Above Shower/tub Surround... - Drywall - Contractor Talk
Old 02-09-2013, 11:43 PM   #1
true north54's Avatar
Trade: gen. contractor/ carpenter
Rewards Points: 25
A buddy of mine asked me to come over and look at his bathroom. He has a standard tub/shower surround with drywall ( greenboard) above. As you can see in the pics he has an issue. My question is, when he replaces this board with new, is there a different type of board he should use? Tile is out of the question.when done properly, shouldn't the greenboard hold up? Also, his bathroom has NO exhaust fan. Moisture just builds like crazy. I am installing one for him tomorrow. I don't know how it passed code. That house is 6 years old. Any professional drywalling tips I could pass along to him would be helpful.
Thanks all.
above shower/tub surround...-forumrunner_20130209_233226.jpg
Click image for larger version
true north54 is offline
Old 02-09-2013, 11:49 PM   #2
pro
country_huck's Avatar
Trade: Capenter/ Remodeler
Rewards Points: 768
Re: Above Shower/tub Surround...
Is that a window above that.
Nathaniel Huckins (huck)
Facebook
country_huck is offline
Old 02-10-2013, 12:01 AM   #3
Rewards Points: 25
Yes, but I checked that out when I knocked a hole to investigate. I thought maybe the window was leaking, but it's sealed up tight. I know if I was to do this bathroom, I would have chalked around the surround, which wasn't done. Maybe moisture got behind the paint and paper and made it curl? The rest of the wall was good. It was just that one inch that deteriorated. I tore all the board out around the tub. No mold, not moisture on the back.
Old 02-10-2013, 12:07 AM   #4
Jeff
jkfox624's Avatar
Trade: master turd burglar
Rewards Points: 502
Just my 2 cents but i never run the drywall tight to the surround. Run a tear away bead around the surround, leave it 1/8 or so away from the surround. Then caulk it in. Your always gonna have some moisture on the top ledge whether its condensation or someone tall getting splash back. The bead with caulk helps protect the bottom edge of the rock that's sure to get some moisture and go to hell.
jkfox624 is offline
The Following 4 Users Say Thank You to jkfox624 For This Useful Post:
Daveylad (02-10-2013), Henn Drywall (02-16-2013), thezoo (02-11-2013), true north54 (02-10-2013)
Old 02-10-2013, 12:18 AM   #5
Rewards Points: 25
I like that idea. I figured that's what drywallers did. I'll pass the word along. Thanks for the help!!!
Old 02-10-2013, 12:45 AM   #6
pibe's Avatar
Trade: drywall
Rewards Points: 93
If the rockers dont board it tight to the tub some finishers pre fill the gap and flat tape it.
Just another option for you to think about.
pibe is offline
Old 02-10-2013, 06:31 AM   #7
Remodeler
TAHomeRepairs's Avatar
Rewards Points: 574
Ate you serious? You guys do tub surrounds with green board and protect it with only paint??? Is that streak of rust from the steel corner bead in the Pic?
TAHomeRepairs is offline
Old 02-10-2013, 07:09 AM   #8
Remodeler
Rewards Points: 574
Oopsie
Old 02-10-2013, 11:07 PM   #9
Boondockian
Dustincoc's Avatar
Trade: Getting the job done
Rewards Points: 1,018
GP Densearmor Plus - Water beads up on the surface instead of soaking in. The only problem I've found with it is that the surface has fiberglass in it so, unpainted, it irritates my skin.
In the words of General James Mattis: "Be polite, be professional, but have a plan to kill everybody you meet."
Captain Howdy: We must all go through a rite of passage, and it must be physical, it must be painful, and it must leave a mark.
Dustincoc is offline
Old 02-11-2013, 07:43 AM   #10
boman47k's Avatar
Rewards Points: 2,006
Looks like more than 1" is failing.
The top of the surround was not caulked?? If that is the case,imo, the rock is wicking water that gets on the ledge of the surround and water that runs down the rock to whatever gap there is. Some will be caught by and wicked up by the raw rock edge.
The relatively large flat area of the window bottom also concerns me. since moisture will collect there.
And I would say yes, that is rust running down the wall. Metal roll-out window?
