-   Masonry (https://www.contractortalk.com/f48/)
-   -   Veneer Stone Application (https://www.contractortalk.com/f48/veneer-stone-application-414489/)
fire_medic 01-03-2019 01:23 AM
Hi All, I’ve got a project on new construction in Texas and am needing to install a 3’ tall wainscoting around the perimeter on the residence. The owner wants only a real stone that’s not offered in a “thin veneer”. They have the exact product at a quary that is 2-2 1/2” thick chopped in random 4-6-8 cuts. Has anyone ever went that thick with wire mesh and scratch coat? It has a 2” brick ledge poured around the foundation so it will have a footing to sit on. Thanks for any replies.
griz 01-03-2019 01:34 AM
in my experience on any real ledge stone, stacked stone, over lath, the masons used wall ties.
on river rock they fit them in where ever they could.
Tscarborough 01-03-2019 08:03 PM
Buy a saw. For adhered stone it has to be less than 14# per square foot (1/2"-1-1/2" thick) , otherwise you need about 90% of the stone on the ledge, and it will probably still look goofy.
Fouthgeneration 01-06-2019 07:09 PM
One of my competitors has opened a thin veneer Saw service, for small runs of NVT, both resawn rock and split face CMUs/precast, and natural full bed rock. AND FACE BRICK to thin brick...
If you could use both faces, sawing the piece in two would be a $ maker.
A 2.5"x2.5/3.0" angle(galvanized)? laid on the ledge, lagged to the wall or bolted to foundation, would speed the work with uncut rock.
Windycity 01-06-2019 07:48 PM
Yup we do it all the time....you say that there is a small brick ledge so i wouldn’t have any worries about it
Here is a job that i did that is the similar to what you are describing, the wall stone project has stone that was cut to 2-3 inches thick
Sent from my iPhone using Tapatalkhttps://uploads.tapatalk-cdn.com/201...10ff387587.jpg
https://uploads.tapatalk-cdn.com/201...96f77c38c2.jpg
Another one
https://uploads.tapatalk-cdn.com/201...522a068c82.jpg
https://uploads.tapatalk-cdn.com/201...5d83c152db.jpg
JBM 01-10-2019 09:55 PM
3' tall, sure, 18 feet tall no.
Fouthgeneration 01-12-2019 05:01 AM
A wise Mason would use a stainless stone anchor of some type on the wall and some type of pinch anchor so the sills/water course can't "fall" off in normal service.
Natural "thin" stone is still much denser then Faux products...
Multi-story applications would require added framing AND FOOTINGS IMHO.
Man up, bolt on a lintel, get full bed 100 year plus Life-cycle and room for a working rain wall system, plus added thermal performance....
Leave the Masonry wall paper to the low end markets.
Windycity 01-12-2019 09:16 AM
Originally Posted by Fouthgeneration (Post 7453065)
A wise Mason
Never came across one of those
Is that like Bigfoot?
Fouthgeneration 01-13-2019 08:02 PM
All the 'Wise' Masons I knew are dead...
Not counting the Shriner types etc....
