Adding Bonder To Readymix? - Drywall - Contractor Talk
Old 12-19-2010, 08:29 AM   #1
Big Shoe's Avatar
Rewards Points: 2,066
Going to be floting/skimming over 1000' of walls with heavy splatter texture and and very clean latex satin paint on it.
1st coat with 90 makes sense to me. But what about adding a bonding agent to ready mix?
Or rolling a bonder on the walls prior to ready mix?
My gut says 90 min 1st coat. Never tried the other ways.
What say you?
Happy Holidays
Big Shoe is offline
Old 12-19-2010, 08:43 AM   #2
Muddauber's Avatar
Trade: drywall
Rewards Points: 250
Re: Adding Bonder To Readymix?
What say you?
Happy Holidays
I say use 90. Ready mix will shrink requiring more coats to get a smooth wall.
Muddauber is offline
The Following User Says Thank You to Muddauber For This Useful Post:
Big Shoe (12-19-2010)
Old 12-19-2010, 09:00 AM   #3
Ashcon's Avatar
Trade: Renovation contractor, finish carpenter
I have never tried it in the situation you have but I have an old school
painter that swears by weldbond. He will mix it into paint, primer, or roll it
on a wall where proper adhesion might be questionable. I've never had a
call back on any of the jobs he's done for me.
I don't know how to post a link but it is a white glue similar to regular carp
glue. Good luck
Chad
Ashcon is offline
The Following User Says Thank You to Ashcon For This Useful Post:
Old 12-19-2010, 11:22 AM   #4
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Just like adding primer to paint before you paint the walls adding pva to products before you apply them does nothing. The pva has to be added to the surface first for it to work.
I use it for everything from concrete patch work to tiling and painting walls.
You can mix a diluted 1:1 pva to concrete to help adhere to the pva coating on the wall though. I have never tried that as just the pva on the wall was enough to get me good Adhesion.
www.bcconstructionllc.com
BCConstruction is offline
The Following User Says Thank You to BCConstruction For This Useful Post:
Old 12-19-2010, 03:16 PM   #5
flippinfool's Avatar
Trade: Home Improvement contractor
Rewards Points: 113
What say you?
Happy Holidays
When you say ready mix do you mean ready mix mud ? This may help. I use it mixed into my ready mix mud with all my tape/first coats.
http://store.straitflex.com/product_...straitflex.com
This may be what your looking for to add for better bonding.
Thanks for your help in the past with that red paint issue.....
flippinfool is offline
The Following User Says Thank You to flippinfool For This Useful Post:
Old 12-19-2010, 07:48 PM   #6
Big Shoe's Avatar
Thanks Flip. I'm talking bucket mud, we call it ready mix here. I knew straightflex made that stuff. Was given some to try a few yrs back and never tried it. Don't know why.
I'm going to go with 90 min durabond for 1st coat. Tried and true in the past. I was just thinking outside the box......thinking of a way to use bucket mud. I was tempted with this one.
Actually all these yrs of doing this, never had any mud not bond.These walls are really clean and I don't see any problems with the mud sticking.
Thanks guys.
Big Shoe is offline
Old 12-21-2010, 01:04 AM   #7
Rouerplastering's Avatar
Trade: plastering and sheetrocking
Rewards Points: 75
There is no need to use bonding agent with durabond products. I mix 90 in with veneer plaster and go right over it. You could use bonding agent, I like the quikrete brand ($13 a gallon). If you mix your 90 with x-calibur or diamond you will get much better results, depending on the texture you are going with. The plaster will have more "body" to it and and will build up better to go over that heavy splatter. I mix it about 90% plaster and 10% 90.
Rouerplastering is offline
The Following User Says Thank You to Rouerplastering For This Useful Post:
Big Shoe (12-21-2010)
Old 01-07-2011, 11:22 AM   #8
seattlepainting's Avatar
Trade: Painting Contractor
Rewards Points: 75
good post you guys..
John Q. Shearer
Seattle Painting, Seattle House Painting, Commercial Painting
seattlepainting is offline
Bosch Jobsite 4100 TS worth adding the extensions? Andrew M. Tools & Equipment 8 02-05-2010 08:49 PM
Thinking Of Adding Another Product KevinD Business 2 02-01-2010 06:52 PM
adding GFI's AustinDB Electrical 4 12-02-2008 10:12 PM
adding 12" to casions Jarrow General Discussion 5 08-18-2008 11:02 PM
adding 12" to casions Jarrow Construction 0 08-18-2008 05:48 AM
