Air Bubbles In My Mud - Page 3 - Drywall - Contractor Talk
Old 02-05-2010, 09:31 PM   #41
d-rock's Avatar
Trade: carpentry/drywall/plaster
Rewards Points: 250
Re: Air Bubbles In My Mud
Originally Posted by Ben of Hyde View Post
Oh, those dirty Mexicans in front of the Home Depot ...
d-rock is offline
Old 02-07-2010, 04:34 PM   #42
kcbasements's Avatar
Trade: Basement Finishing
Rewards Points: 150
Handsoap? Really?
kcbasements is offline
Old 02-09-2010, 01:39 PM   #43
rbatwood68's Avatar
Trade: Drywall;Hang and Finish
Originally Posted by rjconstructs View Post
This question may have already been addressed in here, but I thought I would ask it anyway. What causes those pesky little air bubbles to come to the surface of my mud? This happens after I smooth the surface out. I get it like I want it then after a few minutes, here they come. If I lightly knock them down again this usually takes care of it.
I'm curious about what causes this and how I can prevent it.
Any thoughts?
rj
I have a two-part answer. First, if you are mudding over stuff that has been painted, the moisture cannot go into the drywall, thus causing it to come back out. Second, some of the old Union Men put a little bit of soal in their mud when mixing, thus keeping out many airpockets. Hope this helps, Rusty.
rbatwood68 is offline
Old 11-04-2014, 08:14 PM   #44
retired seabee's Avatar
Trade: remodel
Rewards Points: 2
Adding soap means not having to add water. The soap is a sufactant and basically makes the existing water wetter. I get bubbles on new drywall and old. Right now I am skim coating painted walls and I get bubbles on the second float. I sand them away when dry, or fill with a spot coat.
retired seabee is offline
Old 11-04-2014, 08:30 PM   #45
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
I prime before working on old work. Bubbles have become a thing of the past since then.
ohiohomedoctor is offline
The Following User Says Thank You to ohiohomedoctor For This Useful Post:
blacktop (11-30-2014)
Old 11-04-2014, 11:05 PM   #46
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,782
I get micro bubbles in mud when I mix it with my little paint mixer bit. Don't seem to get them when I use the fullsize mud bit. They are really annoying, but a couple extra passes over seems to pop them. Now I just need to learn to keep the little bits of gunk out of my mud!
heavy_d is offline
Old 11-05-2014, 08:38 PM   #47
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 108
Originally Posted by Capt-Sheetrock View Post
Okay children,,, pay attention,,,,,
The "bubbles" mentioned in this post,,, are NOT the "pock-marks" caused by "air-bubbles" in the mud. But rather the "bubbles" caused by effervesant bubbles caused by a caustic reaction of putting drywall compound over an "OLD WALL"
Two differant things, adding dishwashing detergent will not help this!!!! (truth is, it won't help in new construction either,, but it does make your mud smell nice an lemony"
Bingo! I miss you Capt!!!
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
Old 11-05-2014, 11:13 PM   #48
mnld's Avatar
Trade: drywall junky
Rewards Points: 498
There's allot of ways to skin a cat........none of which the cats gonna like!
mnld is offline
The Following User Says Thank You to mnld For This Useful Post:
Old 11-12-2014, 01:50 PM   #49
quickpatch's Avatar
Trade: Drywall, painting, Builder
Rewards Points: 66
I was in the drywall supply house is Spokane one day and the manager asked me if I had ever used a product that they were thinking of stocking called "Dr. Smooth Mud". Why yes I have I said as I smiled. I told him that some drywall tapers add liquid dish soap to the drywall compounds when they mix it to eliminate pock marks aka air bubbles etc. I told him "Dr. Smooth Mud" smelled like dish soap. He asked if the dish soap worked. I told him it seemed to help, but was no miracle cure. For the record, it didn't show up on their shelves.
quickpatch is offline
Old 11-30-2014, 10:19 PM   #50
ubcguy89's Avatar
Trade: carpenter/ interior systems
Rewards Points: 742
Frank, he ain't talking about "air bubbles in the mud" (pock marks, or pinholes)he's talking about the little bubbles that come up in a remodel, after you run your mud,,, ya know coming from the junk on the wall, due to the reaction from new mud on old walls
An old finisher, probably the best i have ever seen told me this. The air bubbles happen when your skimming old painted walls because paint acts as a sealer to the surface. So when you put mud on a wall instead of the moisture soaking in like it does on new board it comes out and bubbles.
ubcguy89 is offline
The Following User Says Thank You to ubcguy89 For This Useful Post:
BradingCon (11-30-2014)
Old 11-30-2014, 10:49 PM   #51
icerock drywall's Avatar
Trade: drywaller
Rewards Points: 930
yep.
dont work hard...work smart
icerock drywall is offline
Drywall bubbles AlSmith Drywall 5 06-08-2009 09:48 AM
Air Bubbles under laminate flooring Ugo Flooring 13 04-07-2009 09:12 PM
paint bubbles on door jambs moe2424 Painting & Finish Work 10 10-13-2008 09:05 PM
Bubbles when taping over paint raven2006 Drywall 30 12-23-2007 04:39 PM
Air Bubbles in Laminate Flooring Bigman Flooring 19 09-05-2007 09:07 PM
