Veneer Stone Application - Masonry - Contractor Talk
Old 01-03-2019, 01:23 AM   #1
fire_medic's Avatar
Trade: General
Hi All, I’ve got a project on new construction in Texas and am needing to install a 3’ tall wainscoting around the perimeter on the residence. The owner wants only a real stone that’s not offered in a “thin veneer”. They have the exact product at a quary that is 2-2 1/2” thick chopped in random 4-6-8 cuts. Has anyone ever went that thick with wire mesh and scratch coat? It has a 2” brick ledge poured around the foundation so it will have a footing to sit on. Thanks for any replies.
fire_medic is offline
Old 01-03-2019, 01:34 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,462
Re: Veneer Stone Application
in my experience on any real ledge stone, stacked stone, over lath, the masons used wall ties.
on river rock they fit them in where ever they could.
griz is offline
Old 01-03-2019, 08:03 PM   #3
Tscarborough's Avatar
Rewards Points: 1,460
Buy a saw. For adhered stone it has to be less than 14# per square foot (1/2"-1-1/2" thick) , otherwise you need about 90% of the stone on the ledge, and it will probably still look goofy.
Tscarborough is offline
The Following User Says Thank You to Tscarborough For This Useful Post:
Fouthgeneration (01-06-2019)
Old 01-06-2019, 07:09 PM   #4
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,839
One of my competitors has opened a thin veneer Saw service, for small runs of NVT, both resawn rock and split face CMUs/precast, and natural full bed rock. AND FACE BRICK to thin brick...
If you could use both faces, sawing the piece in two would be a $ maker.
A 2.5"x2.5/3.0" angle(galvanized)? laid on the ledge, lagged to the wall or bolted to foundation, would speed the work with uncut rock.
Fouthgeneration is offline
Old 01-06-2019, 07:48 PM   #5
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,798
Yup we do it all the time....you say that there is a small brick ledge so i wouldn’t have any worries about it
Here is a job that i did that is the similar to what you are describing, the wall stone project has stone that was cut to 2-3 inches thick
Another one
Windycity is offline
The Following 4 Users Say Thank You to Windycity For This Useful Post:
Fouthgeneration (01-06-2019), Idothat (01-06-2019), TheConstruct (01-10-2019), Wile E Coyote (01-08-2019)
Old 01-10-2019, 09:55 PM   #6
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
3' tall, sure, 18 feet tall no.
JBM is offline
The Following User Says Thank You to JBM For This Useful Post:
Fouthgeneration (01-13-2019)
Old 01-12-2019, 05:01 AM   #7
Trade: Masonry
A wise Mason would use a stainless stone anchor of some type on the wall and some type of pinch anchor so the sills/water course can't "fall" off in normal service.
Natural "thin" stone is still much denser then Faux products...
Multi-story applications would require added framing AND FOOTINGS IMHO.
Man up, bolt on a lintel, get full bed 100 year plus Life-cycle and room for a working rain wall system, plus added thermal performance....
Leave the Masonry wall paper to the low end markets.
Old 01-12-2019, 09:16 AM   #8
Windycity's Avatar
Trade: Masonry
Originally Posted by Fouthgeneration View Post
A wise Mason
Never came across one of those
Is that like Bigfoot?
Old 01-13-2019, 08:02 PM   #9
Trade: Masonry
All the 'Wise' Masons I knew are dead...
Not counting the Shriner types etc....
Installing veneer stone work on a metal building Jethroe Masonry 16 03-13-2016 05:48 PM
natural stone thin veneer vs cultured stone dom-mas Masonry 48 08-15-2013 08:56 PM
Stone veneer in cold weather SelectDecks Masonry 8 01-14-2013 03:21 PM
Flashing Veneer stone mikehdg Roofing 9 06-30-2009 02:43 PM
Eldorado Stone veneer Imagineer09 Masonry 3 06-25-2009 08:16 PM
