After Sanding.. - Drywall - Contractor Talk
After Sanding..
Old 08-14-2007, 12:25 PM   #1
bujaly's Avatar
Trade: Commercial interior super
After Sanding..
I'm done sanding and their is dust all over the walls and ceiling. What are some of your suggestions before painting? I didn't use a wet vac or any type of dust collection system either.
"Relentless in Reliability and Satisfaction!"
Oh yeah, 1 other thing...
Assuming doesn't make an a55 out of me and you, it makes an a55 out of YOU and YOU!!!
bujaly is offline
Old 08-14-2007, 04:32 PM   #2
plazaman's Avatar
Rewards Points: 1,226
Re: After Sanding..
i use a california car duster and a shop vac.
Brush down first then sweep/vacuum.
Brush down again & vacuum
Or sometimes we use my dustless system from porter cable which hasnt been working too well lately, so i switched to the traditional method. pole and block
plazaman is online now
Old 08-14-2007, 05:00 PM   #3
bujaly's Avatar
Re: After Sanding..
what type of attachment are you using on the walls? I already have the duster too
bujaly is offline
Old 08-20-2007, 02:10 PM   #4
NFMudder's Avatar
Trade: Drywall
Re: After Sanding..
wet down a terry cloth towel and ring as much water out as you can. Hang it over a push broom and run it over the wall but don't go over the same spot twice or you will remove compound.
NFMudder is offline
Old 08-20-2007, 11:56 PM   #5
oldrivers's Avatar
Trade: drywall applications
Rewards Points: 522
Re: After Sanding..
I think its better to leave the dust on the walls, All i do is take a small paint brush and sweep off any excess piles of it. This way you dont have a fuzzy surface where the wallborad is and a smooth surface where the mud is The dust kind of equals out the transitions on walls , plus the dust fills in any pock marks that might be there. But then again everyone has their own theory .
oldrivers is offline
Old 08-21-2007, 12:24 AM   #6
bujaly's Avatar
Re: After Sanding..
Wait a second. The last time I painted a wall that I didn't fully wipe down, it just bubbled everywhere. How is you method possible oldrivers?
bujaly is offline
Old 08-21-2007, 04:19 AM   #7
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Rewards Points: 4
Re: After Sanding..
If you ever have to prime and paint these walls and make it stick,you just might change that attitude
At least I hope so
chris n is offline
Old 08-21-2007, 10:19 AM   #8
bujaly's Avatar
Re: After Sanding..
I am baffled... I'll have to try a small area first...
bujaly is offline
Old 08-21-2007, 12:11 PM   #9
Mike Finley's Avatar
Trade: Bathroom Remodeling
Rewards Points: 2,000
Re: After Sanding..
We put a fan in the window, close or tape the door shut with plastic, put on a dust mask and blow the dust off the walls with the compressor. In our situation this is ideal because of order of steps that we do things.
Mike Finley is offline
Old 08-21-2007, 12:48 PM   #10
boman47k's Avatar
Rewards Points: 2,006
Re: After Sanding..
I might brush the heaviest part then go back with a damp rag for tacking purposes. I do not do a vigorous brushing for fear of having too much linger in the air then settle back where it does not belong.
boman47k is offline
Old 08-21-2007, 12:53 PM   #11
Tom M's Avatar
Rewards Points: 3,000
Re: After Sanding..
I'll do a once over with brush attatched to a vac. Im digging the idea of air compressor power but I can picture the tornado cloud of dust and could only imagine it spreading to worse places.
Tom M is offline
Old 08-21-2007, 12:58 PM   #12
kgphoto's Avatar
Trade: Residential Remodeling
Rewards Points: 250
Re: After Sanding..
I brush down the walls with a broom. Then spray a fine mist of water in the air from a spray bottle to knock down the dust in the air. Then I open a window and use a fan to exchange the air. Only takes a few minutes.
kgphoto is offline
Old 08-21-2007, 01:33 PM   #13
oldrivers's Avatar
Rewards Points: 522
Post
Re: After Sanding..
