Thin Stone Application. - Masonry - Contractor Talk
Old 02-24-2015, 05:42 PM   #1
S.U.M's Avatar
Trade: Brick/Stone Mason
Rewards Points: 1,286
Had a discussion on a job today with a G.C, we have some thin veneer stone to install over concrete/cement board, he wants lath and plaster but I don't think it's nessassary over concrete board.
What is your guys preferred method when installing stone over cement/concrete board.
Also the concrete board was install on 2x4s with a gap maybe 12" in between, not a solid flat surface, should I be concerned about this, when I install the stone if there is any sort of bounce due to lack of support behind the board this could and most likely will loosen the freshly installed stone bond.
S.U.M is offline
Old 02-24-2015, 06:22 PM   #2
Nouveau Eccentric
Diamond D.'s Avatar
Trade: masonry/hardscaping
Rewards Points: 2,888
Re: Thin Stone Application.
Well, O.C. Cultured Stone, wants lath over CBU if that gives you any insight.
Other manufacturers may have different requirements.
I'd use it.
You don't necessarily have to scratch it first, you can scratch and set as you go.
Personally, I like to just bang out the scratch coat, then I can concentrate on placing units.
I think it sticks better as well, no worries about slippage or sagging.
D.
" ROCK YOUR WORLD "
fb
Diamond D. is offline
Old 02-24-2015, 06:39 PM   #3
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Follow the manufacture's recommendations and you won't have any trouble.
My recollection is that wire is not necessary on cement board, but I am not sure.
Did you say this is interior or exterior?
A lot of guys skip the scratch coat, but I have yet to find documentation from any manufacturer that agrees with omitting the scratch coat.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
Old 02-24-2015, 06:43 PM   #4
S.U.M's Avatar
It is exterior work, I have done a lot of this work before but mostly on existing masonry walls, my main concern is the way the concrete board was installed.
S.U.M is offline
Old 02-25-2015, 07:41 AM   #5
6stringmason's Avatar
Trade: masonry
Rewards Points: 1,136
If its not a whole lot of sq footage, I would probably tear it off, put on OSB, or some other sheeting depending on what it is, and water proof, lathe and scratch. We've only done manufactured stone over cement board on interior fireplaces up here.
Kamps Masonry 920-680-3195
https://www.facebook.com/pages/Kamps...31566206923069
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline
Old 02-25-2015, 08:00 AM   #6
dakzaag's Avatar
Trade: mason
Rewards Points: 786
What is the water screen consist of? If you have to add another layer to manage the water, then you are pretty well locked into a wire application.
No offense 6 string, but I would never consider OSB as an upgrade over cement board. I don't think there will be any problem with the cement board flexing if it is hung on 12" spacing.
D K & Sons
dakzaag is offline
Old 02-25-2015, 09:01 AM   #7
Tscarborough's Avatar
Rewards Points: 1,456
It still has wood under it. Thinset the joints, waterproof the substrate and then thinset the stone.
Tscarborough is offline
Old 02-25-2015, 12:56 PM   #8
Trade: masonry
You dont think so? I would think nailing lathe to OSB, or similar sheathing like on home exteriors is better than cement board. Obviously you have to put the moisture barriers on it, but I'd rather be able to nail my lathe to OSB before cement board. Cement board, from my experience blows up and doesnt hold nails as well. I cant get my lathe nearly as flat and tight on CB as I can on OSB. Unless I've been doing it wrong lol. The only time we've ever used CB is for interior apps though, and we've always thinset our materials to the board.
Visit our website @
The Following User Says Thank You to 6stringmason For This Useful Post:
stonelayer (03-03-2015)
Old 02-25-2015, 04:43 PM   #9
Nick520's Avatar
Trade: Mason
Rewards Points: 514
I'd prefer plywood of some sort on an exterior rather than CB. Why pay for the CB if your gonna lath over it?
Nick520 is offline
The Following User Says Thank You to Nick520 For This Useful Post:
dom-mas (02-25-2015)
Old 02-25-2015, 06:29 PM   #10
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
I only use thinset if I'm going on cement board. I'd imagine acrylic modified mortar would stick well but I KNOW thinset will
But I've only used cement board indoors. 12" spacing should be plenty. I can't see it flexing so long as adequate screws are used
www.dominionmasonry.ca
dom-mas is offline
Old 02-25-2015, 06:52 PM   #11
JBM's Avatar
Trade: Masonry
Rewards Points: 9,490
First back up.
The GC wants thin stone over a section of the house, which should have some sort of plywood on it.
I put Illuminati resistant tape on the cement board.
JBM is online now
Old 02-25-2015, 11:39 PM   #12
dakzaag's Avatar
Trade: mason
Rewards Points: 786
My issue with OSB exterior is it becomes vertical mulch when moisture gets to it. Cement Board will not be affected by moisture.
