Where To Post A Tile Topic? - Masonry - Contractor Talk
Old 01-12-2005, 11:24 AM   #1
KnightofTexas's Avatar
Is this the right forum to post a ceramic tile question?My question concerns pre-mixed grout.Is it inferior to self-mixed grout?I used it to regrout my shower and weeks later I see cracks in places.
KnightofTexas is offline
Old 01-12-2005, 11:37 AM   #2
Deck Designer/Builder
DecksEtc's Avatar
Rewards Points: 1,000
Re: Where To Post A Tile Topic?
I'd have put it in the "Flooring" forum. The flooring experts will probably pick up on it anyway.
As to your post, not sure about being inferior or not but the 2 drawbacks I'm aware of are 1. Pre-mixed costs more 2. You can't alter the consistancy if it appears too wet.
I am the liquor - Jim Lahey, Trailer Park Supervisor
DecksEtc is offline
Old 01-12-2005, 03:30 PM   #3
Mike Finley's Avatar
Trade: Bathroom Remodeling
Rewards Points: 2,000
How big were the grout lines? Sanded or non-sanded grout used? Cracked grout almost always is a result of movement of the tile or more specifically what the tile is attached to.
Mike Finley is offline
Old 01-17-2005, 10:34 AM   #4
housedocs's Avatar
Trade: Home Improvement
Rewards Points: 250
premixed grouts belong in the same category as the premixed thinsets, that would be "J" for junk!
As Mike stated most of the time cracks in grout lines is caused by movement in the base. You shouldn't use an unsanded grout if the grout lines exceed 1/8". Stick with Custom or Aqua-mix products, been using them for years with excellent results.
housedocs is offline
Old 01-25-2005, 11:14 AM   #5
Thanks.I think it was unsanded grout with some lines exceeding 1/8".
Old 02-27-2005, 02:46 PM   #6
pam's Avatar
hello, tile wall grout cracking is it it the corners only? if so thats natural--just caulk the corners,thats a must anyway. if you are experiencing all over than you probaly didn't force enough in the joints. to fix that problem gently with utility or 5 in 1 or grout scraper remove loose grout and regrout not a big deal. now if your durrock is not properly fastened thats another problem. hope this helps. and by the way i like to mix my own grout, you did use unsanded grout for the walls didn't you?
pam is offline
Old 05-11-2005, 07:56 AM   #7
Tileguytodd's Avatar
Trade: Tile & Stone Contracting
While I am in agreement that premixed products are inferior(custom CBP recently stopped manufacturing of these products)
More information would need to be provided to determine why and to give the best way to proceed with doing this repair properly.
A full description of where,what you started with,what you did to prep the area etc.With this information several folks here can give you the proper methods and materials you will need to do a good and lasting repair.
All changes of plane should be caulked and any grout removed from these joints and any others needing repair.
Tilewerks
Tile and Stone Contracting
Warba,MN 55793
Tileguytodd is offline
Old 09-06-2005, 11:09 AM   #8
HuckabayHolding's Avatar
Trade: decking
Well first let me ask you is it a sanded or unsanded grout? One of the problems could be that you're overwiping your joints if it's sanded. If it's unsanded you probably have too much water added. I recommend to about the consistancy of a brownie batter, however make sure you scratch the top layer of old grout off before you regrout, or it won't last anyway. I highly recommend you use premixed latex grout so as to not mess up the consistancy. Contractors use to only mix it themselves in the olden days when latex additives first came out, however you can still buy them that way at home stores. Any respectable tile wholesaler wont sell it separate.
HuckabayHolding is offline
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
