Tie In New CMU Block Wall Perpendicular To An Existing CMU Wall - Masonry - Contractor Talk
Old 03-13-2016, 12:02 PM   #1
madayew's Avatar
Rewards Points: 14
Hey guys,
Doing a basement addition on a home that is perpendicular to an existing CMU block wall. I had planned on doweling and epoxying the old foundation to the new but am struggling with the best strategy for joining the block foundation walls together.
I am reading of a few options:
1) No tie in at all and just one elastomeric isolation joint
2) Wall ties tacked into the old block wall and mortared in between the new block
3)Filling the old wall solid and doweling into the new wall
4) Angle iron attaching the old wall to the new wall
Any thoughts or suggestions would help
madayew is offline
Old 03-13-2016, 01:04 PM   #2
NJ Brickie's Avatar
Trade: Bricklayer
Rewards Points: 750
Re: Tie In New CMU Block Wall Perpendicular To An Existing CMU Wall
My suggestion would be let an engineer spec what's best. Nothing on the plans?
NJ Brickie is offline
The Following 2 Users Say Thank You to NJ Brickie For This Useful Post:
DaVinciRemodel (03-13-2016), fjn (03-13-2016)
Old 03-13-2016, 01:14 PM   #3
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,268
Could you use some of these?
http://www.insulationexpress.co.uk/P...FcrjGwod1IQA9A
stuart45 is offline
Old 03-13-2016, 01:40 PM   #4
madayew's Avatar
Rewards Points: 14
sorry , that link does not work
madayew is offline
Old 03-13-2016, 01:56 PM   #5
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Are the footings doweled together? If so option 3, if no option 1
www.dominionmasonry.ca
dom-mas is offline
Old 03-13-2016, 01:59 PM   #6
stuart45's Avatar
Trade: Brickwork
Sorry, how about this one.
http://www.screwfix.com/p/sabrefix-w...ss-steel/56037
stuart45 is offline
The Following User Says Thank You to stuart45 For This Useful Post:
dom-mas (03-13-2016)
Old 03-13-2016, 05:17 PM   #7
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
neat product
dom-mas is offline
Old 03-13-2016, 05:39 PM   #8
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,768
Is the existing block wall filled with grout? If so i would drill some rebar and epoxy it in every couple of coarses. If its hollow i would cut some matching openings in the new and the old block every couple of coarses and fill them both up with grout and pieces of rebar to lock the new and old together.... I dont know if its the proper way engineering wise but i dont like cold joints. They always seem to have issues and it's amazing how frickin strong grout and rebar is.....i get to demo walls all the time that is filled with grout
Windycity is online now
Old 03-13-2016, 05:55 PM   #9
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Here is another way to skin the cat.Page 286 shows tie bars. I would break holes in existing block to install,along with holes to pour grout.
For the footing,I would dig under existing footing to allow new one to lock around it along with re-bar and epoxy.
I would run these ideas past engineer,let them sign off. Why assume the mantel of responsibility. Design is truly their bailiwick.
fjn is offline
Old 03-13-2016, 05:57 PM   #10
fjn's Avatar
Trade: mason
Forgot to post connection.
https://books.google.com/books?id=ET...gether&f=false
fjn is offline
Old 03-13-2016, 06:22 PM   #11
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
Pour the cell when done, as you build hollow out a course, put corner steel into the cell and into a deadman beam . Do that for 30-50% of the courses.
JBM is offline
Old 03-13-2016, 06:26 PM   #12
JBM's Avatar
Trade: Masonry
Forgot to add, pour adjacent cells o/c, if you pour 1 its good , if you pour 2 adjacent cells, or 1 whole block its better.
JBM is offline
Old 03-14-2016, 01:33 PM   #13
heavyc's Avatar
Trade: masonry
Rewards Points: 945
Why do the walls have to be tied/laced at all?
heavyc is offline
Old 03-22-2016, 06:19 PM   #14
S.U.M's Avatar
Trade: Brick/Stone Mason
Rewards Points: 1,286
I am doing this on a indoor basement project at the minute.
We are tying the new 6" block wall into the existing with 15m rebar every 16" and filling the first block solid, the rebar is 12" long 6in 6 out. It will be epoxied into the existing. All engineer spec's.
Also on the same project we have to build a 6" block wall Parallel to the existing basement wall addition at the back of the home. The homeowner wanted to top up his little single story bump out but when the previous owner had the foundation walls built they contractor used 6" block.
We have had to underpin (my first time) the entire addition and over pour the underpin to allow for a new 6" block wall to be built.
The new parallel wall is to tied into the existing with 10m rebar every 16" both ways, epoxied into the existing and cells filled solid, have to also allow 1/2"-1" gap between the 2 walls and fill solid.
Nice little project, except the underpinning part the boys hate it, they better get used to it gonna do more of it espically in the winter,
S.U.M is offline
The Following User Says Thank You to S.U.M For This Useful Post:
dom-mas (03-23-2016)
Old 03-23-2016, 06:58 PM   #15
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
6" foundation walls??? And the house is still standing? Must be some free draining soil or something
dom-mas is offline
Old 03-25-2016, 10:49 AM   #16
patrick grey's Avatar
Trade: mason
Rewards Points: 100
Originally Posted by stuart45 View Post
Excellent things the wall starter kits used them loads of times
patrick grey is offline
Old 03-25-2016, 11:12 AM   #17
S.U.M's Avatar
Just little timber frame addition in top, we found in Wednesday one of the walls is only 4" in one corner.
S.U.M is offline
Concrete steps masonry block comegetme Masonry 54 12-23-2015 11:44 AM
Drilling Through Concrete Block Wall FullerFramer Masonry 16 05-26-2013 06:05 PM
can any one id this wall sensor HUDSONVALLEYEXT General Discussion 8 06-15-2012 07:20 AM
Making a bed joint look like a laser beam on an existing wall... dakzaag Masonry 23 01-17-2012 11:05 PM
any suggestions for this block retaining wall? ch0mpie Masonry 6 10-02-2009 03:06 PM
