1/4" Over Popcorn - Drywall - Contractor Talk
1/4" Over Popcorn
Old 06-22-2012, 10:03 AM   #1
stillstoked's Avatar
Trade: general contractor
Rewards Points: 25
1/4" Over Popcorn
I have a guy that wants me to put 1/4 drywall over (under) a pop corned ceiling. I don't think its a good idea, thinking it will be uneven at best. I do not do much drywall, so I've never done that. I'm thinking the popcorn should be scraped off first.
Anyone have any experience with doing this? Anyone have any thoughts?
I know some one has an opinion, care to share it?
stillstoked is offline
Old 06-22-2012, 10:56 AM   #2
aptpupil's Avatar
Rewards Points: 1,894
Re: 1/4" Over Popcorn
wet it down and scrape it off. not a bad idea to get it tested first.
clean the ceiling, texture, prime, paint.
aptpupil is offline
The Following 4 Users Say Thank You to aptpupil For This Useful Post:
Big Shoe (06-23-2012), hdavis (06-22-2012), Osito (06-23-2012), Sir Mixalot (06-22-2012)
Old 06-22-2012, 11:37 AM   #3
hdavis's Avatar
Rewards Points: 5,626
If you put 1/4" on a ceiling, you have to bond it to what is there already, or it WILL sag, To get a decent bond, you may have to take the popcorn off (depends on how well it's stuck on). Even if you leave it on and can get a good bond, you're going to be going over an uneven surface. That's a lot of time and money to get a crappy job.
hdavis is offline
Old 06-22-2012, 02:43 PM   #4
rjconstructs's Avatar
Trade: Residential remodel
Rewards Points: 218
Don't do it.
rjconstructs is offline
Old 06-22-2012, 07:04 PM   #5
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 3,431
Scrape it. Skim (if needed), texture, apply stain blocking primer and paint.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 53,000 Subscribers and over 9,500,000 Views
https://www.youtube.com/paulpeck
Twitter Facebook Google+ Instagram
Sir Mixalot is offline
Old 06-22-2012, 07:34 PM   #6
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,450
Oh my, hanging and finishing would be WAY more work than just scraping and skimming. Wetting it down it comes down in sheets and the rock is usually pretty darn smooth.
SuperiorHIP is offline
Old 06-23-2012, 04:38 AM   #7
Big Shoe's Avatar
Rewards Points: 1,972
If I've said it once I've said it a thousand times............1/4'' is not the magical cure!!! especially on ceilings.
It is not strong enough, it will sag , screws will pop. If your going to double up on a''textured'' ceiling at least use 1/2'' for rigidity/strength. And will finish nicer.
Expect the Unexpected
Big Shoe is online now
The Following User Says Thank You to Big Shoe For This Useful Post:
iDAHOchris (06-24-2012)
Old 06-24-2012, 08:00 AM   #8
iDAHOchris's Avatar
Trade: dRYWALL SPECIALIST
Rewards Points: 256
1/2
' or 5/8
' Scraping can get real messy and does damage surface, not to mention the chitty tape job covered up by popcorn. Lower light fixtures, mark ceiling joists (studs) and put a new layer. If I have a choice I will take the overlay over the scrape. 48 sf' of new rock at say 11 to 14 bucks a sheet..... cheaper and better to go with new rock
iDAHOchris is offline
Old 06-24-2012, 10:10 AM   #9
King of Caulk
asbestos's Avatar
Trade: Rot warrior
Rewards Points: 170
Absolutely in this state (WA) you are required to know enough to know that there are things that may need to be tested before you start a job. If you go and scrape that stuff and it has asbestos in it, you're up $41t creek.
It also makes a huge mess.
I am the Sultan, The Sultan of sealants
asbestos is offline
Old 06-26-2012, 10:02 AM   #10
Rewards Points: 25
thanks a lot guys. the house is not that old. (90's) so i think i will scrape and see what that looks like then if I have to i'll use 1/2".
The Following 2 Users Say Thank You to stillstoked For This Useful Post:
Big Shoe (06-27-2012), hdavis (06-27-2012)
Old 08-10-2012, 03:15 PM   #11
ToolNut's Avatar
Trade: Painting & repairs
Rewards Points: 508
i do a lot of popcorn removal its really pretty easy. take a garden pump up sprayer, probably 2 gal, fill it with water add 1/2cup fabric softener. spray the ceiling let set for about 15 minutes, then spray again. remember you just want it damp, not wet. Then scrap with a 6 inch knife, no bigger because if you look down the edge of a big knife you will see it has a curve, that will make the corners dig in and make repairs more and harder. Spray occasionally as you work. With this method you will get very little dust. Hope this helps
ToolNut is offline
Old 08-10-2012, 03:40 PM   #12
I use my airless sprayer to spray the water on the ceiling.
+ YouTube Video
-Paul
TextureMaster.com
Old 08-10-2012, 03:55 PM   #13
ToolNut's Avatar
Rewards Points: 508
I tried that once but it seemed like i got to much water. Probably wrong tip. just watched video great job
ToolNut is offline
The Following User Says Thank You to ToolNut For This Useful Post:
Sir Mixalot (08-10-2012)
Old 08-10-2012, 07:08 PM   #14
scottktmrider's Avatar
Trade: carpenter/drywall
Rewards Points: 295
Will this work if the popcorn has been painted over?
scottktmrider is offline
Old 08-10-2012, 07:15 PM   #15
ToolNut's Avatar
Rewards Points: 508
no if painted whole new ballgame
ToolNut is offline
Old 08-10-2012, 07:28 PM   #16
Yes, it just takes more time and elbow grease.
I dry scrape a 4'x 8' section, then wet it a couple times. If all else fails, Skim it.
-Paul
TextureMaster.com
Old 08-10-2012, 09:26 PM   #17
Rewards Points: 295
Are you saying to skim coat rite over the popcorn?
Old 08-10-2012, 09:35 PM   #18
Scrape what you can off, then skim.
-Paul
TextureMaster.com
popcorn ceiling removal/painting artinall Painting & Finish Work 14 09-07-2010 01:38 AM
Popcorn Texture over Concrete AM1965 Drywall 14 04-15-2010 10:51 AM
Boy Scouts selling popcorn dayexco Off Topic (Non Trade) 22 10-09-2009 08:40 AM
popcorn ceiling disaster lornmastro Painting & Finish Work 40 03-29-2009 08:17 AM
how to get a great look after removing popcorn c.c.co. Drywall 18 12-15-2008 06:02 PM