Ya I cover OSB all the time and usually we start with two layers of felt and then wire and scratch. While you can't nail CB very well unless you stay on the studs, it will withstand moisture a lot better. That's why I would stick with the CB. Mud the seams and apply a water barrier.
Its weird that we use the CB inside where it is very unlikely to get wet and then use OSB on the outside where moisture is almost guaranteed to penetrate.
I need to get me some of that tape...
D K & Sons
dakzaag is offline
Old 02-28-2015, 02:20 AM   #13
Mark Parlee's Avatar
Trade: General Contractor/ Building Envelope Consultant
Rewards Points: 42
If you are installing the stone directly to the CB what are you doing to make the assembly drainable.
The building code requires the assembly to be drainable.
Here is a good document to follow with installation of AMSV.
http://ncma-br.org/pdfs/masterlibrar...2nd%20Prtg.pdf
I do inspections on EIFS, Stucco, and AMSV in 5 states on homes in real estate transactions that are going into a relocation buyout. out of the last 400 buildings I have inspected I have hod only two that almost that were anywhere close to the installation guidelines.
Improperly installed and drained stone veneer is going to make the EIFS problems in this country look like a tiny drop in the bucket.
Mark Parlee
EDI Certified EIFS Inspector/Moisture Analyst/Quality Control/Building Envelope II EDI Seminar Instructor
www.thebuildingconsultant.com
Mark Parlee is offline
Old 02-28-2015, 08:41 AM   #14
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Mr. Parlee is dead on regarding improperly installed thin stone and the like. No one seems to remember that this is basically a hard sponge attached to OSB in wet climates. What could possibly go wrong?
D K & Sons
dakzaag is offline
Old 02-28-2015, 08:43 AM   #15
JBM's Avatar
Trade: Masonry
I attempted an article as this very issue.
http://www.jbmohlermasonry.com/Mason...-stone-veneer/
and here
http://www.mason-contractor.com/outd...stone-veneers/
JBM is online now
Old 02-28-2015, 10:36 AM   #16
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
The assembly would be drainable due to the furring strips that the CB is attached to
dom-mas is offline
Old 03-01-2015, 01:44 AM   #17
Rewards Points: 42
Dom-mas
Installing the veneer directly to the cement board will allow moisture that get into the assembly to come into contact with with the cement board. Fiber cement will delaminate over time and the veneer is only stuck to the outermost layer of the cement board. When this outer layer delaminates the veneer is only adhered to a delaminating layer.
I agree that the water that gets behind the cement board will drain if everything is in place correctly with the furring strips but the furring strips do nothing to drain moisture that is between the veneer and the front face of the cement board.
Mark Parlee
Old 03-01-2015, 10:48 AM   #18
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Sure and if water permeates a lathed and scratch wall the scratch coat could crumble even with a rainscreen. The primary purpose of drainage planes is to stop water from permeating the wall assembly and the living space. The furring strips do a great job of that
dom-mas is offline
Old 03-01-2015, 11:43 PM   #19
Rewards Points: 42
Typically water will penetrate the lath and scratch. The double layer of grade D paper that is behind the lath and scratch is to be the drain plane and will work as long as the installer ran the paper over the foundation to the base of the assembly and lapped the weep screed.
The furring strip type of rainscreen is better. There are some other options for the rainscreen such Keene Driwall http://www.keenebuilding.com/residen...een-020-1.aspx or Gravity Cavity by MTI http://mtidry.com/
any properly applied and drained rainscreen is a step in the right direction.
The OP asked about installing the veneer over the fiber cement without lath and scratch which is a bad idea and does not meet code or the MVMA guidelines
Adhered veneer is really stucco with the masonry veneer adhered to the base or scratch as the finish. The adhered veneer application is addressed in the building codes and various ESR reports for the various products.
ESR documents are part of the code and and state refereng to the ESR documents themselves "where this document and code disagree, this document prevails"
Send me an email and I will email you and article I wrote regarding one of the veneer failures we investigated and its outcome.
At this point we have five of these cases open this year. In our state there is a fifteen statute covering construction defects and the original builder is the one responsible to cover. Most states are ten years.
Mark Parlee
Old 03-02-2015, 02:49 AM   #20
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
But he also refered to the cement board being nailed @ 12" and the question of flex indicates that there is a void behind the cement board further indicating furring strips are being used. Furring the substrate out from the sheathing is one of the best ways to keep water from penetrating the building envelope. keeping the material from delaminating from the substrate isn't really the purpose of the drainage plane.
dom-mas is offline
Thin stone 135 degree corners EthanB Masonry 12 10-22-2013 07:32 AM
Halquist thin stone Tweed11 Masonry 28 08-11-2013 02:30 PM
When the thin blue line becomes black killzoneq2 Sandblasting 6 04-24-2013 04:33 PM
Dry laid stone patio, Crushed 1A vs Sand NYCB Masonry 14 04-20-2013 09:35 PM
Stone over Dryvit Red 5 Masonry 6 04-19-2010 12:40 PM
