Trim For Waterproofing Membrane Below EIFS. - Masonry - Contractor Talk
Old 10-28-2019, 05:50 PM   #1
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 478
Anyone know of a product or how to match EIFS over ICF where it meets up to the dimple board?
I used Platon right to the sill plate when we built the walls, as finish grade wasn't known yet. Grade has been done and now they want EIFS over the exposed wall.
Whats the best way to meet up to the Platon fabric. I plan on cutting the platon just above grade and removing the clips so I can get the brown coat on the for the EIFS.
Should I try to trim in a drip edge of some sort, or just leave the platon flapping in the wind?
NYCB is offline
Old 10-29-2019, 04:17 PM   #2
fjn's Avatar
Trade: mason
Rewards Points: 11,140
Re: Trim For Waterproofing Membrane Below EIFS.
It is my understanding that Platon should always have a termination bar at the top. Reasons being,so it does not flap in the breeze but more importantly,so debris does not have an opportunity to get behind it. Platon does manufacture their own termination bars. My local dealer does not stock it so every job I do it is a special order.
fjn is offline
Old 10-29-2019, 04:26 PM   #3
fjn's Avatar
Trade: mason
They come in two varieties,this is one.
https://www.menards.com/main/buildin...4444226438.htm
fjn is offline
Old 10-30-2019, 02:32 PM   #4
NYCB's Avatar
Rewards Points: 478
Thanks, I guess I will call the ICF supplier (where I got the platon) and ask what they have.
Installation instructions I got were just the clips with the flat strip of the fabric on top, I've used it multiple times, but have never had to go back and remove it for something like this.
Had we had some kind of idea where grade was originally it would have probably saved a lot of hassle.
NYCB is offline
Old 10-30-2019, 04:32 PM   #5
fjn's Avatar
Trade: mason
Don't forget,when you establish final grade,code mandates soil to slope 6 " in first 10 ' from building. Also,6 " of foundation needs to be exposed on frame buildings and 4 " on masonry buildings. Eighty + % of buildings by me get none of that correct. Inspectors are clueless and buildings suffer from water issues til the cows come home.
fjn is offline
Old 10-30-2019, 04:44 PM   #6
NYCB's Avatar
Rewards Points: 478
The grade guy is a good one, I don't mess with any of that stuff, if someone told me one of my walls was leaking and the grade was pointed back at the house I would probably have to laugh a little.
That Platon is good stuff though, it's tougher than hell, better than the ice and water type stuff we used to put over ICF.
NYCB is offline
The Following User Says Thank You to NYCB For This Useful Post:
fjn (10-30-2019)
Old 10-30-2019, 04:52 PM   #7
fjn's Avatar
Trade: mason
Yeah,I discovered Platon around 2004 and have used it ever since.
fjn is offline
Old 11-01-2019, 05:42 AM   #8
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,009
Commercial flat roofers wholesalers sell the term bar ...usually cheaper then my Masonry supply chain....
Often I'll buy some smaller amounts from the roofer on the job....
I'd like to see a weather "course" bump out at the transition to the basement stucco to hide some of wall waves... detail at the bottom of the EIFS product panel.
Fouthgeneration is online now
