Water In Basement - Masonry - Contractor Talk
Water In Basement
Old 04-09-2019, 09:22 PM   #1
tylermckee123's Avatar
Trade: excavation
Rewards Points: 2
Water In Basement
So i have a problem. We have a large custom home, 10' tall poured concrete walls. the walls were allowed to fully cure before we back filled, no stress cracks, a few vertical cracks from curing that were there before we back filled. the walls were professionally coated (not sure of product, thick black stuff, supposedly waterproof) and drainboard installed with the top finish strip, we back filled at least 5-6' up the wall with drain rock, 4" perf drain at the bottom. We are still getting a couple spots inside with moisture. Not really puddling water but you can see moisture and some streaking on the wall in a few locations. We havent really had this happen before. This is a very large multi million dollar custom home so any moisture is unacceptable.
Have you guys had any luck with coating the inside of the walls? I could dig up the exterior where we have moisture, but i dont understand how i could possibly have water coming in. The drains daylight and we do get water flowing out so i know we have positive drainage and plenty of drain rock around the foundation.
tylermckee123 is offline
Old 04-09-2019, 09:46 PM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 17,011
Re: Water In Basement
From my limited experience...
I don't think you can't paint over a crack with waterproofer and expect moisture and condensation to stay out. Should have had membrane applied to bridge the cracked areas.
From the inside, you can seal it with urethane crack injection, but it's going to have a scar (visible repair).
MarkJames is online now
Old 04-09-2019, 09:55 PM   #3
Trade: excavation
Rewards Points: 2
Wall was sprayed to waterproof after it had cured, the couple small vertical cracks were already there.
Crack injection is option, walls will be furred out so doesnt matter what it looks like.
Old 04-09-2019, 09:56 PM   #4
MarkJames's Avatar
Old 04-10-2019, 03:55 AM   #5
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 1,168
What type of forms were used? Did the concrete guy snap the ties off and seal them with hydraulic cement before the waterproof coating was sprayed on? Sounds to me like a drainage issue if all of the above was done correctly. What is the soil composition like surrounding the foundation? Clay or gravel, slope of the land, is it properly graded?
dave_dj1 is offline
Old 04-10-2019, 06:04 AM   #6
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,814
Grade around house should fall 6" in the first 6'. Gutters and downspouts must be installed.
Home Designer Series Software
B.Johnson is offline
The Following 2 Users Say Thank You to B.Johnson For This Useful Post:
fjn (04-10-2019), NYgutterguy (04-10-2019)
Old 04-10-2019, 06:26 AM   #7
tgeb's Avatar
Rewards Points: 436
Unless the excavator damaged the coating during backfill, I would kick the issue to the guy that installed a "supposedly waterproof" product on the wall.
I would certainly attempt to seal it from the exterior before doing anything inside.
If that means digging it up in a few places and pulling back the dimple board to see what the condition of the coating is, so be it.
www.gebcon.com
tgeb is offline
The Following 3 Users Say Thank You to tgeb For This Useful Post:
Calidecks (04-11-2019), fjn (04-10-2019), greg24k (04-10-2019)
Old 04-10-2019, 06:34 AM   #8
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Must be excavator lingo...
SmallTownGuy is offline
Old 04-10-2019, 09:09 AM   #9
Trade: excavation
Rewards Points: 2
2'x8' form panels with snap ties, waterproofed only requires the snap ties to be snapped off, and the wall/footing be clean and dry.
Soil has a lot of clay, not the best, most of the area in question was filled with 3' minus gravel. It's a large patio area so only graded at 2%.
Gutters are on, slope is 2%
Old 04-10-2019, 09:15 AM   #10
Trade: excavation
Rewards Points: 2
Was going to call the waterproofed and see what they say, they supposedly warranty their work. Not sure how that's going to work as there is about 1000 ways to shift the blame.
Excavator lingo for sure 😂, I have no idea what the product is other than its thick black, rubbery, and supposedly "waterproof"
Old 04-10-2019, 10:05 AM   #11
tgeb's Avatar
Rewards Points: 436
There are not 1,000 ways to shift the blame.
The foundation is not water tight, that is a known fact.
If the areas effected are excavated back out and there is no damage to their product, then the product or installation has failed and they need to repair the installation in a manner that maintains the warranty.
