Water Proofing - Masonry - Contractor Talk
Water Proofing
Old 10-25-2012, 11:01 AM   #1
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
Water Proofing
Hey fellas, I've got a client that wants to update a garden wall. The wall is a 16" high slumpstone block and it wasn't water proofed when built.
Without doing anything to the back of the wall (planter side) would applying Thoroseal (2 coats), scratch, then stucco hold up??? I just got off the phone with the Thoro rep (he said yes) but he didn't sound too convincing Lookin for some real world knowledge
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 10-25-2012, 12:23 PM   #2
Tscarborough's Avatar
Rewards Points: 1,456
Re: Water Proofing
Yes, no problem at all, just note that the bond of the stucco will be no better than the bond of the Thoroseal.
Tscarborough is offline
The Following User Says Thank You to Tscarborough For This Useful Post:
Jaws (10-25-2012)
Old 10-25-2012, 01:09 PM   #3
always building
Re: Water Proofing
so are you saying that the Thoroseal bond in this application will hold up??? ....I would wire wheel/power wash prior to application
www.RDPontheWeb.com
Old 10-25-2012, 01:11 PM   #4
always building
Re: Water Proofing
I'm concerned about the possibility of hydrostatic pressure affecting the Thoroseal bond
www.RDPontheWeb.com
Old 10-25-2012, 01:40 PM   #5
always building
Re: Water Proofing
and just to clarify... I would normally excavate and waterproof from behind but the planter is stuffed to the gills with established good looking trees and shrubs.... hence this approach
www.RDPontheWeb.com
Old 10-25-2012, 02:12 PM   #6
Re: Water Proofing
Thoroseal is one of the few products designed for that application. What I meant was make sure the wall is prepped well.
Old 10-25-2012, 02:33 PM   #7
always building
Re: Water Proofing
thank you very much!
www.RDPontheWeb.com
water proofing shower pan new method srfconstruction Kitchens & Baths 32 02-03-2016 10:25 AM
Icf water proofing jeradlittle General Discussion 8 10-10-2012 07:25 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 08:48 PM
