Yup...wood Fired Oven - Page 8 - Masonry - Contractor Talk
Old 05-24-2015, 07:04 PM   #141
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
Re: Yup...wood Fired Oven
Originally Posted by dom-mas View Post
My mix is roughly (just use shovels) 1:2.5 JBM, it gets hard but takes a good week. I give it a spray every day, even a few times a day at first, the first batch was done when it was still fairly cool, between 5-10c/40-50F during the day and a little less but not too close to freezing during the night, and damp too from the snow having just melted off the bricks, and the ground still being wet etc...that batch took over a week before it was cured enough that it could take a real spraying. the batch i did yesterday is pretty stiff but I'm sure if I popped a brick off the mortar in the frog would come back if I added water. I'm also sure that if I hit the joints with the hose on jet the joints would get eaten away pretty quick...but not the joints I did week before last
We used this mix back in school for our projects. After we finished with it and dissembled the brickwork, we take it off the brick with a single blow of the trowel (per side) and off to be recycled in the 2 man roll sieve. It smashed up pretty easy no matter how old it was and we screened it through the sieve which had a large vacuum hood to catch the dust.
The remaining product (powder) was housed in a block wall container and then wheeled over to the mixer as necessary to make new mud.
Off course during breakdown day, if the teacher left the shop for a awhile..."mortar fight', every man for himself
That stuff will leave nasty welts on your head if hit from afar
supersealconstruction.com
superseal is offline
Old 05-24-2015, 07:35 PM   #142
CJKarl's Avatar
Trade: Masonry
Rewards Points: 3,926
Love that sawtooth\dogtooth detail. I tried to do it on my own chimney 20 some yeara ago, but I was inexperienced and pressed for time.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 05-24-2015, 10:19 PM   #143
stonecutter's Avatar
Trade: Stonemasonry
Rewards Points: 2,356
Originally Posted by heavyc View Post
What is dog tooth? Even when in upstate N.Y. we call it saw tooth. Never heard the dog tooth terminology. Just wondering if they are two different methods or the same, just different names?
Regional terms but interchangeable apparently.
www.thewoodfiredenthusiast.com
stonecutter is offline
Old 05-25-2015, 06:22 AM   #144
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
I thought one brick/header in one out was dog tooth. Bricks where corners are at 45°of wall every brick saw tooth?
I think what you're describing is dentils, like teeth. Common throughout architecture, wood working, plastering etc...
www.dominionmasonry.ca
dom-mas is offline
The Following User Says Thank You to dom-mas For This Useful Post:
cdkyle (05-26-2015)
Old 05-25-2015, 06:26 AM   #145
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
If I take the mortar i laid a few weeks ago and throw it in a pail of water it wouldn't break down....unless I took a hammer to it. when i was in school we used just lime as well, but if more than a week went by we'd make a new mix. I wish I knew how to make videos, I've got a few blobs on the pad that are quite hard
dom-mas is offline
Old 05-25-2015, 08:19 AM   #146
heavyc's Avatar
Trade: masonry
Rewards Points: 945
British Wikipedia confirms my belief.
Dog tooth one header in one header projected out.
Saw tooth headers projected at 45° angle to the wall.
Had to call and confirm with my Dad. 55 year veteran retired out of local#1 Buffalo.
heavyc is offline
Old 05-25-2015, 04:14 PM   #147
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Ibstock disagrees
dentils= alternate headers projected
dog tooth = bricks laid at 45* with the head exposed
dom-mas is offline
Old 05-25-2015, 09:13 PM   #148
heavyc's Avatar
Trade: masonry
Rewards Points: 945
Glossary of British brick laying clearly calls each out as I stated. No big deal I guess we studied the British glossary in our line of masons. Kinda confusing how an encyclopedia wouldn't have the most accurate information?
heavyc is offline
Old 05-25-2015, 09:34 PM   #149
Trade: Stonemasonry
Ibstock disagrees
Exactly...
page 4....http://www.gobrick.com/portals/25/do...0notes/tn2.pdf
UK site...http://moodle.sbc.ac.uk/sharedConten...20Features.pdf
Old 05-25-2015, 09:50 PM   #150
heavyc's Avatar
Trade: masonry
Rewards Points: 945
Originally Posted by stonecutter View Post
Go to Home depot Web site for do it yourself masonry and type in saw tooth border then add that link to your next post? Better yet might want to inform them and other information sources that they are providing false information?
heavyc is offline
Old 05-26-2015, 07:19 AM   #151
Smarter than the brick...