If there is damage from the backfill procedure then the excavating/backfill contractor pays to have the waterproofing company make the repairs in away that maintains the warranty.
The only other option is that the coating was damaged in some other way, I've seen lumber packages dropped against foundations, as well as other things happen that can damage a wall.
You're working on a very expensive home.....
www.gebcon.com
tgeb is offline
The Following 2 Users Say Thank You to tgeb For This Useful Post:
Calidecks (04-11-2019), hdavis (04-10-2019)
Old 04-10-2019, 11:37 AM   #12
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,430
Thats not the right term, the spray on black tar coating is not “water proof” it is damp proof
This is my foundation and the membrane that i put on is water proof
Tar coating (damp proof)
Waterproof membrane
Insulation board (another layer of protection)
Windycity is offline
The Following 4 Users Say Thank You to Windycity For This Useful Post:
finisher65 (04-13-2019), hdavis (04-10-2019), MarkJames (04-10-2019), SmallTownGuy (04-10-2019)
Old 04-10-2019, 12:23 PM   #13
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Originally Posted by tylermckee123 View Post
So i have a problem. We have a large custom home, 10' tall poured concrete walls. the walls were allowed to fully cure before we back filled, no stress cracks, a few vertical cracks from curing that were there before we back filled. This is a very large multi million dollar custom home so any moisture is unacceptable.
If water is unacceptable in this multi million dollar home,then why does it have random shrinkage cracks that were not addressed with control joints placed in their proper location during the form work ??
fjn is offline
hdavis (04-10-2019)
Old 04-10-2019, 01:03 PM   #14
hdavis's Avatar
Rewards Points: 2,124
I'm just guessing the excavator is getting some blame on this one. Nominally, it would be whoever did the "waterproofing", or whoever spec'd inappropriate materials or methods on the plans. If examination showed the excavator damaged the waterproofing, the excavator is on the hook.
hdavis is offline
Old 04-10-2019, 01:23 PM   #15
Trade: excavation
Rewards Points: 2
Disclaimer: I'm the excavation manager, not the foreman for the job.
Simple answer is it's never been speced on plans, and it's not common practice in my area. We have talked to engineers on the issue, and was told the vertical cracks from curing are going to happen and acceptable.
I see why control joints are needed though, and we joint flatwork so why wouldn't we think about it for foundations. Thanks, I'll bring the issue up with the rest of the company.
And to answer some other questions, it's not the typical tar based "damp proofing"
It was "waterproofing" the same company also coated the interior walls bellow the garage to act as a 75,000 gallon storage tank for irrigation so hopefully we dont have issues there.
Old 04-10-2019, 05:22 PM   #16
fjn's Avatar
Trade: mason
What is a foundation wall if not a thick slab stood on edge ? Engineers / architects that miss / leave details off the drawings are just like Dr. that leave tools in you after a surgery..........the lawyers will meet them in court. Engineers are supposed to know better,that is why they are paid the big bucks.
By the way,while you are cluing them in,tell them that the bars are to be terminated on either side of the joint and a "slip " joint should be installed there to allow movement,yet allow the structural integrity of the wall to remain.
Joints in poured walls - Concrete Construction
https://www.concreteconstruction.net...96b2-dbf3-a177...
fjn is offline
Old 04-10-2019, 05:24 PM   #17
Trade: excavation
Rewards Points: 2
That page isn't there, but I'm interested in learning more
Old 04-10-2019, 05:32 PM   #18
fjn's Avatar
Trade: mason
Just google joints in poured walls. It will pop up.
fjn is offline
Old 04-10-2019, 05:39 PM   #19
John the Builder
I like your work.
Old 04-10-2019, 05:41 PM   #20
fjn's Avatar
Trade: mason
Watch this,starting around minute # 8. While it is a rather homespun way to address the joint,it is do-able. There a much better propriety slip joint available.
fjn is offline
How to stop water from basement walls and in old wine cellar under front porch. Handros Concrete & Paving 5 04-12-2014 02:25 PM
3" PVC pipe dumpig water into sump pump - what is it? ggsubs Plumbing 9 06-06-2013 07:17 PM
Supplying hot water to 4 apartments joesauers Plumbing Picture Post 8 03-30-2009 07:18 AM
Water in basement EPD Carpentry 3 03-12-2009 12:50 PM
