down with it lol.
Old 07-22-2015, 05:14 PM   #7
madmax718's Avatar
Trade: General
Rewards Points: 3,272
Use a toggle of some sort, but yes like the one pictured. old plaster walls can vary in thickness. Could be up to 1" thick in some areas.
madmax718 is offline
Old 07-22-2015, 07:12 PM   #8
Big Shoe's Avatar
Rewards Points: 1,916
I've had good luck with ''Wall Dogs'' on plaster. Sometimes I pre drill holes and use whatever type nail or screw that is necessary. Depends on what type of plaster.
Inners Snap Toggles are great for heavy things. But the metal Butterfly Toggles come in all sizes and lengths. That is my favorite go to nowadays for things like towel bars and toilet paper holders.
Good luck to you.
Expect the Unexpected
Big Shoe is offline
Old 07-22-2015, 07:39 PM   #9
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 3,431
I use toggles or mollies. It all depends on the weight for me. And sometimes I'll use a level and install two appropriately spaced for the piece that is being hung.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 53,000 Subscribers and over 9,500,000 Views
https://www.youtube.com/paulpeck
Twitter Facebook Google+ Instagram
Sir Mixalot is offline
Old 07-22-2015, 08:04 PM   #10
kingcarpenter's Avatar
Trade: G.C./carpenter
Rewards Points: 544
Butterflies depending on weight sometimes 2 or 3
kingcarpenter is offline
Old 07-23-2015, 09:49 AM   #11
improving homes
platinumLLC's Avatar
Trade: Roofing/Remodeling
Rewards Points: 346
You've had one fail? I've hung grab bars with them and actually put all my weight on the bar and it didn't flinch at all.
platinumLLC is offline
Old 07-23-2015, 10:50 AM   #12
Inner10's Avatar
They don't, the wall does. I've also used those in block.
rrk (07-25-2015)
Old 07-24-2015, 08:11 AM   #13
improving homes
Rewards Points: 346
I was just wondering if anyone has had them or the wall they are anchored to fail on them?
I never thought to use them in block. Just this past week I was installing a vanity on a block wall and tapcons weren't sticking and I didn't have long enough red heads so had to run to the store to get some longer red head anchors. I had some togglers with me and could have used them. Would have been a better solution also since to get the vanity out now you have to trash it or grind off the anchors. Thanks for the suggestion.
Old 07-24-2015, 11:00 AM   #14
GettingBy's Avatar
Rewards Points: 6,486
One chance in 10 for 16" O.C., I figure.
Glass is pretty dense, more than concrete I think, so mirrors weigh quite a bit more than pix.
The force on the toggle is mostly vertically downward [a shearing force] with very little pull-out/pull-through force and little 'pull-over' force, so they should be quite strong.
Some fastener packages post 'working load', some 'ultimate strength'. Check the packages, weigh your item, figure how many fasteners you need to share the load.
The strength of materials used in resi walls should be all over the Web.
GettingBy is offline
Old 07-24-2015, 11:16 AM   #15
Texas Wax's Avatar
Rewards Points: 1,780
Good luck to you.
OP's use, Add a nut and fender washer -
Texas Wax is online now
Old 07-24-2015, 11:30 AM   #16
Creter's Avatar
Hung many a thing in drywall - plaster is a different beast in that if that bastard starts crumbling it's like a thread on a t-shirt and may never stop.
Usually, plaster doesn't worry me too much as the company is usually inside the home working on a remodeling project. If asked to hang something in plaster in a part of the home we're not working in I usually don't have an issue with it knowing the homeowner as well as having time to make a repair if the plaster heads south.
This morning I had a few handyman items I was obligated to perform and wanted a sure fire way to get in and out with the plaster. Fortunately I was able to provide great results for the other items on her list and was able to skirt around hanging the pictures and mirrors.
We exchanged pleasantries when I was finished and we parted on great terms. Her chatting away about future remodeling projects. IF those remodeling projects ever make the light of day - I'll gladly hang whatever she needs in the plaster. But to do say today was a risk I was unwilling to take.
Thanks for all the replies and insights.
Creter is offline
The Following 2 Users Say Thank You to Creter For This Useful Post:
Big Shoe (07-25-2015), Sir Mixalot (07-25-2015)
Old 07-24-2015, 03:50 PM   #17
Inner10's Avatar
I did, leak in roof soaked the drywall and the chunk of drywall pulled off with the anchors.
Old 07-25-2015, 03:15 AM   #18
Big Shoe's Avatar
Ah yes........I remember the first plaster home I hung a ton of stuff in. I learned real quick.
Big Shoe is offline
Old 07-25-2015, 07:19 AM   #19
GettingBy's Avatar
Is old plaster worse or better?
Old 07-25-2015, 05:47 PM   #20
rrk's Avatar
Rewards Points: 1,960
What type of plaster? Wood lath? wire lath? gypsum lath?
I have never seen a toggler fail, walls yes togglers no
the smallest toggler holds almost 240 lbs in drywall
http://www.toggler.com/pdf/toggle.pdf
rrk is online now
Identifying plaster walls artinall Drywall 2 01-26-2013 11:15 AM
Ornamental Plaster (Removing Paint) Jason Whipple Painting & Finish Work 4 09-23-2012 07:55 PM
anchoring wet location box VAviaCo Electrical 5 06-21-2012 10:45 PM
wallboard patch on plaster artinall Drywall 0 05-21-2012 04:20 PM
Venetian Plaster Glossary Plaster Ayn Faux Finishes 3 04-27-2011 08:46 AM
