The Wood-fired Oven Thread - Page 26 - Masonry - Contractor Talk
Old 12-23-2014, 10:43 AM   #501
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: The Wood-fired Oven Thread
That looks reeaaallly good. Not much I like better than warm bread with melting butter
www.dominionmasonry.ca
dom-mas is offline
The Following 2 Users Say Thank You to dom-mas For This Useful Post:
brickhook (12-23-2014), stonecutter (12-23-2014)
Old 12-23-2014, 11:04 AM   #502
brickhook's Avatar
Trade: masonry
Rewards Points: 7,586
dom-mas, have you had a chance to work on your oven?
brickhook is offline
Old 12-23-2014, 11:07 AM   #503
stonecutter's Avatar
Trade: Stonemasonry
Rewards Points: 2,356
Too bad there's no such thing as smellivision.
www.thewoodfiredenthusiast.com
stonecutter is offline
The Following User Says Thank You to stonecutter For This Useful Post:
Old 12-23-2014, 11:28 AM   #504
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
I have it closed in, that's about all. I need to build the face because I have to corbel out some to have enough depth for a decent throat and landing. I've faltered a bit there because I don't have a finished idea of what the facing will look like...Mainly where to stop the stone and start the brick and what type of arch to do. I really should have cantilevered the pad instead...At least then I could have made it functional. Spring time is coming.....we're passed the shortest day so it should be here any minute right?
dom-mas is offline
Old 12-23-2014, 12:12 PM   #505
brickhook's Avatar
Trade: masonry
I know...times flying! I'm not trying to wish my life away, but i'll be glad when spring gets here
Do you have any pictures of the progress?
Old 12-23-2014, 01:35 PM   #506
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
I could take one. Back in a flash...(get it camera...flash...huh...huh)
dom-mas is offline
The Following 3 Users Say Thank You to dom-mas For This Useful Post:
brickhook (12-23-2014), tgeb (12-23-2014), Windycity (12-07-2016)
Old 12-23-2014, 01:48 PM   #507
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Looks rough still I know. Some of these bricks have been rolling around for 7 or 8 years. Not good enough for a clients fireplace but too good to chuck
dom-mas is offline
The Following 4 Users Say Thank You to dom-mas For This Useful Post:
brickhook (12-23-2014), Captainsls (12-23-2014), Fundi (12-25-2014), tgeb (12-23-2014)
Old 12-23-2014, 02:02 PM   #508
brickhook's Avatar
Trade: masonry
Man! That's awesome Is this the first one you've built!
Old 12-23-2014, 02:07 PM   #509
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Oh yeah...can't you tell?
dom-mas is offline
Old 12-23-2014, 04:16 PM   #510
Trade: Stonemasonry
Pretty brick work or ugly brick work.....it won't matter a bit when the fires lit!
dom-mas (12-23-2014)
Old 12-23-2014, 06:17 PM   #511
brickhook's Avatar
Trade: masonry
No....not at all! I'm impressed. I only hope if I can build one, it'll turn out as well
I'm so impressed how people build the domes.
Old 12-23-2014, 06:26 PM   #512
JBM's Avatar
Trade: Masonry
Rewards Points: 10,832
Tent that in and rock it!
JBM is offline
The Following 2 Users Say Thank You to JBM For This Useful Post:
Old 12-23-2014, 07:22 PM   #513
Tscarborough's Avatar
Rewards Points: 1,460
Take your grinder and roll the edges of the upper third of the arch, it will help a lot. And it is ready for use at this point, fire it up!
Tscarborough is offline
Old 12-24-2014, 01:50 AM   #514
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Rewards Points: 786
I don't quite follow this suggestion, I would roll the bottom outside edge of the arch brick to help smooth the smoke draw, (assuming we are looking at the inner arch.) and the inner bottom edge could also be rolled for a better smoke path. I don't get what would be gained on the upper end of the arch.
Not picking a fight here, just looking to learn something.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
Old 12-24-2014, 07:40 AM   #515
We are saying the same thing: Easing the edge, inner and outer of the upper part of the arch.
The Following User Says Thank You to Tscarborough For This Useful Post:
dakzaag (12-24-2014)
Old 12-24-2014, 11:47 AM   #516
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
This one is only 1/3rd dome. the front 2/3rds is a barrel vault. I put the dome n the back to maximise space because it's a corner oven. There are 2- 8' (at the rear) legs on either side that also need material. It would be a large tent to setup at home. If this were customer I wouldn't hesitate
I have about 2 months of indoor or semi indoor work coming uo so I'm not crazy interested in tenting it. In the early spring I usually have had a few months to think up some inspiration.
My biggest issue is 4 stone that I have for quoins. A type of local brownstone that is impossible to find anymore...the quarry has been closed for 75 years or more. Problem is that I have 5 outside corners and it would be strange to have a single quoin if I just went with the 3 prominent corners.
I'll riddle it out but it will take some time
dom-mas is offline
Old 06-30-2015, 09:46 AM   #517
Trade: Stonemasonry
I broke down and bought an oven! Not sure how long we will be in our current location, so this made sense. I haven't had a chance to use it yet, but from what I've seen, it'll do the job nicely!
dom-mas (06-30-2015)
Old 06-30-2015, 11:33 AM   #518
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
I should update my thread. I've been puttering away a little at a time a few sq ft of stone or 50 bricks here or there. Need to get another bag of perlite to fiunish insulating then it will be functional at least. I've had a few fires going but only one with any hardwood, i figure there isn;t much sense in acclimatising if there's more perlecrete to pour.
And guys who have built ovens....how about doors...lets see them. I've seen SC's door and I love it, and I've seen iron doors...some I like....any other ideas
dom-mas is offline
Old 06-30-2015, 12:41 PM   #519
CJKarl's Avatar
Trade: Masonry
Rewards Points: 3,926
https://youtu.be/kh_WqdLHfw8
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 06-30-2015, 12:45 PM   #520
CJKarl's Avatar
Trade: Masonry
Poor planning on my part determined my door set up. I had built the inner brickwork way be for I did the shell. The piece or Limestone I wanted to use was only wide enough to create an opening the same as (slightly smaller actually) the inner opening. Hence the 2 piece door.
CJKarl is offline
The Following User Says Thank You to CJKarl For This Useful Post:
Thermally Modified Wood Live test results naturalwood Decks & Fencing 0 09-17-2009 06:06 PM
Commercial wood framing mckellarman Commercial Construction 2 05-06-2009 05:11 PM
LEED Certified Wood CF Construction Business 6 02-27-2009 04:45 PM
Covered Patio 10 x 10 - Should I wood block? gussy1971 Roofing 1 01-27-2009 06:19 PM
Wood floor refinishing Floorwizard Flooring 25 01-26-2009 10:17 PM
