Ugl Bonding Agent - Masonry - Contractor Talk
Ugl Bonding Agent
Old 04-06-2015, 05:28 PM   #1
Renaissance Man
superseal's Avatar
Rewards Points: 5,816
Ugl Bonding Agent
I ran out of Acryl 60 so the nearest supplier had UGL bonding agent. Gave it a try and was pretty impressed...would use it again.
Simple project of resurfacing some concrete spalling on a driveway apron and I mixed a rich color match using bar sand and white portland. Just a tad of deep buff and the mix was fairly close to blend.
According to UGL, it's an admix and bonder and I didn't see any mention of one or the other. I rolled it on the surface and used a 1:1 ratio in the mix and it was quite an impressive mud.
Within a hour or so when I went to clean some mixing trowels, it was stuck tenaciously and hardened like a 28 day cure
Of all the different bonding agents I've used over the years, I'd rank this a good quality and will definitely use again.
Next on the list is cutting out some expansion joints and hitting them with a 2 part polyurethane followed by an application of SureKlean Salt Guard WB. I'll snap some pics when it's done...
supersealconstruction.com
superseal is offline
The Following 3 Users Say Thank You to superseal For This Useful Post:
fjn (04-06-2015), hdavis (04-06-2015), JBM (04-06-2015)
Old 04-06-2015, 06:25 PM   #2
fjn's Avatar
Trade: mason
Rewards Points: 10,710
Re: Ugl Bonding Agent
Before you even think of cutting expansion or control joints,you better check with the engineer and have him sign off. What makes you think you can just indiscriminately take it on yourself to do that ? ?
fjn is offline
superseal (04-06-2015)
Bonding darrylb02 Business 10 04-15-2013 02:19 AM
R E agent says proposed buyers can sue for breach of contract? curapa General Discussion 19 10-27-2009 07:22 AM
bonding agent for stone driveway rocknhammer Specialty Trades Picture Post 5 09-28-2008 06:25 PM
bonding agent ApgarNJ Masonry 10 05-09-2008 10:16 AM
System Bonding Jumper vs. Main Bonding Jumper Mark Twenhafel NEC Discussion 3 02-09-2008 06:15 PM
