Working On Slate/terra-cotta - Masonry - Contractor Talk
Old 04-07-2019, 08:05 AM   #1
Confluence's Avatar
Trade: Masonry/Restoration
Rewards Points: 32
Hey Fellas,
I am interested in talking about methods for working on slate or terra-cotta roofing.
We have been very lucky with reaching repair areas without needing to step foot on fragile roofs.
This weekend we looked at a few chimneys that I would like to take on, but cannot tear up the yard with a lift/machine. Both Chimneys are on old slate.
I know some guys are great at walking fragile roofs, but the risk is far from the reward in this one.
I am open to hearing any and all methods. Crazy or not!
Confluence is offline
Old 04-07-2019, 09:54 AM   #2
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,248
Re: Working On Slate/terra-cotta
You can walk up slate on a roof ladder, but if you are doing a lot of work on the chimney I would set up a scaffold.
stuart45 is offline
Old 04-07-2019, 11:53 AM   #3
Confluence's Avatar
Rewards Points: 32
Unfortunately both chimneys are in the middle of the roof. We have gotten away with scaffolding and machines at this point.
Will hook ladders do the trick?
Old 04-07-2019, 12:40 PM   #4
stuart45's Avatar
Trade: Brickwork
Hook ladders will work, and special chimney scaffs are usefull.
https://www.ebay.co.uk/i/291532973345
stuart45 is offline
The Following User Says Thank You to stuart45 For This Useful Post:
fjn (04-07-2019)
Old 04-07-2019, 01:09 PM   #5
fjn's Avatar
Trade: mason
Rewards Points: 11,202
I do it with ultimate ridge hooks and the chimney scaffold brackets from lynn ladder company. I put sheets of 2" high density extruded foam beneath the ridge hook lumber to spread / cushion the weight. Will try to get connections to those tools posted.
fjn is offline
Fouthgeneration (04-13-2019)
Old 04-07-2019, 01:12 PM   #6
fjn's Avatar
Trade: mason
Better yet, a video.
One down,one to go. Chimney scaffolding next.
fjn is offline
Old 04-07-2019, 01:15 PM   #7
fjn's Avatar
Trade: mason
Chimney scaffolding
https://www.lynnladder.com/products/...LD-FRAMES.html
fjn is offline
stuart45 (04-07-2019)
Old 04-07-2019, 06:47 PM   #8
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,446
Here is a bad shot of chimney scaffold in action
Chimney through the middle of the roof
Windycity is online now
The Following User Says Thank You to Windycity For This Useful Post:
Confluence (04-09-2019)
Old 04-09-2019, 08:39 AM   #9
Confluence's Avatar
Rewards Points: 32
Looks like a fine photo to me! I am in south west PA. If anyone has any suggestions on who to get the chimney scaffolding and hook ladders from, I am all about new suggestions. We often go to Bon Tool. Itís not too far.
Old 04-11-2019, 04:08 PM   #10
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
I just keep driving...
JBM is offline
Old 04-13-2019, 06:16 AM   #11
Confluence's Avatar
Rewards Points: 32
Comedy or wisdom. Why not both?
The Following User Says Thank You to Confluence For This Useful Post:
JBM (04-14-2019)
Old 04-13-2019, 11:59 PM   #12
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,403
You can Saw two older frames(even brand new ones,to save 100s of $ in time) to match the roof pitch then make or buy some pivoting baseplates to screw to the sleepers.
Or purchase several sets of System scaffolding "monkey" fist clamps to make the necessary angled frame from scaffold sized piping.
Make sure the service tower is built to take all the side thrust of the sloped dunnage/sleepers, and all pins are installed in all connections(nipples).
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
fjn (04-19-2019)
Help on working in the USA Simon1010 Help Wanted or Looking For Work 18 06-22-2011 04:25 PM
working solo FRAME2FINISH General Discussion 17 06-16-2011 04:18 PM
Pretty tough working conditions, don't ya think? pinwheel General Discussion 13 05-10-2011 12:37 AM
Thoughts on Working with a Public Adjuster? HammerUrHouse Business 1 03-23-2011 01:42 PM
Working (not) with Illegal Contractors RenaissanceR General Discussion 11 06-23-2007 12:34 PM
