Tuckpoint Blades Single, Double, Triple - Masonry - Contractor Talk
Old 05-17-2019, 03:39 PM   #1
john2019's Avatar
Rewards Points: 40
Thoughts on tuckpoint blades? Such as the sandwich Bosch DD4510H, or do guys prefer the single blades?
john2019 is offline
Old 05-17-2019, 04:45 PM   #2
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,490
Re: Tuckpoint Blades Single, Double, Triple
I like the double and triple blades because they keep the width as they wear down as opposed to a single blade which gets more narrow.
The only problem I have with sandwich type blades like that is they have a tendency to throw more large debris
For example with a regular single tuckpoint blade regular safety glasses are enough where as the sandwich type blade you need a face shield because the chips blast your face
Windycity is online now
Old 05-17-2019, 06:09 PM   #3
fjn's Avatar
Trade: mason
Rewards Points: 11,202
You need all three to fit various joint widths. I'ts not one size fits all.
fjn is offline
Old 05-18-2019, 09:44 AM   #4
john2019's Avatar
Rewards Points: 40
I understand needing many blades I guess the question was centered around how Windycity put it about chips flying more with the sandwich blades.
I was thinking that in the back of the cut with a single blade there is a better chance to not have a sliver left behind like what the double sandwich blade might leave because in some cases you would be limited to how much you could move that blade up and down
john2019 is offline
Old 05-18-2019, 10:06 AM   #5
fjn's Avatar
Trade: mason
Where needed,the slivers can be cleaned up lickity split with the various size mortar router bits on an angle grinder if the need be.
https://www.bontool.com/mortar-route...ter-3-8-11-826
fjn is offline
Old 05-18-2019, 02:49 PM   #6
Windycity's Avatar
Trade: Masonry
Do those work good, i have never actually seen one in use
Old 05-18-2019, 02:54 PM   #7
Windycity's Avatar
Trade: Masonry
Yes, absolutely you need several blades, I probably have about 20 of them
You donít really need a face shield, although itís not a bad idea but it just seems like when i use the sandwich blades my face gets blasted alot more than the regular blades
Itís not a deal breaker but its something i noticed while using them
The Following User Says Thank You to Windycity For This Useful Post:
fjn (05-18-2019)
Old 05-18-2019, 04:28 PM   #8
fjn's Avatar
Trade: mason
They work great for clean up of slivers and mortar left on edges of brick with hard mortar,they also work great with soft lime mortar,way less dust than grinder. On hard mortar not cut first with grinder,I would not endorse them in that capacity.
fjn is offline
Old 05-18-2019, 04:41 PM   #9
Windycity's Avatar
Trade: Masonry
Thats good to know!
Ill have to pick on up and try it out
fjn (05-18-2019)
Hot mop showers vs waterproofing systems Floormasta78 Tiling 161 01-29-2019 08:03 AM
dewalt 20v flush cutter blades VinylHanger Tools & Equipment 29 08-01-2016 10:14 AM
tuck pointing double diamond blades... Rock Headed Masonry 12 10-26-2015 08:20 PM
single or double cheek cut hips? PZA Carpentry 25 10-12-2011 09:48 PM
Recommendation on Single pole double throw (SPDT) thermostats mtplus HVAC 19 04-10-2011 09:36 AM