If I fall dead, I hope I fall off a ladder, not this couch.
boman47k is offline
Old 02-11-2013, 07:53 AM   #11
Rewards Points: 25
I tore out the entire tub surround, all the drywall around it as well. The rust is from a razor or something left on the window ledge. Being a nice guy and a good friend, I have a pallet of tile in my shop that I haven't touched in awhile. I gave it to my friend and he is going to turn the tub into a shower. That window is a concern for me as well. The entire neighborhood has this windows in the bathroom...
Old 02-11-2013, 10:44 AM   #12
11678's Avatar
Rewards Points: 250
Rust = steel window(?) = single pane glass (?) = cold glass + hot water vapor = 6 years of condensation. JMHO
Code says a bath with window needs no mechanical ventilation.
11678 is offline
Old 02-11-2013, 01:36 PM   #13
Rewards Points: 25
This is the corner bead from the window sill. The window is a dbl pane casement. No leaks and it didn't have any draft.
above shower/tub surround...-forumrunner_20130211_133602.jpg
Old 02-11-2013, 01:47 PM   #14
Rewards Points: 25
I've been told no good deed goes unnoticed. The friend I am helping out was talking to his neighbor about the problems in the bathroom. His neighbor called me today and wants a quote to remodel his bathroom. Perfect timing too. I'll be getting a few weeks off after Wednesday.
The Following User Says Thank You to true north54 For This Useful Post:
Tom Struble (02-11-2013)
Old 02-11-2013, 02:34 PM   #15
CraftyJT's Avatar
Trade: General Construction
Rewards Points: 75
when ever I do any DW in a bath I use plastic corners. never had a problem with damage or rust.
jt
CraftyJT is offline
The Following 3 Users Say Thank You to CraftyJT For This Useful Post:
jkfox624 (02-11-2013), TAHomeRepairs (02-11-2013), true north54 (02-11-2013)
Old 02-11-2013, 02:42 PM   #16
Rewards Points: 25
I've never hung De. I know my strengths and that's not one of them. My DW guy up here was astonished when I showed him pics of this bathroom. I was told by another guy in the neighborhood that this particular house was built pretty fast. You can tell. Just sad to see a buddy have to go through this.
Old 02-11-2013, 03:38 PM   #17
Talking Head
EthanB's Avatar
Rewards Points: 290
I use non-paper faced gypsum panes, e.g. Densarmor, on any panels that are near the tub or shower. I usually do it for the whole wall to eliminate backer transitions. It would be good for that type of issue but a good drywall install with caulking and appropriate primer/paint would be fine.
I don't use greenboard at all. Hasn't it been proved enough times that it basically a gimmick?
Planer.....
EthanB is offline
The Following User Says Thank You to EthanB For This Useful Post:
Old 02-11-2013, 03:51 PM   #18
pro
Rewards Points: 768
You would be surprised how many people still don't know. I hear it from homeowners to contractors alike.
Facebook
The Following User Says Thank You to country_huck For This Useful Post:
Old 02-11-2013, 04:17 PM   #19
Rewards Points: 25
I was always taught to use it. Again, I don't do DW. I have always had someone else do it. I just got comfortable enough to do tile work. I will check into that EthanB. I knew there had to be something better then whats there now.
Old 02-11-2013, 04:29 PM   #20
Talking Head
EthanB's Avatar
Rewards Points: 290
It's a lot more money. I think that's why HO's and contractor's alike don't use it and why the lumber yards aren't bringing it in. I had a hell of a time getting it around me until I finally cornered the rep for my yard. I don't use enough for them to bring it in but I pointed out that they sell tons of a product that doesn't work for $10 a sheet when they could be selling the RIGHT product for $30 with a bit of customer education.
Who the hell want's to put the wrong material in a bathroom to save less than $100? Aside from hacks of course.
Planer.....
EthanB is offline
need advice on installing vinyl surround Laketahoedan Kitchens & Baths 3 10-07-2010 06:46 AM
Tile surround rehab izzy Flooring 5 09-21-2010 01:53 PM
from tile to vinyl surround and the valve Laketahoedan Plumbing 7 09-18-2010 01:18 PM
Using Regular Liquid Nails on a Tub Surround Second Look Remodeling 5 10-30-2008 06:18 PM
tub surround hydrology punkab Tiling 8 10-13-2008 08:21 AM