Kniggit's Avatar
Trade: Masonry
Rewards Points: 561
We always called the ones at an angle a sawtooth, the alternating protrusions we always called a dental block....didn't know there was a fancy spelling for it until this thread.
Kniggit is offline
The Following User Says Thank You to Kniggit For This Useful Post:
heavyc (05-26-2015)
Old 05-26-2015, 05:19 PM   #152
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Different regions different terms. We had this discussion last year sometime with the hidden bond/secret bond/ clipped bond. Only thing that's important is that you know what's spec'd in the drawings and that you and the customer/GC/architect are all on the same page. For this project I am builder/customer/architect so I'm mostly on the same page with myself in many of the important matters...other matters not so much
dom-mas is offline
brickhook (05-27-2015)
Old 05-27-2015, 09:54 AM   #153
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
Since this is as good a thread to ask as any, where do I get the thermometer that can be built into the ovens?
JBM is offline
Old 05-27-2015, 10:54 AM   #154
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Do you have a store that specialises in grilling and barbecue etc...they should have one.
I think I'm going to get a heat gun, like they use in automotive. Fairly cheap at Princess Auto/Harbour Freight and you can get a reading of the walls, the floor the top of the dome whatever. Accurate as well
dom-mas is offline
Old 05-27-2015, 05:20 PM   #155
Tscarborough's Avatar
Rewards Points: 1,460
The reality is that you only need a temperature reading while you learn to use the oven or to impress your friends. The cheapo IR gun is just fine for that.
Tscarborough is offline
Old 05-27-2015, 06:18 PM   #156
Trade: Stonemasonry
I don't really care that much, I thought I'd post those links to show that other sources have other names for the same detail. Home Depot huh?
Old 05-27-2015, 06:38 PM   #157
Local terms do differ, but there is a specific language used by architects across the world to define certain architectural details. Note that I said "architectural" twice, since that is what we are discussing, an architectural detail. This question was already determined at least as far back as the first century, although I bet it goes back a millennia further at least.
Vitruvious said (Chapter V, Section 11), "...is apportioned so that the face of each dentil is half as wide as its height and the cavity of each intersection two thrids of this face in width". "Dentil" itself means "tooth", not "sawtooth".
The sawtooth detail does not go back so far, mostly being a function of Victorian brick detailing (the Romans almost always covered brick with stucco, so it wasn't normally used to create details), but prima facie, it most resembles the teeth of a sawblade)
The Following User Says Thank You to Tscarborough For This Useful Post:
heavyc (05-27-2015)
Old 05-27-2015, 07:16 PM   #158
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Not quite. Dogtooth is a very old style, and is applicable to ANY triangular projection in a series, usually in a moulding. Outside of brickwork it is commonly found as 2 or 4 flower petals or leaves coming to a point and projecting out like this. This definition say conical but others say triangular
http://www.finedictionary.com/Dog-tooth.html
The only way to do this with regular brick is to lay the brick at a 45
so maybe it's a sawtooth version of a dogtooth. Whatever
And a dentil is a dentil no matter the proportion. You can find dentils of varying proportions throughout architecture from ancient times to modern. Interesting to note that their occurence is most likely from the original Greek temples that were built of wood. the roof timbers were visible and looked like teeth. When the stone temples were built to mimic the wood ones the detail was called dentils
dom-mas is offline
heavyc (05-27-2015)
Old 05-27-2015, 07:22 PM   #159
I misunderstood, I thought we were talking about sawtooth VS dentil, not sawtooth VS dogtooth.
dom-mas (05-27-2015)
Old 05-27-2015, 07:28 PM   #160
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Yeah, dentils being called dogtooth is interesting, I'd never heard of it but it's what it's called by some. A quick google search brings it up a few times
dom-mas is offline
Why is wood rotting ? SKC Construction 47 05-27-2018 04:50 PM
Wood Windows -- PlyGem Baltimore Carpentry 8 03-05-2014 10:12 PM
wood blasting ratherberacin Sandblasting 8 10-15-2012 05:48 PM
going over existing wood shakes davinci Windows, Siding and Doors 33 07-08-2012 07:09 PM
Cabinet for built-in oven mattsk8 Finish Carpentry 10 03-15-2010 11:14 PM
