Air Bubbles In My Mud - Page 2 - Drywall - Contractor Talk
Old 01-05-2010, 09:54 PM   #21
Ben of Hyde's Avatar
Rewards Points: 150
Re: Air Bubbles In My Mud
Why are we talking about air bubbles?
It's a normal thing when mixing mud, everyone gets them on the first and second coat ... it's like starting a thread about dust.
New Thread: How a bout that dust you get after sanding eh?
Ben of Hyde is offline
Old 01-05-2010, 09:56 PM   #22
Rewards Points: 150
Oh, those pesky Knots in my pine wood ...
Old 01-05-2010, 09:57 PM   #23
Rewards Points: 150
Oh, those dirty Mexicans in front of the Home Depot ...
The Following User Says Thank You to Ben of Hyde For This Useful Post:
d-rock (02-05-2010)
Old 01-05-2010, 09:57 PM   #24
Rewards Points: 150
... some things you just gotta put up with.
Old 01-05-2010, 10:11 PM   #25
Capt-Sheetrock's Avatar
Trade: Drywall
Rewards Points: 250
It seems you forgot to mention them pesky socials in washington,,,
are you slipping???
Capt-Sheetrock is offline
The Following User Says Thank You to Capt-Sheetrock For This Useful Post:
Ben of Hyde (01-05-2010)
Old 01-05-2010, 10:33 PM   #26
Rewards Points: 150
Just for the record ... (not to burst you're bubble) ... I'm a Dirty Mexican.
It's true, I was Born in La Cuidad de Puebla, Mexico.
Old 01-06-2010, 03:23 PM   #27
Trade: Drywall
Rewards Points: 250
Well perhaps its cause he wasn't talking about pock marks that are caused by air in the mud, he was talking about the "bubbles" that come up when you are mudding over an OLD wall,,,,, thats an entirely differant thing.
O'laaaa
Old 01-06-2010, 04:03 PM   #28
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
are you slipping???
Socials in Washington. I've never been invited to a social in Washington before. You must run in higher circles than me Capt. I don't even think I could sneak in.
Paulie is offline
Old 01-06-2010, 10:32 PM   #29
Trade: Drywall
Rewards Points: 250
HeeHee,, me neither,,, specially the way I spell,, or rather the way I DON"T spell....... I meant socialists
Old 01-23-2010, 08:37 AM   #30
Bernie Logan
bernielogan's Avatar
Trade: Drywall and Painting
Originally Posted by flippinfool View Post
The only time I've had that happen is when blending new and old sheet rock. Spoke to a USG rep and he said, as it dries the mosture can't soak into the old sealed area of drywall. So it comes out the other way "To the surface". If you are getting that with brand new work your not mixing or applying to thick of a coat.
We do mainly flood restorations so every job involves butting new sheet rock up to old, and I always get bubbles or fish eyes in a nice row on the old painted drywall. Tries the liquid soap also various mixing methods. Now i just scrape the dries second coat with a trowel, and apply a light skim coat which fills in the bubble holes. Takes a bit of extra time, then again we aren't doing new construction and they allow us some leeway cost wise.
bernielogan is offline
Old 01-23-2010, 10:39 AM   #31
phoney2's Avatar
Trade: professional
i sand alot ive seen a lot of different texture from many different tappers most defects in the mud comes out with a good sander what doesnt i just mark it lrt the tapper now and thay go back and touch it up
phoney2 is offline
Old 01-23-2010, 02:25 PM   #32
Muddauber's Avatar
Trade: drywall
Rewards Points: 250
It took me 5 minutes to read that.
Is this what you were trying to say?
I sand a lot. I've seen a lot of different texture from many different tapers. Most defects in the mud comes out with a good sander. What doesn't, I just mark it, let the taper know, and they go back and touch it up.