At least I hope so
well the painter in wich i am not can do what he wants after im done but i dont wipe the dust off myself.
Old 08-21-2007, 03:07 PM   #14
Capt-Sheetrock's Avatar
Trade: Drywall
Rewards Points: 250
Re: After Sanding..
I don't worry about the dust, I spray the primer on, and then back roll it. Dust isn't a problem when you do it that way, and by back-rolling the primer, you take care of the problem of the mud and paper not having the same texture (seeing the joints through thinned down primer that has been sprayed on and not back-rolled)
99% of painters disagree with this, because they are gonna thin their primer, and they ain't gonna back-roll the walls
Capt-Sheetrock is offline
Old 08-21-2007, 03:41 PM   #15
bujaly's Avatar
Re: After Sanding..
Back roll it?? Haven't heard of that. What is that exactly?
bujaly is offline
Old 08-21-2007, 09:21 PM   #16
theworx's Avatar
Re: After Sanding..
Have never wiped walls after sanding (big buildups only). A good heavy coat of primer will soak it all up. After priming, the walls should be sanded anyway - so any slight fuzz will be eliminated before finish coats. Most residential guys spray primer and for the best results they backroll... Oh yeah, you asked about backrolling!!! That's when you give a wall a heavy coat with the sprayer and before it dries you quickly go over it with a roller (gives it slight texture)...
theworx is offline
Old 08-21-2007, 09:49 PM   #17
bujaly's Avatar
Re: After Sanding..
OK... Gotcha!!
BUT, do they roll it with a wet roller of the primer or a dry roller??
bujaly is offline
Old 08-22-2007, 12:42 AM   #18
Nigel S. Shorts's Avatar
Trade: Wallpaper Whisperer
Rewards Points: 75
Re: After Sanding..
Hoooolllly CRAP! I'm beginning to feel vindication for my hard line stance about priming my own walls for wallpaper. No offense meant, but paper dries harder than paint, pulling on the surface like nothing else. It seems like any loose stuff (dust in this case) that lies under the primer coat is a candidate for adhesion problems. I don't feel confident at all that the primer will bond all that up when you apply it by back rolling after spraying, or any other method.
Nigel S. Shorts is offline
Old 08-22-2007, 04:18 PM   #19
Trade: Drywall
Rewards Points: 250
Re: After Sanding..
Nigel
by backrolling it, the dust is removed,or re-mixed or whatever it is. the roller gets it wet and it then becomes drywall mud again.
About backrolling, I use a 1" knapp roller, get it saturated, I spray it full of paint, and roll it on the wall until is sturated. I spray the wall ahead of another guy who rolls the wall. Its simple and effective and fast.
As someone else mentioned, You should be lightly sanding between coats of paint anyway. But if you do it like this, there are no "furries" after the primer coat
Old 08-24-2007, 09:51 AM   #20
Brocktologist llc.
Brockster's Avatar
Trade: drywall
Rewards Points: 250
Re: After Sanding..
I'm new around here but here goes, I use a sponge type wringer mop and dip it in a bucket of water and wring it halfway out and mop along all seams and corners putting the mop half on the mud and the other on the drywall.
Doing this help in two ways; first it removes the dust and second it pushes down any fuzzed paper from sanding. In my experience you can have a perfect seam but if you have fuzzed up the paper from sanding you will always see the seam. I can 'mop' a whole house down in just a few minutes. It also makes touch up easier since all the dust is gone...
Brockster is offline
Sanding Sealer plumbco Painting & Finish Work 18 01-05-2013 08:48 AM
Sanding sealer help birdog Specialty Coatings 5 07-11-2007 08:05 PM
Drywall Sanding Sponges? Abrasive Dan Drywall 6 06-14-2007 04:35 PM
Drywall Sanding Price per Board sandman Drywall 3 12-10-2005 05:21 PM
Sanding Nighmares drunkrussian Flooring 4 11-09-2005 06:34 PM
