Stupid Question Time. - Page 3 - Masonry - Contractor Talk
Old 05-31-2015, 07:57 AM   #41
Smarter than the brick...
Kniggit's Avatar
Trade: Masonry
Rewards Points: 561
Re: Stupid Question Time.
Originally Posted by JBM View Post
Come on FG, id use that saw in a heartbeat. Id even have my guy spray water on the blade while im using it!
Yup, that's what 80% of the "contractors" around here use, or the Dewalt equivalent. I have one but it's usually just used for cutting angle iron, though it does come in handy if you just have a cut or two to make and don't want to drag out the Target.
Kniggit is offline
The Following User Says Thank You to Kniggit For This Useful Post:
JAH (05-31-2015)
Old 05-31-2015, 07:32 PM   #42
JAH's Avatar
Trade: carpenter
Rewards Points: 1,910
Originally Posted by Fouthgeneration View Post
FYI, a diamond wheel "cuts" by grinding, not actually peeling material away like 99% of wood cutting tools, thus they cut skin and bone a little slower....
One has to hold the material steady for tens of seconds instead a few...
None of my dedicated masonry saws have a "brake".
If your outfit can't afford to buy/rent needed tools,maybe its time to look for work in a less competitive field.
You and your kind are running up my Workmen's Comp. charges.
Rough day?
The OP asked a ? about miter saws for masonry work, I posted a pic. If you dont like the saw I use, thats fine. You and your kind are not required to use them.
JAH is offline
Old 06-01-2015, 02:56 AM   #43
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,953
Everyone: there is a large difference in a experienced mason using a cobbled up saw then some jack of all trades whose still working on his first hundred cut units. the U(ntrained) T(rained) I(diots) are the one that will end up in the E-room costing everyone in the Workmen's Comp exchange thousands of dollars a year for years to come.
The chance of injury is several times higher with incorrect saw.
Fouthgeneration is online now
The Following User Says Thank You to Fouthgeneration For This Useful Post:
JBM (06-01-2015)
New? Have A Question? Read This First. Seven-Delta-FortyOne General Discussion 58 07-31-2019 02:46 AM
Time delay relay PlumbBob^2Pants HVAC 4 06-17-2013 09:29 PM
Stupid question Eric K Masonry 36 01-16-2013 04:28 PM
Question on re-decking prices!! RHS Design Roofing 1 12-08-2012 08:48 AM
Ask a stupid question, get a stupid answer Ron The Plumber Off Topic (Non Trade) 7 12-23-2007 06:01 PM