Muddauber is offline
The Following User Says Thank You to Muddauber For This Useful Post:
d-rock (02-05-2010)
Old 01-23-2010, 02:30 PM   #33
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
Iím not a master sheet rocker or sander but I know if you hand mix your joint compound you are less likely to have air bubbles, same goes with mixing mud and grout for tile.
I have also seen mex putting soap in when they mix up the compound.
What makes a good sander: A good spackler
festerized is offline
Old 01-23-2010, 08:52 PM   #34
Tom R's Avatar
Rewards Points: 2,036
Several good points mentioned here, but one I didn't see was that you'll have less bubbles/pinholes if you knife in one direction only.
Tom R is offline
Old 01-25-2010, 09:07 PM   #35
njcarpenter's Avatar
Rewards Points: 29
Originally Posted by Sir Mixalot View Post
Add a little
Exactly what I was thinking....
I've seen the tapers doing that alot on big commercial jobs.......
njcarpenter is offline
Old 01-25-2010, 10:36 PM   #36
Trade: Drywall
Rewards Points: 250
Okay children,,, pay attention,,,,,
The "bubbles" mentioned in this post,,, are NOT the "pock-marks" caused by "air-bubbles" in the mud. But rather the "bubbles" caused by effervesant bubbles caused by a caustic reaction of putting drywall compound over an "OLD WALL"
Two differant things, adding dishwashing detergent will not help this!!!! (truth is, it won't help in new construction either,, but it does make your mud smell nice an lemony"
blacktop (11-05-2014)
Old 01-27-2010, 12:46 AM   #37
Student Mentality
DustyMudder's Avatar
Trade: Drywall Taper
Aye aye Capt. These bubbles are particular to painted surfaces; the statement about the surface not being able to absorb moisture seems to make sense.
Never tried the soap trick, although a simple solution would be nice. The trick I learned was to put on a thin layer of mud and wipe it TIGHT, pretty much taking it all off, before loading it proper. It takes a few extra seconds per joint, but when the mud goes on the second time the bubbles are pretty much nonexistent.
DustyMudder is offline
The Following 2 Users Say Thank You to DustyMudder For This Useful Post:
Capt-Sheetrock (01-30-2010), festerized (02-05-2010)
Old 02-05-2010, 02:31 PM   #38
chris jackson's Avatar
Trade: painter,remodelling
One of the other things that hasnt been mentioned but is something to consider is the type of drywall mixer you use. too many use convention drills to mix and thus creating a lot of air into the mud. i know the fish eyes are inherant when placed over prepainted surfaces however they can be greatly minimized by using a proper drywall mixer. I have a makita and a ridgid and actually the ridgid has an even lower rpm than the makita does.
it doesnt negate all fish eyes however it does minimize them over a conventional drill
chris jackson is offline
Old 02-05-2010, 03:21 PM   #39
mikebooth's Avatar
Trade: general contractor
Rewards Points: 25
put a small amount of ivory dishwashing liquid in your joint compound when you mix it. That should take care of the bubbles.
mikebooth is offline
Old 02-05-2010, 09:27 PM   #40
d-rock's Avatar
Trade: carpentry/drywall/plaster
Rewards Points: 250
Originally Posted by jonny rocket View Post
we call them pocks or pimples lol.when i coat i dont like adding to much water to my mud cause it can cause the mud to shrinks to much.then you can get humps in your cross seams or the the flats could cup.
try useing light weight usg.the blue lid(for coat only).no water just a little hand soap and mix.
What's with the hand soap boys ??
d-rock is offline
Drywall bubbles AlSmith Drywall 5 06-08-2009 09:48 AM
Air Bubbles under laminate flooring Ugo Flooring 13 04-07-2009 09:12 PM
paint bubbles on door jambs moe2424 Painting & Finish Work 10 10-13-2008 09:05 PM
Bubbles when taping over paint raven2006 Drywall 30 12-23-2007 04:39 PM
Air Bubbles in Laminate Flooring Bigman Flooring 19 09-05-2007 09:07 PM
